Bug in Kernel: OpenOffice doesn't work any more
enrico65
Operating system: ROSA R8
Сообщение enrico65 »
Hi Folks!
I have installed Desktop Fresh R8.1 to R10 on several machines. Unfortunately OpenOffice doesn't work any more since version 3.2.1. This is the last release you can install on ROSA and which works properly. Newer releases produce a segmentation fault when started. The same issue occurred on openSUSE last year (kernel-bug 1045340):
https://bugzilla.suse.com/show_bug.cgi?id=1045340
I posted this issue here:
http://de.openoffice.info/viewtopic.php ... 08#p275108
Is there any fix available?
regards
enrico65
grem
Operating system: Gentoo, Rosa
Re: Bug in Kernel: OpenOffice doesn't work any more
Сообщение grem »
Hello.
try to install package lib64gdk_pixbuf_xlib2.0_0 and then re-run OpenOffice. This package is usual absent on most of Rosa distributive in default installation. Please try latest version of ApacheOpenoffice 4.1.5
Installation could be done like this:
$ tar -xvf pache_OpenOffice_4.1.5_Linux_x86-64_install-rpm_en-US.tar.gz
$ cd ./en-US/RPMS
# urpmi ./.*rpm
But in current case the LIbreOffice must not be presented in system.
Also you could unpack OpenOffice to local directory:
$ mkdir ./temp
$ cd ./temp
$ wget http://downloads.sourceforge.net/project/openofficeorg.mirror/4.1.5/binaries/en-US/Apache_OpenOffice_4.1.5_Linux_x86-64_install-rpm_en-US.tar.gz
$ tar -xvf Apache_OpenOffice_4.1.5_Linux_x86-64_install-rpm_en-US.tar.gz
$ cd ./en-US/RPMS
$ for i in ./*.rpm; do rpm2cpio $i | cpio -idvm; done
and then run it
$ cd ./opt/openoffice4/program
$ ./soffice
grem
Сообщение grem »
To install Apache OpenOffice 4.1.5 simultaneously with LibreOffice the following sequence of command could be done (en-US could be changed to appropriate localization or language pack could be installed later):
$ cd ./en-US/RPMS
then make under the root:
# rpm -i *.rpm
# cd ./desktop-integration
# rpm -i openoffice4.1.5-freedesktop-menus-4.1.5-9789.noarch.rpm --excludepath=/usr/bin/soffice
The last command will install program menu icons (but not the /usr/bin/soffice symlink) and them will be displayed in this menu. File association will bound with OpenOffice until libreoffice-common package will be reinstalled or updated. Also the opening of files will be available through context menu via "Open with..." dialogue.
Вернуться в «Desktop»
