Rosa 2012.1 problems
bvbfan
Operating system: Rosa 2014.1
Сообщение bvbfan »
Hi there, i'm using Rosa 2012.1 since first alpha and everything works perfect till kernels 3.6.x and kde 4.9.4. About new kernel cpupower service and kernel variables can't start.
UNIT                   LOAD   ACTIVE SUB    JOB DESCRIPTION
atd.service                       loaded failed failed     Job spooling tools
atieventsd.service            loaded failed failed     LSB: ATI Events Daemon
cpupower.service             loaded failed failed     Configure CPU power related settings
networkmanager.service loaded failed failed     LSB: Daemon for automatically switching to best network connection.
systemd-sysctl.service   loaded failed failed     Apply Kernel Variables
cpupower info
System's multi core scheduler setting: not supported
System's thread sibling scheduler setting: not supported
System does not support Intel's performance bias setting
analyzing CPU 0:
CPU is AMD APU E350.
Last QtWebkit not work with rekonq HTML5, WebGL not working.
rpm -qa | grep webkit
python-qt4-webkit-4.9.4-1-rosa2012.1.i586
libwebkitgtk1.0_0-1.10.0-4-rosa2012.1.i586
webkit1.0-1.10.0-4-rosa2012.1.i586
webkit1.0-webinspector-1.10.0-4-rosa2012.1.i586
libqtwebkit4-4.8.4-1-rosa2012.1.i586
libkdewebkit5-4.9.4-1-rosa2012.1.i586
libsmokeqtwebkit3-4.9.4-2-rosa2012.1.i586
Ty for your suggestions.
akdengi
Re: Rosa 2012.1 problems
Сообщение akdengi »
bvbfan писал(а):Hi there, i'm using Rosa 2012.1 since first alpha and everything works perfect till kernels 3.6.x and kde 4.9.4. About new kernel cpupower service and kernel variables can't start.
cpupower info
analyzing CPU 0:
cpupower not need because ondemand governor enabled by default. See cpupower frequency-info
If not, uncomment /etc/sysconfig/cpupower string
# CPUPOWER_START_OPTS="frequency-set -g performance"
# CPUPOWER_STOP_OPTS="frequency-set -g ondemand"
and set needing governor...
For some AMD GPU and P4 processors need install powernowd
urpmi powernowd
and reboot
bvbfan
Сообщение bvbfan »
Ty, akdengi, what about kernel variables and QtWebkit, still no solution :)
akdengi
Сообщение akdengi »
All bugs will be resolved after release in updates - it's not system-broken, but system-user-output-horror :) like cpupower and atd with networkmanager
For QT please add bug to Bugzilla - in forum maintainer may not be present..
bvbfan
Сообщение bvbfan »
OK, ty again. I was using Mandriva since 2009 in all stable and cooker versions till last completely broken cooker and was very surprised to see Rosa like Mandriva continuers. The Distro is simple, beautiful, powerful, useful and most user-friendly, ty to developers for this good work. :beer:
bvbfan писал(а):OK, ty again. I was using Mandriva since 2009 in all stable and cooker versions till last completely broken cooker and was very surprised to see Rosa like Mandriva continuers. The Distro is simple, beautiful, powerful, useful and most user-friendly, ty to developers for this good work. :beer:
Thank you very much for your kind words :beer: and for using ROSA :)
bvbfan писал(а):Ty, akdengi, what about kernel variables and QtWebkit, still no solution :)
http://bugs.rosalinux.ru/show_bug.cgi?id=1274
bvbfan
Сообщение bvbfan »
I can notice strange cursor changes. In KDM cursor is Rosa, when KDE loading cursor is changed to my choose and then again reset to ROSA. When start KDE application like Dolphin cursor again is my choose. In some situation looks between ROSA and my choose, happen with every choose. My ~/.kde4/share/config/kcminputrc is
[Keyboard]
ClickVolume=0
KeyboardRepeating=0
NumLock=2
RepeatDelay=660
RepeatRate=25
[Mouse]
Acceleration=2
MouseButtonMapping=RightHanded
ReverseScrollPolarity=false
Threshold=4
cursorSize=0
cursorTheme=win8
bvbfan
Сообщение bvbfan »
One strange bug from kde 4.9.4 till now 4.9.5 with flicker display instead of dimming -> https://bugs.kde.org/show_bug.cgi?id=311480 it's sill no fixed? When plasma will be updated?
akdengi
Сообщение akdengi »
bvbfan писал(а):One strange bug from kde 4.9.4 till now 4.9.5 with flicker display instead of dimming -> https://bugs.kde.org/show_bug.cgi?id=311480 it's sill no fixed? When plasma will be updated?
Due this upstream bug - question will need be place in KDE bugzilla... Also you may try disable brightness change in Power mode control.
