GnuCash failure [SOLVED]
DShelbyD
Operating system: Linux
Сообщение DShelbyD »
Installed gnucash, saw messsage about something needing to be compiled (never seen before). Clicked OK to compile. Nothing happened. Closed the dialog box. Tried to start gnucash, saw banner, which disappeared quickly. Nothing more happened. Any ideas?
I'm very impressed with 2012.1, but this is a problem.
Thanks,
David
Последний раз редактировалось DShelbyD 29 янв 2013, 07:50, всего редактировалось 1 раз.
DShelbyD
Re: GnuCash failure
Tried to start it from the command line:
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
;;; note: auto-compilation is enabled, set GUILE_AUTO_COMPILE=0
;;;       or pass the --no-auto-compile argument to disable.
;;; compiling /usr/share/gnucash/guile-modules/gnucash/main.scm
;;; compiling /usr/share/gnucash/guile-modules/gnucash/core-utils.scm
;;; WARNING: compilation of /usr/share/gnucash/guile-modules/gnucash/core-utils.scm failed:
;;; ERROR: no code for module (sw_core_utils)
;;; WARNING: compilation of /usr/share/gnucash/guile-modules/gnucash/main.scm failed:
;;; ERROR: In procedure dynamic-link: file: "libgnc-core-utils", message: "file not found"
;;; compiling /usr/share/gnucash/guile-modules/gnucash/gnc-module.scm
;;; WARNING: compilation of /usr/share/gnucash/guile-modules/gnucash/gnc-module.scm failed:
;;; ERROR: no code for module (sw_gnc_module)
Backtrace:
In unknown file:
   ?: 19 [catch-closure]
In ice-9/boot-9.scm:
2505: 18 [#<procedure 28fd460 at ice-9/boot-9.scm:2493:4 (name #:optional autoload version #:key ensure)> # ...]
2772: 17 [try-module-autoload (gnucash main) #f]
2111: 16 [save-module-excursion #<procedure 2b07b70 at ice-9/boot-9.scm:2773:17 ()>]
2783: 15 [#<procedure 2b07b70 at ice-9/boot-9.scm:2773:17 ()>]
In unknown file:
   ?: 14 [primitive-load-path "gnucash/main" #f]
In ice-9/eval.scm:
 480: 13 [#<procedure 285cb20 at ice-9/eval.scm:474:4 (exp)> (use-modules #)]
In ice-9/psyntax.scm:
1101: 12 [expand-top-sequence ((use-modules (gnucash gnc-module))) () ...]
 986: 11 [scan ((use-modules (gnucash gnc-module))) () ...]
 270: 10 [scan ((# #) #(syntax-object *unspecified* # #)) () (()) ...]
3244: 9 [process-use-modules (((gnucash gnc-module)))]
 545: 8 [map #<procedure 290bca0 at ice-9/boot-9.scm:3244:25 (mif-args)> ((#))]
3245: 7 [#<procedure 290bca0 at ice-9/boot-9.scm:3244:25 (mif-args)> (#)]
2580: 6 [resolve-interface (gnucash gnc-module) #:select ...]
2505: 5 [#<procedure 28fd460 at ice-9/boot-9.scm:2493:4 (name #:optional autoload version #:key ensure)> # ...]
2772: 4 [try-module-autoload (gnucash gnc-module) #f]
2111: 3 [save-module-excursion #<procedure 2d2f750 at ice-9/boot-9.scm:2773:17 ()>]
2783: 2 [#<procedure 2d2f750 at ice-9/boot-9.scm:2773:17 ()>]
In unknown file:
   ?: 1 [primitive-load-path "gnucash/gnc-module" #f]
   ?: 0 [load-extension "libgnc-module" "scm_init_sw_gnc_module_module"]
ERROR: In procedure load-extension:
ERROR: In procedure dynamic-link: file: "libgnc-module", message: "file not found"
Re: GnuCash failure
DShelbyD писал(а):Installed gnucash, saw messsage about something needing to be compiled (never seen before). Clicked OK to compile. Nothing happened. Closed the dialog box. Tried to start gnucash, saw banner, which disappeared quickly. Nothing more happened. Any ideas?
I guess gnucash package should be fixed in repositories. Re-compiled with another version of guile. Wait few days please.
DShelbyD
Re: GnuCash failure
I will. Grazie.
DShelbyD
Re: GnuCash failure
I see new updates including guile and gnucash, but dependency issues are numerous, so many of the updates fail, including those for GnuCash. I thought it might be a problem with syncing the repository, but after waiting overnight, the issues remain. Tried switching to wget from aria2, but it did not help.
Re: GnuCash failure
Yes there were some minor issues on ABF, which are fixed now, but the error will remain on the mirrors for some time. Please wait a little :)
DShelbyD
Re: GnuCash failure
Thank you.
DShelbyD
Re: GnuCash failure [SOLVED]
Updates completed just now, and GnuCash works perfectly.
Thread marked "solved." Thank you!
David
