Missing software
Non-Desktop related topics
ferri
Missing software
Сообщение ferri »
This time I missing in repos two-pannels file manager krusader.
Re: Missing software
Lots of packages from contrib are rebuilding at the moment. Please wait a little until they become available in repos.
Or you can use Dolphin TWO panel by press F3.
ferri
Сообщение ferri »
PastorDi писал(а):Or you can use Dolphin TWO panel by press F3.
For file management I prefer keyboard. Old school ;)
So Krusader is quite good compromise between midnight commander and mentioned dolphin (for example).
kifto
Сообщение kifto »
I've just registered to thank ROSA for your great job...and to say that I use krusader for exactly the same reasons in any KDE desktop that I have to manage.
There are a few other apps that I miss too, like powertop (to check & save energy, really useful in a laptop) or htop, but mostly the whole system is a piece of art, very friendly and usable.Congratulations.
kifto писал(а):There are a few other apps that I miss too, like powertop (to check & save energy, really useful in a laptop) or htop, but mostly the whole system is a piece of art, very friendly and usable.Congratulations.
Htop is present in the repository. You can install it with the command:
urpmi htop
kifto
Сообщение kifto »
that's true, I don't know why I mentioned it, because I even got it already installed, I've had a lapsus with another package. Thamks
As I mentioned above, we have lots of programs from contrib rebuilding at the moment in ABF. Contrib has about 16000 packges so please-please have patience :)
Additional reading: ROSA's Repo Policy :idea:
We should expect mass income of freshly rebuilded packages from contrib during next week. Please stay up to date :)
List of packages which are currently rebuilding: https://abf.rosalinux.ru/build_lists
ferri
Сообщение ferri »
ДроноваЮ писал(а):List of packages which are currently rebuilding: https://abf.rosalinux.ru/build_lists
I miss i586 version of poedit. There is only x86_64 version.
I use it for translation KDE environment language files.
awl
Сообщение awl »
ferri писал(а):This time I missing in repos two-pannels file manager krusader.
Krusader has been builded!
You can install it from this personal repos:
i586
http://abf.rosalinux.ru/downloads/impor ... 2695/RPMS/
x86_64
http://abf.rosalinux.ru/downloads/impor ... 2696/RPMS/
OMNE NIMIUM NOCET
ferri
Сообщение ferri »
Thanks
ferri
Сообщение ferri »
ferri писал(а): I miss i586 version of poedit. There is only x86_64 version.
Thanks. Already in repo. :D
Последний раз редактировалось ferri 21 июн 2012, 16:58, всего редактировалось 1 раз.
captain_america
Сообщение captain_america »
I would also like to see Synapse and nano packages added to the repositories. Synapse is an application launcher, and the project page is located at:
https://launchpad.net/synapse-project
Nano, as most of you probably know, is a CLI text editor. The project page is located at: http://www.nano-editor.org/
Thanks! :D
When the mob and the press and the whole world tell you to move, your job is to plant yourself like a tree beside the river of truth, and tell the whole world----No you move.- Captain America
captain_america писал(а):Nano, as most of you probably know, is a CLI text editor. The project page is located at: http://www.nano-editor.org/
You can install nano from Contrib/Updates repository. Just enable Contrib/Updates via checkbox in "Install and remove software" application.
It's not the latest stable nano, but I guess 2.2.4 should be fine anyway. :) In case you really need 2.2.6, let me know and I'll update it.
captain_america писал(а):I would also like to see Synapse and nano packages added to the repositories. Synapse is an application launcher, and the project page is located at:
I guess you need to add bug-report for it in bugzilla: http://bugs.rosalinux.ru/
Something like "[PACKAGE REQUEST] Synapse". I'll assign it to myself to make sure I won't forget about it when I have some free time to add new packages :)
captain_america
Pulfer,
Many thanks for your help and reply! Nano 2.2.4 will work just fine. As per your instructions, I have filed a bug report for the package request of Synapse launcher. :)
captain_america писал(а):Pulfer,
After some investigations I found that Synapse requires at least Vala 0.14. While we have 0.12 in Rosa 2012 LTS (and I see in changelog that Vala was reverted back to 0.12 due to some stability issues). I cannot say for sure if it's possible to update Vala, I need to discuss it with other developers.
captain_america
Thanks Pulfer! I understand if it is not possible to update Vala, especially where stability is a major concern for an enterprise and LTS distro. I can live without Synapse, but it would have been nice to have it in the repos.
captain_america писал(а):Thanks Pulfer! I understand if it is not possible to update Vala, especially where stability is a major concern for an enterprise and LTS distro. I can live without Synapse, but it would have been nice to have it in the repos.
Meanwhile I prepared all necessary updates. If they pass QA and security validation, we'll have Synapse in 2012 LTS repos. :)
As for Rosa 2012.1 (aka Desktop), I already added Synapse to repositories. So when 2012.1 is released, Synapse will be there in Contrib.
bluethoughtz
Сообщение bluethoughtz »
i thought that too until i enabled the contrib repos then i found everything i needed
Now done for ROSA 2012 LTS too :) Don't forget to update your system before using Synapse. It requires some library updates from Main and Contrib /updates.
From Bugzilla:
Konstantin Vlasov - Created a project for Double Commander file manager, and request for putting it into the contrib repository.
At the moment the packages are built and published in my(Konstantin Vlasov) personal repository:
x64 - http://abf.rosalinux.ru/downloads/captainflint_personal/repository/rosa2012lts/x86_64/main/release/
x32 - http://abf.rosalinux.ru/downloads/captainflint_personal/repository/rosa2012lts/i586/main/release/
Sources:
https://abf.rosalinux.ru/captainflint/doublecmd
https://abf.rosalinux.ru/captainflint/libQt4Pas (required by dependencies)
Description of the application (taken from the developer's web site):
Double Commander is a cross platform open source file manager with two panels side by side. It is inspired by Total Commander and features some new ideas.
Here are some key features of Double Commander:
* Unicode support
* All operations working in background
* Multi-rename tool
* Tabbed interface
* Custom columns
* Internal text editor (F4) with syntax hightlighting
* Built in file viewer (F3) to view files of in hex, binary or text format
* Archives are handled like subdirectories. You can easily copy files to and from archives. Supported archive types: ZIP, TAR GZ, TGZ, LZMA and also BZ2, RPM, CPIO, DEB, RAR.
* Extended search function with full text search in any files
* Configurable button bar to start external programs or internal menu commands
* Total Commander WCX, WDX and WLX plug-ins support
* File operations logging
* And more...
Изображение Изображение
