Stellarium перестал работать на R8
stargazer
Operating system: ROSA Desktop Fresh R8.1
Сообщение stargazer »
[ This is Stellarium 0.15.2 - http://www.stellarium.org ]
[ Copyright (C) 2000-2017 Fabien Chereau et al.         ]
Writing log file to: "/home/stargazer/.stellarium/log.txt"
File search paths:
  0 .  "/home/stargazer/.stellarium"
  1 .  "/usr/share/stellarium"
Config file is:  "/home/stargazer/.stellarium/config.ini"
Default surface format:  QSurfaceFormat(version 2.0, options QFlags(), depthBufferSize -1, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize -1, samples -1, swapBehavior 0, swapInterval 1, profile  0)
Desired surface format:  QSurfaceFormat(version 2.1, options QFlags(), depthBufferSize 24, redBufferSize 8, greenBufferSize 8, blueBufferSize 8, alphaBufferSize 8, stencilBufferSize 8, samples -1, swapBehavior 0, swapInterval 1, profile  0)
StelGLWidget constructor
StelGraphicsScene constructor
initializeGL
OpenGL supported version:  "4.5.0 NVIDIA 375.26"
Current Format:  QSurfaceFormat(version 4.5, options QFlags(0x4), depthBufferSize 24, redBufferSize 8, greenBufferSize 8, blueBufferSize 8, alphaBufferSize 8, stencilBufferSize 8, samples 0, swapBehavior 0, swapInterval 1, profile  2)
StelMainView::init
Detected: OpenGL "4.5"
Driver version string: "4.5.0 NVIDIA 375.26"
GL vendor is "NVIDIA Corporation"
GL renderer is "GeForce GTX 1060 6GB/PCIe/SSE2"
GL Shading Language version is "4.50 NVIDIA"
GLSL Version Number detected:  4.5
GLSL version is fine, we should not see a graphics problem.
Cache directory is:  "/home/stargazer/.cache/stellarium/stellarium"
Sky language is  "ru_RU"
Application language is  "ru_RU"
Loading Solar System data ...
Loading star data ...
"Loading \"/usr/share/stellarium/stars/default/stars_0_0v0_7.cat\": 0_0v0_7; 4979"
"Loading \"/usr/share/stellarium/stars/default/stars_1_0v0_7.cat\": 1_0v0_7; 21806"
"Loading \"/usr/share/stellarium/stars/default/stars_2_0v0_7.cat\": 2_0v0_7; 150850"
"Loading \"/usr/share/stellarium/stars/default/stars_3_1v0_4.cat\": 3_1v0_4; 425807"
Finished loading star catalogue data, max_geodesic_level:  3
navigation/preset_sky_time is a double - treating as jday: "2451514.25001"
Reloading DSO data...
Loaded 10757 DSO records
LandscapeMgr: initialized Cache for 100 MB.
Loading star names from "/usr/share/stellarium/skycultures/western/star_names.fab"
Loaded 703 / 703 common star names
Loading star names from "/usr/share/stellarium/stars/default/name.fab"
Loaded 4506 / 4506 scientific star names
Loading variable stars from "/usr/share/stellarium/stars/default/gcvs_hip_part.dat"
Loaded 6916 / 6916 variable stars
Loading double stars from "/usr/share/stellarium/stars/default/wds_hip_part.dat"
Loaded 16412 / 16412 double stars
Loading cross-identification data from "/usr/share/stellarium/stars/default/cross-id.dat"
Loaded 108278 / 108278 cross-identification data records for stars
Loading DSO name data ...
Loaded 327 / 485 DSO name records successfully
Loaded 88 / 88 constellation records successfully for culture "western"
Loaded 85 / 85 constellation art records successfully for culture "western"
Loaded 88 / 88 constellation names
Loading constellation boundary data ...
Loaded 782 constellation boundary segments
Initializing basic GL shaders...
Creating GUI ...
Loaded plugin "Exoplanets"
[Exoplanets] Version of the format of the catalog: 1
[Exoplanets] loading catalog file: "/home/stargazer/.stellarium/modules/Exoplanets/exoplanets.json"
Loaded plugin "FOV"
Loaded plugin "MeteorShowers"
MeteorShowersMgr: Loading catalog file: "/home/stargazer/.stellarium/modules/MeteorShowers/showers.json"
Loaded plugin "Novae"
[Novae] version of the catalog: 1
[Novae] loading catalog file: "/home/stargazer/.stellarium/modules/Novae/novae.json"
Loaded plugin "Oculars"
Ocular plugin - press Command-O to toggle eyepiece view mode. Press ALT-o for configuration.
Oculars::validateIniFile ocular.ini exists at:  "/home/stargazer/.stellarium/modules/Oculars/ocular.ini" . Checking version...
Oculars::validateIniFile found existing ini file version  3.1
Loaded plugin "Satellites"
[Satellites] loading catalog file: "/home/stargazer/.stellarium/modules/Satellites/satellites.json"
Satellite has invalid orbit: "DELTA 1 R/B" "08063"
Satellite has invalid orbit: "MOLNIYA 3-10" "11057"
Satellite has invalid orbit: "SL-14 R/B" "26874"
Satellite has invalid orbit: "CZ-3B R/B" "38253"
Satellite has invalid orbit: "PHONESAT 2.4" "39381"
Satellite has invalid orbit: "SPINSAT" "40314"
Satellite has invalid orbit: "BEVO 2" "41314"
Satellite has invalid orbit: "CADRE" "41475"
Satellite has invalid orbit: "STMSAT-1" "41476"
Satellite has invalid orbit: "LEMUR-2-THERESACONDOR" "41485"
Satellite has invalid orbit: "LEMUR-2-NICK-ALLAIN" "41488"
Satellite has invalid orbit: "LEMUR-2-KANE" "41489"
Satellite has invalid orbit: "LEMUR-2-JEFF" "41490"
Satellite has invalid orbit: "FLOCK 2E-8" "41566"
Satellite has invalid orbit: "LEMUR-2-DRMUZZ" "41595"
Satellite has invalid orbit: "LEMUR-2-CUBECHEESE" "41597"
Satellite has invalid orbit: "LEMUR-2-NATE" "41598"
Loaded plugin "SolarSystemEditor"
Using the ssystem.ini file that already exists in the user directory...
Dubious result: Landscape  "Guereins"  not calibrated. Opacity test represents mathematical horizon only.
Initializing planets GL shaders...
terminate called after throwing an instance of 'std::runtime_error'
  what():  illegal value
Stellarium не запускается на R8. После запуска автоматически завершается.
Survolog
Operating system: ROSA Fresh
Писать в Телеграм или ВК.
Сообщение Survolog »
Подтверждаю. Работает несколько секунд и вылетает с тем же логом.
Survolog
Починил вроде. Отправил собираться в контриб 2014.1
Обоснование: оно не работало.
stargazer
Спасибо. Сегодня установил обновление до 18 версии. Всё работает.
