Failsafe does not work
Non-Desktop related topics
ejvwaasdijk
Сообщение ejvwaasdijk »
Yesterday I installed Rosa Marathon. The insstall progrma does not read the names in the Home diriceory likke Mandriva did. So I got the wrong name. I tried to cange this, but messed things. I could no longer start KDE. Some files were not writeable. So I started "failsafe". This option looked like "linux-nonfb" and did not end with a login screen in text format, but tried to start KDE that did not work. So the whole "failsafe" turned out to be useless. To remedy this problem I did another clean install with a formatted home partition. (Long live Backup dirives togehter with Ubuntu live CDl!!! The Rosa live option was too slow to be useable.)
I hope these problems will be remedied soon. After all this is a LTS version!
Greetings,
E. J. van Waasdijk.
Re: Failsafe does not work
What on the equipment you started ROSA2012LTS?
ejvwaasdijk
Dear PastorDi,
thank you for your reply. It is not clear to me what you want to know. English is my second language. I you mean my hardware:
[root@localhost ~]# lshw
localhost.localdomain
description: Desktop Computer
product: System Product Name (To Be Filled By O.E.M.)
vendor: System manufacturer
version: System Version
serial: System Serial Number
width: 32 bits
capabilities: smbios-2.5 dmi-2.5 smp-1.4 smp
configuration: boot=normal chassis=desktop cpus=1 family=To Be Filled By O.E.M. sku=To Be Filled By O.E.M. uuid=E06A314D-71B8-DD11-9FD2-002354CDCE0D
*-core
description: Motherboard
product: P5KPL-AM SE
vendor: ASUSTeK Computer INC.
physical id: 0
version: X.0x
serial: MT708BK05520594
slot: To Be Filled By O.E.M.
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 0311
date: 10/30/2008
capacity: 960KiB
capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
*-cpu
description: CPU
product: Intel(R) Pentium(R) 4 CPU 3.00GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 15.3.4
serial: 0000-0F34-0000-0000-0000-0000
slot: Socket 775
capacity: 3800MHz
width: 32 bits
clock: 200MHz
capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe constant_tsc pebs bts pni dtes64 monitor ds_cpl cid xtpr
configuration: id=1
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 16KiB
capabilities: internal write-back data
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 1MiB
capabilities: internal write-back unified
*-logicalcpu:0
description: Logical CPU
physical id: 1.1
width: 32 bits
capabilities: logical
*-logicalcpu:1
physical id: 1.2
width: 32 bits
*-memory
description: System Memory
physical id: 23
slot: System board or motherboard
*-bank:0
description: DIMM DDR2 Synchronous 667 MHz (1,5 ns)
product: PartNum0
vendor: Manufacturer0
physical id: 0
serial: SerNum0
slot: DIMM A1
width: 64 bits
clock: 667MHz (1.5ns)
*-bank:1
description: DIMM [empty]
product: PartNum1
vendor: Manufacturer1
physical id: 1
serial: SerNum1
slot: DIMM B1
*-pci
description: Host bridge
product: 82G33/G31/P35/P31 Express DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 10
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: 82G33/G31/P35/P31 Express PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 10
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:40 ioport:d000(size=4096) memory:fd000000-feafffff ioport:de000000(size=301989888)
*-display
description: VGA compatible controller
product: GT218 [GeForce 210]
vendor: nVidia Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:16 memory:fd000000-fdffffff memory:e0000000-efffffff memory:de000000-dfffffff ioport:dc00(size=128) memory:fea00000-fea7ffff
*-multimedia
description: Audio device
product: High Definition Audio Controller
physical id: 0.1
bus info: pci@0000:01:00.1
version: a1
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0
resources: irq:16 memory:feafc000-feafffff
*-multimedia
product: N10/ICH 7 Family High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 01
width: 64 bits
clock: 33MHz
resources: irq:44 memory:fcffc000-fcffffff
*-pci:1
product: N10/ICH 7 Family PCI Express Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:41 ioport:1000(size=4096) memory:40000000-401fffff ioport:40200000(size=2097152)
*-pci:2
product: N10/ICH 7 Family PCI Express Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: 01
width: 32 bits
clock: 33MHz
resources: irq:42 ioport:e000(size=4096) memory:feb00000-febfffff ioport:fbf00000(size=1048576)
*-network
description: Ethernet interface
product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 02
serial: 00:23:54:cd:ce:0d
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=N/A ip=192.168.178.30 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:43 ioport:e800(size=256) memory:fbfff000-fbffffff memory:fbfe0000-fbfeffff memory:febf0000-febfffff
*-usb:0
description: USB controller
product: N10/ICH 7 Family USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0
resources: irq:23 ioport:c480(size=32)
*-usb:1
product: N10/ICH 7 Family USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 01
width: 32 bits
clock: 33MHz
resources: irq:19 ioport:c800(size=32)
*-usb:2
product: N10/ICH 7 Family USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 01
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:c880(size=32)
*-usb:3
product: N10/ICH 7 Family USB UHCI Controller #4
physical id: 1d.3
bus info: pci@0000:00:1d.3
version: 01
width: 32 bits
clock: 33MHz
resources: irq:16 ioport:cc00(size=32)
*-usb:4
product: N10/ICH 7 Family USB2 EHCI Controller
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci_hcd latency=0
resources: irq:23 memory:fcffbc00-fcffbfff
*-pci:3
product: 82801 PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: e1
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
*-isa
description: ISA bridge
product: 82801GB/GR (ICH7 Family) LPC Interface Bridge
physical id: 1f
bus info: pci@0000:00:1f.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: latency=0
*-ide:0
description: IDE interface
product: 82801G (ICH7 Family) IDE Controller
physical id: 1f.1
bus info: pci@0000:00:1f.1
logical name: scsi0
version: 01
width: 32 bits
clock: 33MHz
capabilities: ide bus_master emulated
configuration: driver=ata_piix latency=0
resources: irq:18 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ffa0(size=16)
*-cdrom
description: DVD-RAM writer
product: CDDVDW SH-S222A
vendor: TSSTcorp
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/cdrom
logical name: /dev/scd0
logical name: /dev/sr0
version: SB02
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
*-ide:1
product: N10/ICH7 Family SATA Controller [IDE mode]
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi2
version: 01
width: 32 bits
clock: 66MHz
capabilities: ide pm bus_master cap_list emulated
resources: irq:19 ioport:c400(size=8) ioport:c080(size=4) ioport:c000(size=8) ioport:bc00(size=4) ioport:b880(size=16)
*-disk
description: ATA Disk
product: WDC WD3200JD-22K
vendor: Western Digital
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sda
version: 08.0
serial: WD-WCAMR1773383
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=1f63fb2c
*-volume:0
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@2:0.0.0,1
logical name: /dev/sda1
version: 1.0
serial: bd58f911-ab43-4c12-948c-31d701f1dd50
capacity: 9538MiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
configuration: created=2012-04-27 17:05:21 filesystem=ext4 lastmountpoint=/ modified=2012-05-30 01:15:10 mounted=2012-05-30 01:17:58 state=clean
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@2:0.0.0,2
logical name: /dev/sda2
capacity: 238GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume:0
description: Linux swap / Solaris partition
physical id: 5
logical name: /dev/sda5
capacity: 1906MiB
capabilities: nofs
*-logicalvolume:1
description: Linux filesystem partition
physical id: 6
logical name: /dev/sda6
capacity: 27GiB
*-logicalvolume:2
physical id: 7
logical name: /dev/sda7
capacity: 9993MiB
*-logicalvolume:3
physical id: 8
logical name: /dev/sda8
capacity: 48GiB
*-logicalvolume:4
physical id: 9
logical name: /dev/sda9
capacity: 9536MiB
*-logicalvolume:5
physical id: a
logical name: /dev/sda10
capacity: 37GiB
*-logicalvolume:6
physical id: b
logical name: /dev/sda11
capacity: 13GiB
*-logicalvolume:7
physical id: c
logical name: /dev/sda12
capacity: 26GiB
*-logicalvolume:8
physical id: d
logical name: /dev/sda13
logical name: /
capacity: 14GiB
configuration: mount.fstype=ext4 mount.options=rw,relatime,user_xattr,acl,barrier=1,data=ordered state=mounted
*-logicalvolume:9
physical id: e
logical name: /dev/sda14
logical name: /home
capacity: 31GiB
*-serial
description: SMBus
product: N10/ICH 7 Family SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 01
width: 32 bits
clock: 33MHz
configuration: driver=i801_smbus latency=0
resources: irq:19 ioport:400(size=32)
*-scsi
physical id: 1
bus info: usb@5:8
logical name: scsi4
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
physical id: 0.0.0
bus info: scsi@4:0.0.0
logical name: /dev/sdb
*-network
description: Wireless interface
physical id: 1
bus info: usb@5:2
logical name: wlan0
serial: 00:0e:2e:f1:38:c0
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rt73usb driverversion=3.0.28-nrj-desktop-2rosa.lts firmware=1.7 link=no multicast=yes wireless=IEEE 802.11bg
[root@localhost ~]#
I do not know what is relevant, and what not.
As for the menu.lst, at installation I got this:
title linux
kernel (hd0,12)/boot/vmlinuz BOOT_IMAGE=linux root=UUID=5882d78f-1f77-44ba-b256-2405f2176225 nokmsboot logo.nologo quiet resume=UUID=9c1ff77a-d90e-4bbd-be22-6812e86b4331 splash=silent vga=788
root (hd0,12)
initrd /boot/initrd.img
title linux-nonfb
kernel (hd0,12)/boot/vmlinuz BOOT_IMAGE=linux-nonfb root=UUID=5882d78f-1f77-44ba-b256-2405f2176225 nokmsboot resume=UUID=9c1ff77a-d90e-4bbd-be22-6812e86b4331
root (hd0,12)
title failsafe
kernel (hd0,12)/boot/vmlinuz BOOT_IMAGE=failsafe root=UUID=5882d78f-1f77-44ba-b256-2405f2176225 nokmsboot failsafe
root (hd0,12)
I hope you can find out what is wrong.
Greetings,
Erik Jan.
