[SOLVED]Can't reboot after installation
matfx
Operating system: Rosa Desktop Fresh 2012 R2
Сообщение matfx »
I have successful installed Rosa Marathon 2012 EE but the problem is after reboot it can boot into Rosa desktop, all i have is black screen.
What should i do?
Pentium Dual Core E5400 4GB Ram Asus R7 240 2GB DDR3 Rosa Desktop Fresh R7 64bit
matfx
Re: Can't reboot after installation
Сообщение matfx »
Forgot to mention i am dual boot Rosa Marathon 2012 with windows 7.
matfx писал(а):windows 7.
Yes that's very important detail. Did you see the GRUB menu at all?
If not, you should insert Windows7 installation media and restore the loader, at least.
matfx
Сообщение matfx »
After installed, i make the reboot. Upon reboot, i can see the Rosa marathon grub (i install the Rosa grub on mbr). Then it shows the Rosa grey boot screen, after a few seconds then went to black screen. Tried to reinstall again but still facing the same problem.
Most likely a problem with the video card. When you see the grey screen Grub try select "....(safe mode)" and run the system in this mode.
matfx
Сообщение matfx »
Hi PastorDi,
Thanks for the comment. I also have the same thought that it is my ATI graphic card can't be recognize by Rosa Lnux.
Vegatron
Operating system: Rosa Linux 2012 Marathon
Сообщение Vegatron »
try adding nomodeset to your grub boot string.
If system boots ok, then you can try using fglrx proprietary driver from rosa non-free repo. Install it and then choose with XFdrake.
matfx
Сообщение matfx »
Sorry to ask, but how to insert nomodeset?
After booting in GRUB menu press F3 and append nomodeset (at the end of the string)
Then hit Enter
matfx
Сообщение matfx »
Thank you for the info. Now i can boot into Rosa desktop. Download the non-free graphic cards driver and everything solved.
ferri
Сообщение ferri »
matfx писал(а):Download the non-free graphic cards driver and everything solved.
I have ATI Mobility Radeon. Can you give here some more details, please? :)
Вернуться в «Marathon (ROSA LTS)»
