Today I noticed that CPU usage at after start up of KDE, while the computer is doing nothing, was close to 100%. To analyze this I added a new user and did not make any changes to the standard KDE/Rosa desktop. CPU usage was around 4%. As soon as I made some changes in KDE configuration the usage grew to around 14%, the computer doing nothing. The more changes I make, the higher is the CPU usage. It is plasma-desktop that uses the many CPU cycles.
There must be some incompatibility between KDE and the Rosa theme.
Greetings,
E. J. van Waasdijk.
Customized KDE causes high CPU usage
ejvwaasdijk
ejvwaasdijk
Re: Customized KDE causes high CPU usage
I did some experiments these days and found that customizing KDE does not cause problems as long as the theme "oxygen" is not used. "Oxygen" was the theme that I used in Mandriva 2010.2 without any problem. So my suggestion is that there is some incompatibility between the theme "oxygen" and KDE with Rosa. On Mageia 2 there are no problems at all with "oxygen".
I tried Rosa Marathon EE because of its promised long term support, but I find some things wanting, especially in the repositories. There is no XFCE for instance, and very few games. Is there a reason for this?
I hope you will update Libreoffice, because version 3.4 does not handle footnotes well.
Greetings,
Erik.
Greetings,
Erik.
