[not possible] Update Rosa Marathon 2012 Rosa Desktop 2012.1
rjadot
Operating system: Rosa desktop 2012 Marathon
Сообщение rjadot »
Is ther a way to make an update from rosa 2012 Marathon to the beta of 2012.1 ?
I did not find documentation
Последний раз редактировалось rjadot 12 ноя 2012, 20:50, всего редактировалось 1 раз.
Re: Update Rosa Marathon 2012 Rosa Desktop 2012.1 Beta
No. The only way is to install it from scratch. The code difference is too big.
rjadot
Сообщение rjadot »
Aaaargh :%) :cry:
But the lazy people like me, they're condemned :pardon:
Don't you want to jump quickly in France and make my installation ? :-)
Ok ok, let's start dd_rescue Haha!
akdengi
Re: [not possible] Update Rosa Marathon 2012 Rosa Desktop 20
Сообщение akdengi »
You may try (it's real), but...
1. You need manually resolved all conflicts
2. You may broke you system (really) - some system part is moving to another, some droped...
3. You need manually delete old config and add newest
4. You need setup sudo...
and etc...
If it's really need for you? Reinstall system is more quickly... Not format /home and you may have really fresh system (but we recomend delete .kde4 dir and setup for new).
