I am wondering what the best way to install Apache Office on ROSA.
These are these install guidlies from Apache:
This is the main part I do not understand.:
Unpack the downloaded package to prepare for installation.
The following command should work: tar -xvzf "linux package name".tar.gz
where "linux package name" is the beginning part of the archive you just downloaded.
This will create an installation directory.
The name of the installation directory will likely be the language abbreviation for the install set, e.g., en-US.
Add the install directory as a "local repository" for your GUI package manager if possible. This will enable you to do a GUI install rather than command line.
I have unpacked using -xvzf and I can see folder en-US ^ as shown above. But the next line of guide :
I do not understand??
Linux Installations
Linux Pre-installation Notes
The following preinstallation steps are recommended for Linux distributions. These should be taken to assure that you have a clean install of Apache OpenOffice due to internal considerations and/or the installation of LibreOffice, if it exists, on your system.
Check to see if LibreOffice has re-routed the OpenOffice binary.
Type "whereis soffice" from a console.
If this is symlinked to libreoffice, remove the symlink. (see your favorite reference for how to do this)
This will NOT remove LibreOffice, this will only disallow LibreOffice to redirect the normal OpenOffice binary -- typically /usr/bin/soffice -- to libreoffice instead.
Due to directory structure changes in Apache OpenOffice 4.x versions, your older Openoffice 3.x should be deleted entirely by a new install or update process. This is normal. If you experience problems using the "update" process, please remove the old OpenOffice 3.x packages manually.
If you have been testing one of the older developer snapshots, not the released version, revision 150370, completely remove this old version before attempting a new install or update.
See java requirements.
Installation Steps -- RPM or DEB: Download to Installation Directory, Unpack
Review the System Requirements
Download your favorite Linux version of Apache OpenOffice
Desktop integration.
Desktop integration for deb-based systems requires installation of one package.
Historically, for rpm based systems, OpenOffice has provided desktop integration packages for madriva, redhat, suse, and now freedesktop. These packages are located in the desktop-integration subdirectory of the install directory.
Many desktop window managers like KDE4, Gnome3, and Unity now adhere to the freedsktop.org standard for icon placement and mime-type definitions. For this reason, you may want to install the freedesktop desktop integration package first before trying the others.
Linux RPM-based Installation
su to root, if necessary, and navigate to Apache OpenOffice installation directory.
You will likely need to be root to run the rpm command to install the software.
cd into the RPMS subdirectory of the installation directory.
You should see a lot of rpms here and one sub-directory called "desktop-integration".
Install this new version by typing rpm -Uvih *rpm.
By default, this will install Apache OpenOffice in your /opt directory.
Alternatively, you can use a GUI package installer, reference the installation directory, and install all rpms at the top level. This may also aid you in determing any dependency problems if they exist.
Install the desktop integration features for your setup.
cd to desktop-integration (in the installation directory),
and install an appropriate desktop interface using RPM. (Try the freedesktop-menus first.)
Finally, start up Apache OpenOffice 4.x.x to insure it's working.
Any help would be awesome
Thanks !!!!!!!!!
https://www.openoffice.org/download/com ... ux-general
____________________________________________________________________________________________________________________________
Привет всем,
я уверен, что наилучшим способом для установки Apache на роса.
Это такие guidlies установка от Apache:
это основная часть я не понимаю.:
Распакуйте загруженный пакет и подготовит их к установке.
Следующая команда должна работать: tar -xvzf "linux Имя пакета".tar.gz
, где "linux Имя пакета" - начало часть архива вы загрузили.
Это позволит создать каталог установки.
Имя каталога установки, скорее всего, будет на языке аббревиатура для установки, например, en-US.
Добавить в каталог установки как "локальное хранилище" для вашего графический менеджер пакетов, если это возможно. Это позволит вам делать GUI установки вместо командной строки.
Я распаковал с помощью -xvzf и я вижу папку en-US ^, как показано на рисунке выше. Но в следующей строке :
добавить в каталог установки как "локальное хранилище" для вашего графический менеджер пакетов, если это возможно. Это позволит вам делать GUI установки вместо командной строки.
Я не могу понять??
Дистрибутивов Linux
Linux - установка отмечает
следующие шаги перед установкой рекомендуется для дистрибутивов Linux. Они должны быть, чтобы убедиться, что у вас есть чистая установка Apache OpenOffice вследствие внутренних соображений и/или установка LibreOffice (если он существует) в вашей системе.
Проверьте, нет ли на LibreOffice повторно направляется в OpenOffice.
Тип "whereis soffice" из консоли.
Если это symlinked для libreoffice, снимите symlink. (См. любимые ссылки о том, как это сделать)
Это не удалит LibreOffice - это будет только запретить LibreOffice для перенаправления обычного двоичного OpenOffice - обычно в /usr/bin/soffice - libreoffice.
Из-за структуры каталогов в Apache OpenOffice 4.x версий, старых Openoffice 3.x должны быть исключены полностью, новая установка или обновление. Это нормально. Если у вас возникли проблемы с помощью "обновление", пожалуйста, удалите старый OpenOffice 3.x пакеты вручную.
Если вы испытывали одну из старых снимков для разработчиков, а не в официальной версии, редакция 150370, полностью удалить старую версию перед новой установки или обновления.
См. java.
Этапы установки -- rpm или deb скачать к каталогу установки распаковать
Обзор Системные требования
Скачать ваш любимый Linux версия Apache OpenOffice
Системная интеграция.
Системная интеграция для deb-систем требует установки один пакет.
Исторически сложилось так, что в об/мин, OpenOffice обеспечила интеграцию настольных пакетов для madriva, redhat, suse, и теперь freedesktop. Эти пакеты находятся в системной интеграции каталога каталог для установки.
Многие настольные оконные менеджеры, как KDE4 Gnome3, и Единство сейчас присоединиться к freedsktop.org для размещения значка и mime-типов. По этой причине, возможно, вы захотите установить freedesktop системная интеграция пакета первый перед другими.
Linux на базе RPM Установка
на пользователя root, а в случае необходимости и перейдите к Apache OpenOffice каталог установки.
Вам, вероятно, нужно быть пользователем root, чтобы запустить команду rpm для установки программного обеспечения.
Компакт-диск в RPMS каталога каталог установки.
Вы должны увидеть много оборотов здесь и в каталог "Системная интеграция".
Установите новую версию, введя rpm -Uvih *мин.
По умолчанию, после этого будет произведена установка Apache OpenOffice в /opt.
Кроме того, вы можете использовать графический установщик пакетов, следует обратиться к каталогу установки и установить обороты на верхнем уровне. Это может также помочь вам в determing зависимостями проблемы, если
