Update/Upgrade problem. Help needed...
Draguljche
Operating system: ROSA Fresh Desktop 13.0 (fresh-desktop) x86_64
Сообщение Draguljche »
When I go in update_applet when Updates are available I got this error:
==> Update repositories
kernel 6.7-6.y.10 with XanMod patch 12 kB/s | 3.3 kB 00:00
kernel with XanMod patch 12 kB/s | 3.3 kB 00:00
victorr2007_personal repo 12 kB/s | 3.3 kB 00:00
x11_backports repo 12 kB/s | 3.3 kB 00:00
ROSA 13 - x86_64 - Contrib - Test Updates 23 kB/s | 3.3 kB 00:00
ROSA 13 - x86_64 - Contrib 12 kB/s | 3.4 kB 00:00
ROSA 13 - x86_64 - Main 12 kB/s | 3.4 kB 00:00
ROSA 13 - x86_64 - Non-free - Test Updates 24 kB/s | 3.3 kB 00:00
ROSA 13 - x86_64 - Non-free 24 kB/s | 3.3 kB 00:00
ROSA 13 - i686 - Contrib 24 kB/s | 3.3 kB 00:00
ROSA 13 - i686 - Contrib - Test Updates 24 kB/s | 3.3 kB 00:00
ROSA 13 - i686 - Non-free 24 kB/s | 3.3 kB 00:00
ROSA 13 - i686 - Non-free - Test Updates 24 kB/s | 3.3 kB 00:00
Metadata cache created.
==> Check updates
==> Packages that need to be updated:
Last metadata expiration check: 0:00:03 ago on nedjelja, 16. studenoga 2025. 16:18:20 CET.
Error:
 Problem 1: package kernel-modules-nvidia580-proprietary-6.17-generic-580.95-99220895.76.7f619.x86_64 from @System conflicts with kmod-nvidia580-kabi(6.17.7-generic-1rosa13-x86_64)-type < proprietary provided by kernel-modules-nvidia580-open-6.17-generic-3:580.105-99596980.78.0af41.x86_64 from nvidia-x86_64
  - package kernel-modules-nvidia580-open-6.17-generic-3:580.105-99596980.78.0af41.x86_64 from nvidia-x86_64 conflicts with kmod-nvidia580-kabi(6.17.7-generic-1rosa13-x86_64)-type > open provided by kernel-modules-nvidia580-proprietary-6.17-generic-580.95-99220895.76.7f619.x86_64 from @System
  - cannot install the best update candidate for package kernel-modules-nvidia580-open-6.17-generic-580.105-100168402.53.7f619.x86_64
  - problem with installed package kernel-modules-nvidia580-proprietary-6.17-generic-580.95-99220895.76.7f619.x86_64
 Problem 2: package kernel-modules-nvidia580-proprietary-6.12-generic-3:580.105-99596980.78.0af41.x86_64 from @System conflicts with kmod-nvidia580-kabi(6.12.47-generic-2rosa13-x86_64)-type < proprietary provided by kernel-modules-nvidia580-open-6.12-generic-3:580.105-99596980.78.0af41.x86_64 from nvidia-x86_64
  - package kernel-modules-nvidia580-open-6.12-generic-3:580.105-99596980.78.0af41.x86_64 from nvidia-x86_64 conflicts with kmod-nvidia580-kabi(6.12.47-generic-2rosa13-x86_64)-type > open provided by kernel-modules-nvidia580-proprietary-6.12-generic-3:580.105-99596980.78.0af41.x86_64 from @System
  - cannot install the best update candidate for package kernel-modules-nvidia580-proprietary-6.12-generic-3:580.105-99596980.78.0af41.x86_64
  - cannot install the best update candidate for package kernel-modules-nvidia580-open-6.12-generic-1:580.95-99585298.71.0af41.x86_64
 Problem 3: package plasma6-skanpage-25.04.3-1.x86_64 from @System requires libtesseract.so.5.3.4()(64bit), but none of the providers can be installed
  - cannot install both lib64tesseract5-5.5.1-1.x86_64 from nvidia-x86_64 and lib64tesseract5-5.3.4-1.x86_64 from @System
  - cannot install both lib64tesseract5-5.3.4-1.x86_64 from mirror-rosa-x86_64-main and lib64tesseract5-5.5.1-1.x86_64 from nvidia-x86_64
  - cannot install the best update candidate for package plasma6-skanpage-25.04.3-1.x86_64
  - cannot install the best update candidate for package lib64tesseract5-5.3.4-1.x86_64
 Problem 4: problem with installed package plasma6-skanpage-25.04.3-1.x86_64
  - package plasma6-skanpage-25.04.3-1.x86_64 from @System requires libtesseract.so.5.3.4()(64bit), but none of the providers can be installed
  - package plasma6-skanpage-25.04.3-1.x86_64 from mirror-rosa-x86_64-main requires libtesseract.so.5.3.4()(64bit), but none of the providers can be installed
  - package lib64gs10-10.05.1-3.x86_64 from nvidia-x86_64 requires libtesseract.so.5.5()(64bit), but none of the providers can be installed
  - cannot install the best update candidate for package lib64gs10-10.05.1-2.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
How to fix this, I need Nvidia drivers. And hop from 6.17.8-generic-1rosa13-x86_64 to Xanmod kernel?
System info:
Operating System: ROSA Fresh Desktop 13
KDE Plasma Version: 6.4.5
KDE Frameworks Version: 6.18.0
Qt Version: 6.8.3
Kernel Version: 6.17.8-generic-1rosa13-x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 2700X Eight-Core Processor
Memory: 16 GiB of RAM (15,5 GiB usable)
Graphics Processor: NVIDIA GeForce GTX 1080
Edit: BTW I use Proprietary drivers.
bestcat75
Re: Update/Upgrade problem. Help needed...
Сообщение bestcat75 »
Такая же проблема, видюха 1070 ti, стоят проприетарные драйвера, зачем мне при обнове пытаются поставиться открытые?? Вроде бы как открытые для 5хххх серии и выше, 10ххх серию они не поддерживают, или я в чем то ошибаюсь?
Draguljche
Hello! Nvidia-proprietary does support GTX1xxx series Nvidia-Open support from GTX16xx and RTX and most recent GPUs. So update should not try to install Open drivers when you use Nvidia-Proprietary. BTW I dont have any of Open packages installed. There others packages to update and error is simillar.
Edit: I tried this to and here is error:
┬─[stefanm@Starchild:~]─[17:51:41]
╰─>$ sudo dnf distro-sync --refresh --allowerasing
[sudo] password for stefanm:
victorr2007_personal repo        11 kB/s | 3.3 kB     00:00
ROSA 13 - x86_64 - Contrib - Test Updates                                                      12 kB/s | 3.3 kB     00:00
ROSA 13 - x86_64 - Non-free - Test Updates                                                     23 kB/s | 3.3 kB     00:00
ROSA 13 - x86_64 - Non-free        12 kB/s | 3.3 kB     00:00
ROSA 13 - i686 - Contrib        12 kB/s | 3.3 kB     00:00
ROSA 13 - i686 - Contrib - Test Updates                                                        12 kB/s | 3.3 kB     00:00
ROSA 13 - i686 - Non-free        12 kB/s | 3.3 kB     00:00
ROSA 13 - i686 - Non-free - Test Updates                                                       12 kB/s | 3.3 kB     00:00
Error:
 Problem: problem with installed package kernel-modules-nvidia580-open-6.17-generic-580.105-100168402.53.7f619.x86_64
  - nothing provides kernel-abi(6.17.7-generic-1rosa13-x86_64) needed by kernel-modules-nvidia580-open-6.17-generic-3:580.105-99596980.78.0af41.x86_64 from nvidia-x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
Draguljche писал(а): 16 ноя 2025, 18:24 When I go in update_applet when Updates are available I got this error:
Убрал из своего репозитория пакет tesseract-5.5.1.
Теперь не должно быть ошибки.
perfectsense
Сообщение perfectsense »
Вот такая ошибка уже несколько дней:
sudo dnf5 distro-sync --refresh
Обновление и загрузка репозиториев:
 ROSA 13 - x86_64 - Contrib - Test Updates        100% |   4.4 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - x86_64 - Main - Test Updates        100% |   4.1 KiB/s |   3.4 KiB |  00m01s
 ROSA 13 - x86_64 - Contrib        100% |   5.5 KiB/s |   3.4 KiB |  00m01s
 ROSA 13 - x86_64 - Main        100% |   5.5 KiB/s |   3.4 KiB |  00m01s
 ROSA 13 - x86_64 - Non-free - Test Updates        100% |   4.6 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - x86_64 - Non-free        100% |   5.4 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - i686 - Contrib        100% |   5.4 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - i686 - Main - Test Updates        100% |   4.7 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - i686 - Contrib - Test Updates        100% |   5.4 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - i686 - Main        100% |   5.5 KiB/s |   3.4 KiB |  00m01s
 ROSA 13 - i686 - Non-free        100% |   4.1 KiB/s |   3.3 KiB |  00m01s
 ROSA 13 - i686 - Non-free - Test Updates        100% |   5.4 KiB/s |   3.3 KiB |  00m01s
 google-chrome        100% |   2.2 KiB/s |   1.3 KiB |  00m01s
 kde6        100% |   4.4 KiB/s |   3.4 KiB |  00m01s
 kernel        100% |   2.6 KiB/s |   3.3 KiB |  00m01s
Репозитории загружены.
Не удалось разрешить транзакцию:
Проблема: Не удается установить лучшего кандидата на обновление для пакета kernel-modules-nvidia580-proprietary-6.17-generic-580.105-100387600.66.7f619.x86_64
  - ничто не предоставляет kernel-abi(6.17.7-generic-1rosa13-x86_64), необходимый для kernel-modules-nvidia580-proprietary-6.17-generic-3:580.105-99596980.78.0af41.x86_64 из kernel
Можно попробовать добавить в командную строку:
  --no-best, чтобы не ограничивать транзакцию лучшими кандидатами
  --skip-broken, чтобы пропустить неустанавливаемые пакеты
Поправил пакеты в своих репах.
Draguljche
Ok, Hi. First update was succesful this morning, but now another update came, and here is error when I open Update_Applet:
==> Check updates
Last metadata expiration check: 0:00:03 ago on ponedjeljak, 17. studenoga 2025. 19:27:09 CET.
Error:
 Problem: cannot install the best update candidate for package kernel-modules-nvidia580-proprietary-6.17-generic-580.105-100387600.66.7f619.x86_64
  - nothing provides kernel-abi(6.17.8-generic-3rosa13-x86_64) needed by kernel-modules-nvidia580-proprietary-6.17-generic-4:580.105-100437556.86.0af41.x86_64 from nvidia-x86_64
EDIT: The error with sudo dnf distro-sync --refresh --allowerasing, before that command I used: sudo dnf clean all ; dnf clean all ; dnf repolist:
┬─[stefanm@Starchild:~]─[19:28:43]
kernel 6.7-6.y.10 with XanMod patch                                                           2.1 MB/s | 3.2 MB     00:01
kernel with XanMod patch        363 kB/s | 373 kB     00:01
victorr2007_personal repo        526 kB/s | 600 kB     00:01
x11_backports repo        11 kB/s | 3.3 kB     00:00
ROSA 13 - x86_64 - Contrib - Test Updates                                                     5.0 kB/s | 3.4 kB     00:00
ROSA 13 - x86_64 - Contrib        15 MB/s |  37 MB     00:02
ROSA 13 - x86_64 - Main        13 MB/s |  28 MB     00:02
ROSA 13 - x86_64 - Non-free - Test Updates                                                    1.3 kB/s | 531  B     00:00
ROSA 13 - x86_64 - Non-free        367 kB/s | 346 kB     00:00
ROSA 13 - i686 - Contrib        206 kB/s | 182 kB     00:00
ROSA 13 - i686 - Non-free        28 kB/s |  19 kB     00:00
Error:
  - problem with installed package kernel-modules-nvidia580-proprietary-6.17-generic-580.105-100387600.66.7f619.x86_64
max-sever
Сообщение max-sever »
Чет день сегодня какой-то.... Не задался, в общем.
==> Обновление метаданных
ROSA 13 - x86_64 - Contrib 19 kB/s | 3.4 kB 00:00
ROSA 13 - x86_64 - Main 22 kB/s | 3.4 kB 00:00
ROSA 13 - x86_64 - Non-free 22 kB/s | 3.3 kB 00:00
ROSA 13 - i686 - Contrib 16 kB/s | 3.3 kB 00:00
ROSA 13 - i686 - Main 16 kB/s | 3.4 kB 00:00
ROSA 13 - i686 - Non-free 19 kB/s | 3.3 kB 00:00
Yandex 10 kB/s | 3.0 kB 00:00
Создан кэш метаданных.
==> Проверка наличия обновлений
==> Пакеты, требующие обновления:
Последняя проверка окончания срока действия метаданных: 0:00:01 назад, Пн 17 ноя 2025 22:16:34.
Ошибка:
 Проблема: dconf-gio-modules-0.40.0-22.i686 from @System  does not belong to a distupgrade repository
  - cannot install both dconf-gio-modules-0.49.0-2.x86_64 from mirror-rosa-x86_64-main and dconf-gio-modules-0.40.0-22.x86_64 from @System
  - cannot install the best update candidate for package dconf-gio-modules-0.40.0-22.i686
  - cannot install the best update candidate for package dconf-gio-modules-0.40.0-22.x86_64
Draguljche писал(а): 17 ноя 2025, 21:28 Ok, Hi. First update was succesful this morning, but now another update came, and here is error when I open Update_Applet:
Попробуйте ещё раз. :)
Draguljche
VictorR2007 писал(а): 17 ноя 2025, 22:29
Thx, Update was succesfull. One more question. Plasma Discover doesnt notify about Flatpak updates. How to fix it?
bestcat75
Это же обновление, проблема - писал выше
bestcat75 писал(а): 18 ноя 2025, 07:42 Это же обновление, проблема - писал выше
sudo dnf remove kmod-nvidia580
nvidia module already build with kernel
create new theme for this trouble.
Draguljche
[/quote]
Hi Thanx. I fixed it by installing package plasma6-applet-discovernotifier. Maybe this should be a dependency for installing plasma6-discover.
Похоже у вас есть уже установленный
kernel-modules-nvidia580-open-6.17-generic.
И из-за него не может установиться пакет
kernel-modules-nvidia580-proprietary-6.16-generic.
Нужно сделать замену модулей
sudo dnf --allowerasing swap nvidia580-open-kernel-modules nvidia580-proprietary-kernel-modules
Draguljche писал(а): 18 ноя 2025, 09:34 Hi Thanx. I fixed it by installing package plasma6-applet-discovernotifier. Maybe this should be a dependency for installing plasma6-discover.
Нет, так не нужно делать.
У нас discover и установка пакетов flatpak не используются по умолчанию.
Для сообщений об обновлениях используется
rosa-update-system.
Два виджета о доступных обновлениях нам не нужны.
Если кому-то нужен plasma6-applet-discovernotifier,
он может его установить сам вручную.
Draguljche
I am talking about Flatpaks. Discover is a Gui for Flatpaks. It works. rosa-update doesnt update flatpaks.
Draguljche писал(а): 18 ноя 2025, 17:20 I am talking about Flatpaks. Discover is a Gui for Flatpaks. It works. rosa-update doesnt update flatpaks.
Я вас понял.
Если вам нужно, чтобы в системном лотке работал discover, то конечно нужно устанавливать пакет
Но устанавливать его в систему по умолчанию не будем.
И в зависимости не будем добавлять.
Если кому-то понадобится, он сможет установить вручную.
