Plasma6 hangs when copying single image from Gwenview
erfan
Operating system: Rosa Fresh 13 Plasma 6
Сообщение erfan »
Hello again! :)
When copying a single image from gwenview, plasma6 desktop hangs for 15-20 seconds on my brand new Lenovo Ideapad 5. This hanging is present running the Rosa Fresh 13 plasma iso too, and happens on other laptop too, on a one year old DELL Vostro (around 5 seconds hanging).
The hanging is caused by the plasma6 clipboard manager. If I disable it completely, there is no hanging.
It seems to happen only with gwenview, only with one single image, and bigger images – several MB big, and 10+ MP large – while generating it's thumbnail. And many times thumbnail is not generated, but some kind of text file??? and after it appears a +34 567 or other huge number, like I would have copied thousands of files.
If multiple images are selected from gwenview, there is no problem. And copying image from dolphin also is no problem, thumbnail is generated without any issue.
I have tried to set the plasma6 clipboard manager to manage only texts, but was not possible, the settings are not working.
Also tried the xfce clipboard manager on plasma6 desktop. It also has problems when generating one single thumbnail in the clipboard.
As a temporary solution I use clipit, as textonly clipboard manager, but I hope to find a solution to reenable plasma6 built-in clipboard manager.
Re: Plasma6 hangs when copying single image from Gwenview
Где-то в сообщениях в git kde, видел что то ли уже это исправили, то ли пока на стадии исправления.
erfan
Сообщение erfan »
I don't know where to look, but it is not solved on 6.4.5. Also checked on the ROSA_13_PLASMA6_x86_64_7701.iso the 6.5 Beta 2 do not solves it.
Because of the continuous problems with external displays on X11, I am using now Wayland, to see if it works better with external displays. But plasma clipboard manager behaves the same. Hangs when copying single image from gwenview. Also the setting to text-only mode does not work.
The problem which I am facing now is that ClipIt (which I found to work conveniently for text-only on X11) seems to not work on Wayland. It starts up normally and could read de data recorded on X11, but do not records anything on Wayland. And did not find in the repository any working replacement. So for now I work completely without clipboard manager.
Any solution to make plasma 6 clipboard manager to work in text-only mode? Because the built-in setting has no effect. Or
Make ClipIt to work on Wayland? Or
An other clipboard manager?
erfan писал(а): 24 окт 2025, 10:12 I don't know where to look
Вот этот вроде похож: https://bugs.kde.org/show_bug.cgi?id=490952
erfan
Сообщение erfan »
Thank you for the suggestion, but I do not think it is related, because with small images, like a screenshot, there is no observable lag.
It seems that if nomacs is used, there is no problem copying the image.
But plasma 6 klipper seems to have many other problems too. If I choose text only mode, strangely it saves images and will create thumbnails without problems from dolphin or nomacs, and with problems from gwenview, but from other apps, like libreoffice, gimp, inkscape, do not copy images. IF image mode is choosen, than klipper tries to save images from other apps too, but without succes, resulting nothing, or after a lag resulting into an unusable empty line in clipboard manager.
Still searching for a working clipboard manager on wayland.
erfan писал(а): 05 ноя 2025, 12:25 Still searching for a working clipboard manager on wayland.
Вряд ли такой имеется. Создайте баг-репорт с вашей проблемой на https://bugs.kde.org
erfan
Сообщение erfan »
That's what I intend to do.
Вернуться в «Desktop»
