Сломался Akonadi
Сломался Akonadi
Стоит самая новая Rosa R1x c обновлением из Kde5_backports.
Настроил Kmail на работу с почтовым ящиком Gmail. При попытке загрузки содержимого почты, т.е. при нажатии кнопки "Проверить почту" спустя несколько секунд валится ошибка akonadi_imap_resource. В логах такое:
QObject::killTimer: Timers cannot be stopped from another thread
org.kde.pim.akonadicore: not referenced  13
[SASL-XOAUTH2] - Requesting authID![SASL-XOAUTH2] - Requesting token
![SASL-XOAUTH2] - filling prompts
![SASL-XOAUTH2] - Requesting authID![SASL-XOAUTH2] - Requesting token
!org.kde.pim.kidentitymanagement: IdentityManager: There was no default identity. Marking first one as default.
!Tokenizer Warning: 8Bit character ' -47 '
Tokenizer Warning: 8Bit character ' -21 '
Tokenizer Warning: 8Bit character ' -13 '
Tokenizer Warning: 8Bit character ' -26 '
Tokenizer Warning: 8Bit character ' -31 '
Tokenizer Warning: 8Bit character ' -32 '
Tokenizer Warning: 8Bit character ' -17 '
Tokenizer Warning: 8Bit character ' -18 '
Tokenizer Warning: 8Bit character ' -28 '
Tokenizer Warning: 8Bit character ' -27 '
Tokenizer Warning: 8Bit character ' -16 '
Tokenizer Warning: 8Bit character ' -22 '
Tokenizer Warning: 8Bit character ' -24 '
Tokenizer Warning: 8Bit character ' -4 '
Tokenizer Warning: 8Bit character ' -25 '
Tokenizer Warning: 8Bit character ' -30 '
Tokenizer Warning: 8Bit character ' -14 '
Tokenizer Warning: 8Bit character ' -23 '
terminate called after throwing an instance of 'Akonadi::PayloadException'
  what():  Akonadi::PayloadException: Wrong payload type (requested: sp(0)<QByteArray>; present: sp(2)<KMime::Message*>)
KCrash: Application 'akonadi_imap_resource' crashing...
KCrash: Attempting to start /usr/lib64/libexec/drkonqi from kdeinit
sock_file=/run/user/1000/kdeinit5__0
ProtocolException thrown:Timeout while waiting for data
org.kde.pim.akonadiserver: Protocol exception: Timeout while waiting for data
запустить akonadiconsole не получается - валится много ошибок.
Хотелось бы понять, насколько эта проблема серьёзна и с чем она связана.
Сломался Akonadi
Zeffanyx писал(а): 09 янв 2019, 01:57 Хотелось бы понять, насколько эта проблема серьёзна и с чем она связана.
Связана с тем, что вы на свой страх и риск подключили сторонний источник.
В официальном репозитории этих пакетов нет.
Не дождались исправления и публикации в офф репах,
и получаете ошибки, которые отлавливает QA.
Сломался Akonadi
VictorR2007 писал(а): 09 янв 2019, 02:05 которые отлавливает QA.
Если их действительно отлавливают - замечательно!
Нет проблем, сделаю reposync на официальных источниках.
