ffmpeg
*d0s
Operating system: OS X
ffmpeg
Сообщение *d0s »
После обновления ffmpeg начались проблемы с воспроизведением mkv-файлов у romp и umplayer. Если driver\vo=vdpau то виснет
VO: [vdpau] 1920x804 => 1920x804 H.264 VDPAU acceleration  [zoom]
Dropping frame with size not matching configured size (1920x804 vs 1920x792 vs 1920x804)
ID_VIDEO_TRACK=0
ID_AUDIO_TRACK=0
Debug: MplayerProcess::parseLine: 'Starting playback...'
Debug: MplayerProcess::parseLine: 'Movie-Aspect is 2.39:1 - prescaling to correct movie aspect.'
Debug: MplayerProcess::parseLine: md.video_aspect set to 2.390000
Debug: MplayerProcess::parseLine: 'ID_VIDEO_ASPECT=2.3881'
Debug: MplayerProcess::parseLine: md.video_aspect set to 2.388100
Debug: MplayerProcess::parseLine: 'VO: [vdpau] 1920x804 => 1920x804 H.264 VDPAU acceleration  [zoom]'
Debug: Core::gotVO: 'vdpau'
Debug: Core::gotWindowResolution: 1920, 804
Debug: BaseGuiPlus::resizeWindow: 1920, 804
Debug: BaseGui::resizeWindow: 1920, 804
Debug: MplayerProcess::parseLine: 'Dropping frame with size not matching configured size (1920x804 vs 1920x792 vs 1920x804)'
Debug: MplayerProcess::parseLine: 'Too many buffered pts'
*d0s
Re: ffmpeg
Сообщение *d0s »
$ ffmpeg -hwaccels
ffmpeg version 3.4.1 Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 5.4.1 (Linaro GCC 5.4-2017.05) 20170404 (ROSA)
  configuration: --prefix=/usr --enable-shared --libdir=/usr/lib64 --shlibdir=/usr/lib64 --incdir=/usr/include --disable-stripping --enable-postproc --enable-gpl --enable-pthreads --enable-ladspa --enable-libbluray --enable-libtheora --enable-libvorbis --disable-encoder=vorbis --enable-libvpx --enable-libxcb --enable-libxcb-shm --enable-libxcb-xfixes --enable-libxcb-shape --enable-runtime-cpudetect --enable-libdc1394 --enable-librtmp --enable-libspeex --enable-libfreetype --enable-libgsm --enable-libcelt --enable-avresample --enable-opencl --disable-libopencv --enable-libopenjpeg --enable-libopus --enable-libsoxr --enable-libwavpack --disable-libxavs --enable-libmodplug --enable-libmp3lame --enable-libass --enable-gnutls --enable-libcdio --enable-libpulse --enable-libv4l2 --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-version3 --enable-libx264 --enable-libx265 --enable-libvo-amrwbenc --enable-libxvid
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
Hardware acceleration methods:
vdpau
vaapi
cuvid
$ ffplay -codecs | egrep -i "vdpau|vaapi|cuvid"
ffplay version 3.4.1 Copyright (c) 2003-2017 the FFmpeg developers
 DEV.LS h264                 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_vdpau h264_cuvid ) (encoders: libx264 libx264rgb h264_nvenc h264_v4l2m2m h264_vaapi nvenc nvenc_h264 )
 DEV.L. hevc                 H.265 / HEVC (High Efficiency Video Coding) (decoders: hevc hevc_cuvid ) (encoders: libx265 nvenc_hevc hevc_nvenc hevc_vaapi )
 DEVIL. mjpeg                Motion JPEG (decoders: mjpeg mjpeg_cuvid ) (encoders: mjpeg mjpeg_vaapi )
 DEV.L. mpeg1video           MPEG-1 video (decoders: mpeg1video mpeg1video_vdpau mpeg1_v4l2m2m mpeg1_cuvid )
 DEV.L. mpeg2video           MPEG-2 video (decoders: mpeg2video mpegvideo mpegvideo_vdpau mpeg2_v4l2m2m mpeg2_cuvid ) (encoders: mpeg2video mpeg2_vaapi )
 DEV.L. mpeg4                MPEG-4 part 2 (decoders: mpeg4 mpeg4_v4l2m2m mpeg4_vdpau mpeg4_cuvid ) (encoders: mpeg4 libxvid mpeg4_v4l2m2m )
 D.V.L. vc1                  SMPTE VC-1 (decoders: vc1 vc1_vdpau vc1_v4l2m2m vc1_cuvid )
 DEV.L. vp8                  On2 VP8 (decoders: vp8 vp8_v4l2m2m libvpx vp8_cuvid ) (encoders: libvpx vp8_v4l2m2m vp8_vaapi )
 DEV.L. vp9                  Google VP9 (decoders: vp9 libvpx-vp9 vp9_cuvid ) (encoders: libvpx-vp9 )
 D.V.L. wmv3                 Windows Media Video 9 (decoders: wmv3 wmv3_vdpau )
$ mediainfo "file.mkv"
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings                          : CABAC / 5 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 5 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1 h 46 min
Bit rate                                 : 8 780 kb/s
Width                                    : 1 920 pixels
Height                                   : 804 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 24.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.237
Stream size                              : 6.51 GiB (89%)
Writing library                          : x264 core 148 r2705 3f5ed56
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.05:0.05 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=0 / bitrate=8780 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=62500 / nal_hrd=none / filler=0 / ip_ratio=1.40 / pb_ratio=1.30 / aq=3:0.80
Language                                 : English
Default                                  : Yes
Forced                                   : No
Запускаю так кино идет
$ ffplay -codec:v h264 "file.mkv"
Запускаю так и нифига
$ ffplay -codec:v h264_vdpau "file.mkv"
[h264_vdpau @ 0x7f083003d4c0] decode_slice_header error
[h264_vdpau @ 0x7f083003d4c0] no frame!
Точно такая же фигня с этим файлом https://forum.rosalinux.ru/viewtopic.ph ... 100#p91836
так да
$ ffplay -codec:v vc1 "file.mkv"
а так нет
$ ffplay -codec:v vc1_vdpau "file.mkv"
[vc1_vdpau @ 0x7feee01a1f40] decoding to AV_PIX_FMT_NONE is not supported.
Re: ffmpeg
Эх, такие вещи нужно в тестинге ловить... а видеокарта какая? (лучше б вообще пробу оборудования)
*d0s
Re: ffmpeg
Сообщение *d0s »
Извиняюсь за сумбур.
lspci -v | grep -i vga
        Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Redwood XT [Radeon HD 5670/5690/5730] (prog-if 00 [VGA controller])
$ vdpauinfo
display: :0   screen: 0
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name   width height types
420    16384 16384  NV12 YV12
422    16384 16384  UYVY YUYV
444    16384 16384  Y8U8V8A8 V8U8Y8A8
Decoder capabilities:
name                        level macbs width height
MPEG1                          --- not supported ---
MPEG2_SIMPLE                    3  9216  2048  1152
MPEG2_MAIN                      3  9216  2048  1152
H264_BASELINE                  41  9216  2048  1152
H264_MAIN                      41  9216  2048  1152
H264_HIGH                      41  9216  2048  1152
VC1_SIMPLE                      1  9216  2048  1152
VC1_MAIN                        2  9216  2048  1152
VC1_ADVANCED                    4  9216  2048  1152
MPEG4_PART2_SP                 --- not supported ---
MPEG4_PART2_ASP                --- not supported ---
DIVX4_QMOBILE                  --- not supported ---
DIVX4_MOBILE                   --- not supported ---
DIVX4_HOME_THEATER             --- not supported ---
DIVX4_HD_1080P                 --- not supported ---
DIVX5_QMOBILE                  --- not supported ---
DIVX5_MOBILE                   --- not supported ---
DIVX5_HOME_THEATER             --- not supported ---
DIVX5_HD_1080P                 --- not supported ---
H264_CONSTRAINED_BASELINE       0  9216  2048  1152
H264_EXTENDED                  --- not supported ---
H264_PROGRESSIVE_HIGH          --- not supported ---
H264_CONSTRAINED_HIGH          --- not supported ---
H264_HIGH_444_PREDICTIVE       --- not supported ---
HEVC_MAIN                      --- not supported ---
HEVC_MAIN_10                   --- not supported ---
HEVC_MAIN_STILL                --- not supported ---
HEVC_MAIN_12                   --- not supported ---
HEVC_MAIN_444                  --- not supported ---
Output surface:
name              width height nat types
B8G8R8A8         16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
R8G8B8A8         16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
R10G10B10A2      16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
B10G10R10A2      16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 A4I4 I4A4 A8I8 I8A8
Bitmap surface:
name              width height
A8               16384 16384
Video mixer:
feature name                    sup
DEINTERLACE_TEMPORAL             y
DEINTERLACE_TEMPORAL_SPATIAL     -
INVERSE_TELECINE                 -
NOISE_REDUCTION                  y
SHARPNESS                        y
LUMA_KEY                         y
HIGH QUALITY SCALING - L1        y
HIGH QUALITY SCALING - L2        -
HIGH QUALITY SCALING - L3        -
HIGH QUALITY SCALING - L4        -
HIGH QUALITY SCALING - L5        -
HIGH QUALITY SCALING - L6        -
HIGH QUALITY SCALING - L7        -
HIGH QUALITY SCALING - L8        -
HIGH QUALITY SCALING - L9        -
parameter name                  sup      min      max
VIDEO_SURFACE_WIDTH              y        48     2048
VIDEO_SURFACE_HEIGHT             y        48     1152
CHROMA_TYPE                      y
LAYERS                           y         0        4
attribute name                  sup      min      max
BACKGROUND_COLOR                 y
CSC_MATRIX                       y
NOISE_REDUCTION_LEVEL            y      0.00     1.00
SHARPNESS_LEVEL                  y     -1.00     1.00
LUMA_KEY_MIN_LUMA                y
LUMA_KEY_MAX_LUMA                y
$ mpv --vo=help
Available video outputs:
  opengl         : Extended OpenGL Renderer
  vdpau          : VDPAU with X11
  wayland        : Wayland SHM video output
  xv             : X11/Xv
  sdl            : SDL 2.0 Renderer
  vaapi          : VA API with X11
  x11            : X11 (slow, old crap)
  null           : Null video output
  image          : Write video frames to image files
  tct            : true-color terminals
  caca           : libcaca
  drm            : Direct Rendering Manager
$ mpv --hwdec=vaapi --vo=vaapi --alang=ru,rus --slang=ru,rus "file.mkv"
Playing: file.mkv
 (+) Video --vid=1 (*) '*' (vc1 1920x1080)
 (+) Audio --aid=1 --alang=rus 'DTS 5.1, 1536 kbps (Tycoon)' (dts 6ch 48000Hz)
     Audio --aid=2 --alang=rus 'AC3, 2ch 192 kbps (Dubbed)' (ac3 2ch 48000Hz)
     Audio --aid=3 --alang=eng (*) 'DTS 5.1, 1536 kbps' (dts 6ch 48000Hz)
     Audio --aid=4 --alang=eng 'Commentry Track 1' (vorbis 2ch 48000Hz)
     Audio --aid=5 --alang=eng 'Commentry Track 2' (vorbis 2ch 48000Hz)
     Audio --aid=6 --alang=eng 'Commentry Track 3' (vorbis 2ch 48000Hz)
 (+) Subs  --sid=1 --slang=eng (*) (ass)
     Subs  --sid=2 --slang=fin (ass)
     Subs  --sid=3 --slang=scr (ass)
     Subs  --sid=4 --slang=cze (ass)
     Subs  --sid=5 --slang=dan (ass)
     Subs  --sid=6 --slang=ger (ass)
     Subs  --sid=7 --slang=nor (ass)
     Subs  --sid=8 --slang=pol (ass)
     Subs  --sid=9 --slang=por (ass)
     Subs  --sid=10 --slang=slv (ass)
     Subs  --sid=11 --slang=spa (ass)
     Subs  --sid=12 --slang=swe (ass)
     Subs  --sid=13 --slang=tur (ass)
File tags:
 Title: -
libva info: VA-API version 0.38.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib64/dri/r600_drv_video.so
libva info: va_openDriver() returns -1
[vaapi] vaInitialize(): unknown libva error
Error opening/initializing the selected video_out (--vo) device.
Video: no video
Exiting... (Errors when loading file)
$ mpv --hwdec=vdpau --vo=vdpau --alang=ru,rus --slang=ru,rus "file.mkv"
Playing: file.mkv
File tags:
 Title: -
AO: [pulse] 48000Hz 5.1(side) 6ch float
Using hardware decoding (vdpau).
VO: [vdpau] 1920x1080 vdpau[yuv420p]
Invalid video timestamp: 0.000000 -> 0.000000
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.019 Cache: 10s+21MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.034 Cache: 10s+21MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.050 Cache: 10s+22MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.068 Cache: 10s+22MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.083 Cache: 10s+23MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.104 Cache: 10s+24MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.122 Cache: 10s+24MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.139 Cache: 10s+25MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.158 Cache: 10s+25MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.175 Cache: 10s+26MB
AV: 00:03:26 / 01:57:36 (2%) A-V:  0.001 Cache:  9s+73MB
Exiting... (Quit)
$ mpv --hwdec=auto --alang=ru,rus --slang=ru,rus "file.mkv"
Playing: file.mkv
File tags:
 Title: -
VO: [opengl] 1920x1080 vdpau[yuv420p]
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.002 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.003 Dropped: 1 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.004 Dropped: 2 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.021 Dropped: 3 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.037 Dropped: 4 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.052 Dropped: 5 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.067 Dropped: 6 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.083 Dropped: 7 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.099 Dropped: 8 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.114 Dropped: 9 Cache: 10s+73MB
AV: 00:00:00 / 01:57:36 (0%) A-V:  0.129 Dropped: 9 Cache: 10s+73MB
AV: 00:02:13 / 01:57:36 (1%) A-V:  0.007 Cache: 10s+25MB
Exiting... (Quit)
*d0s
Re: ffmpeg
Сообщение *d0s »
Я поторопился с выводами. Mplayer тоже фигачит.
*d0s
Re: ffmpeg
Сообщение *d0s »
Re: ffmpeg
похоже на апстримовую ошибку. Еще попробуйте из тестинга, сегодня еще чуть обновили ffmpeg
*d0s
Re: ffmpeg
Сообщение *d0s »
keleg писал(а): 16 фев 2018, 07:44 похоже на апстримовую ошибку. Еще попробуйте из тестинга, сегодня еще чуть обновили ffmpeg
Подключился к тестовому main64.
Достаточно будет обновить только ffmpeg? Если "да" то ничего не изменилось.
Хотя нет, mplayer стал воспроизводить mplayer -vo vdpau -vc ffvc1vdpau. А ffh264vdpau нет. В остальном по-прежнему.
Re: ffmpeg
*d0s писал(а): 16 фев 2018, 10:30 Хотя нет, mplayer стал воспроизводить mplayer -vo vdpau -vc ffvc1vdpau. А ffh264vdpau нет. В остальном по-прежнему.
Наверное сейчас нужно уже использовать mpv.
*d0s
Re: ffmpeg
Сообщение *d0s »
VictorR2007 писал(а): 16 фев 2018, 20:21
Наверно. Привык к mplayer еще с winxp. Кажется я нашел причину. Вот сейчас подловил в альте ( в росе тоже самое было однажды)
[ 3390.197615] radeon 0000:01:00.0: evergreen_cs_track_validate_cb:480 cb[0] bo too small (layer size 14336, offset 0, max layer 1, bo size 4096, slice 55)
[ 3390.197621] radeon 0000:01:00.0: evergreen_cs_track_validate_cb:484 problematic surf: (64 56) (0 4 1 0 0 4 3)
[ 3390.197624] radeon 0000:01:00.0: evergreen_packet3_check:1948 invalid cmd stream 454
[ 3390.197673] [drm:radeon_cs_ioctl [radeon]] *ERROR* Invalid command stream !
[ 3390.451125] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3390.474950] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3390.474990] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3390.572898] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3390.573062] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3390.573100] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3390.694714] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3390.694875] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3390.694914] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3390.816024] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3390.816187] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3390.816226] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3390.936544] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3390.936706] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3390.936745] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.055849] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.056017] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.056055] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.173863] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.174027] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.174065] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.290027] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.290067] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.405169] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.405331] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.405369] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.520523] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.520688] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.520727] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.636761] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.636923] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.636962] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.756980] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.757144] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.757182] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.880869] radeon 0000:01:00.0: No GEM object associated to handle 0x00000075, can't create framebuffer
[ 3391.881031] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.881070] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3391.923343] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3391.923364] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.049374] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.049414] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.176373] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.176412] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.302162] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.302202] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.425601] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.425640] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.545060] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.545099] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.661700] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.661740] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.778355] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.778394] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3392.895340] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3392.895379] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.012263] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.012302] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.129830] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.129889] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.251261] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.251300] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.376198] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.376237] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.503394] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.503433] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.631826] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.631865] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.759959] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.760038] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3393.886364] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3393.886403] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.009853] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.009893] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.129920] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.129959] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.249632] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.249671] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.369430] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.369469] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.489248] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.489287] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.609036] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.609075] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.729058] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.729097] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.848953] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.848992] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3394.968937] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3394.968977] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.088888] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.088928] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.208795] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.208835] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.328841] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.328881] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.448877] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.448917] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.568849] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.568889] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.688848] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.688887] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.808856] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.808896] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3395.928849] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3395.928888] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.048782] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.048822] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.168828] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.168867] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.288885] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.288924] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.408835] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.408874] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.528923] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.528962] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.648942] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.648981] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.768963] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.769003] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3396.888959] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3396.888998] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.008987] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.009027] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.128970] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.129009] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.248975] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.249014] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.368958] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.368997] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.488954] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.488994] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.609042] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.609082] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.728981] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.729021] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.848998] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.849037] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3397.969065] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3397.969105] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.089081] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.089121] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.209115] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.209159] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.329083] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.329123] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.449168] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.449207] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.569181] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.569220] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.689183] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.689222] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.809090] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.809129] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3398.929213] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3398.929252] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.049239] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.049287] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.169231] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.169271] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.289252] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.289291] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.409254] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.409293] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.529288] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.529328] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.649300] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.649340] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.769265] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.769304] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3399.889228] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3399.889268] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.009230] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.009270] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.129195] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.129269] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.249190] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.249267] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.369204] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.369273] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.489136] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.489183] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.609241] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.609318] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.729250] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.729290] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.849248] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.849296] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3400.969279] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3400.969324] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.089296] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.089341] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.209271] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.209312] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.329297] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.329346] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.449280] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.449327] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.569282] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.569324] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.689256] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.689300] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.809298] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.809341] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[ 3401.929336] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x75
[ 3401.929384] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
https://pastebin.com/6cm7yHCv
*d0s
Re: ffmpeg
Сообщение *d0s »
*d0s писал(а): 17 фев 2018, 10:41 Вот сейчас подловил в альте ( в росе тоже самое было однажды)
Это возникает если перейти в полноэкранный режим mplayer (терминал), romp, umplayer в результате выкидывает из сессии.
https://www.phoronix.com/forums/forum/l ... eady/page4
*d0s
Re: ffmpeg
Сообщение *d0s »
В росе так
$ dmesg
[  123.925114] [drm:radeon_cs_parser_relocs [radeon]] *ERROR* gem object lookup failed 0x54
[  123.925160] [drm:radeon_cs_ioctl [radeon]] *ERROR* Failed to parse relocation -2!
[  124.118104] Core[8735]: segfault at 30097d60 ip 00007f2bd4b29175 sp 00007f2bb2366ab0 error 4 in libc-2.24.so[7f2bd4af0000+1b4000]
*d0s
Re: ffmpeg
Сообщение *d0s »
К сожалению глобальное обновление не решило проблему.
С mpv один раз возник такой же глюк как и с mplayer, надеюсь не повторится.
Единственный положительный момент umplayer с vdpau заработал.
Где-то читал что баг часто возникает если AccelMethod использует EXA, а где-то на гитхабе, что поломали мезу. Возможно что-то аппаратное.
https://bugs.freedesktop.org/show_bug.cgi?id=55913
P.S. Пожалуйста переименуйте название темы на "ffmpeg, mplayer, mpv, vdpau, vaapi"
Andreas17
Re: ffmpeg
Сообщение Andreas17 »
Тоже самое...
[h264_vdpau @ 0x7f8dd45205c0] decode_slice_header error
[h264_vdpau @ 0x7f8dd45205c0] no frame!
Звук есть!
Т.е. это не работает ускорение от видеокарты?
А как вообще в Линукс посмотреть насколько загружен этот специализированный ASIC? Чтобы было как в GPU-Z - 'Video Engine Load'.
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 22 фев 2018, 13:19 Т.е. это не работает ускорение от видеокарты?
Хм. Вопрос!
$ vdpau
$ vainfo
$ cat /var/log/Xorg.0.log | egrep -i "vdpau|vaapi"
https://wiki.archlinux.org/index.php/Ha ... celeration
http://www.geeks3d.com/gputest/
Можно использовать окружение VDPAU_DRIVER=
Только сейчас заметил у себя что выдает vdpauinfo
Фу! Я так не играю
*d0s
Re: ffmpeg
Сообщение *d0s »
В терминале набрать gst потом TAB
$ gst
gst-device-monitor-1.0  gst-inspect-1.0         gst-typefind-0.10
gst-discoverer-0.10     gst-launch-0.10         gst-typefind-1.0
gst-discoverer-1.0      gst-launch-1.0          gst-visualise-0.10
gst-feedback-0.10       gst-play-1.0            gst-xmlinspect-0.10
gst-inspect-0.10        gst-stats-1.0           gst-xmllaunch-0.10
*d0s
Re: ffmpeg
Сообщение *d0s »
$ vainfo
libva info: VA-API version 0.40.0
libva info: Found init function __vaDriverInit_0_40
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.40 (libva )
vainfo: Driver version: mesa gallium vaapi
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
      VAProfileH264ConstrainedBaseline: VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointVLD
      VAProfileNone                   : VAEntrypointVideoProc
Andreas17
Re: ffmpeg
У меня вроде как должно поддерживаться H264:
# vdpauinfo
API version: 1
Information string: NVIDIA VDPAU Driver Shared Library  384.111  Tue Dec 19 22:55:29 PST 2017
Video surface:
420     4096  4096  NV12 YV12
422     4096  4096  UYVY YUYV
MPEG1                           0 65536  4032  4048
MPEG2_SIMPLE                    3 65536  4032  4048
MPEG2_MAIN                      3 65536  4032  4048
H264_BASELINE                  41 65536  4032  4080
H264_MAIN                      41 65536  4032  4080
H264_HIGH                      41 65536  4032  4080
VC1_SIMPLE                      1  8190  2048  2048
VC1_MAIN                        2  8190  2048  2048
VC1_ADVANCED                    4  8190  2048  2048
MPEG4_PART2_SP                  3  8192  2048  2048
MPEG4_PART2_ASP                 5  8192  2048  2048
DIVX4_QMOBILE                   0  8192  2048  2048
DIVX4_MOBILE                    0  8192  2048  2048
DIVX4_HOME_THEATER              0  8192  2048  2048
DIVX4_HD_1080P                  0  8192  2048  2048
DIVX5_QMOBILE                   0  8192  2048  2048
DIVX5_MOBILE                    0  8192  2048  2048
DIVX5_HOME_THEATER              0  8192  2048  2048
DIVX5_HD_1080P                  0  8192  2048  2048
H264_CONSTRAINED_BASELINE      41 65536  4032  4080
H264_EXTENDED                  41 65536  4032  4080
H264_PROGRESSIVE_HIGH          41 65536  4032  4080
H264_CONSTRAINED_HIGH          41 65536  4032  4080
H264_HIGH_444_PREDICTIVE       41 65536  4032  4080
Но всё равно не робит.
Andreas17
Re: ffmpeg
Тут вот пишут, что в ffplay нету аппаратных декодеров...
https://www.linux.org.ru/forum/general/13829547
Нашёл, где посмотреть загрузку видео-движка - в панели управления NVIDIA.
Так вот, включил видео на ютубе с кодеком vc-1. И посмотрел загрузку...
Проц отъедает целое ядро, а Video Engine Utilization: 0%.
Как включить ускорение видео хотя бы в браузере (Chromium)?
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 22 фев 2018, 23:03 Тут вот пишут, что в ffplay нету аппаратных декодеров...
vc1 - проблематичный кодек.
Вроде собрали хром - https://forum.rosalinux.ru/viewtopic.ph ... 100#p92640
Если в терминале запустить хромиум то что пишет? Если так запустить
$ chromium-browser --blacklist-accelerated-compositing
$ chromium-browser --disable-gpu-sandbox
$ chromium-browser --ignore-gpu-blacklist
можно в chrome://flags включить Override software redendering list аналогично --ignore-gpu-blacklist.
Кстати, что показывает chrome://gpu строка "Graphics Feature Status Video Decode:"?
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 22 фев 2018, 23:03 Как включить ускорение видео хотя бы в браузере (Chromium)?
У меня такая картина нарисовалась
$ chromium-browser --ignore-gpu-blacklist --enable-accelerated-video --enable-gpu-rasterization --memory-ablation --enable-native-gpu-memory-buffers
crome://gpu
Note: To properly save this page, select the "Webpage, Complete" option in the Save File dialog
Canvas: Hardware accelerated
CheckerImaging: Enabled
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Hardware accelerated
Rasterization: Hardware accelerated
Video Decode: Hardware accelerated
Video Encode: Hardware accelerated
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
Driver Bug Workarounds
adjust_src_dst_region_for_blitframebuffer
clear_uniforms_before_first_program_use
count_all_in_varyings_packing
decode_encode_srgb_for_generatemipmap
disable_framebuffer_cmaa
disable_post_sub_buffers_for_onscreen_surfaces
disable_software_to_accelerated_canvas_upgrade
dont_remove_invariant_for_fragment_input
force_cube_map_positive_x_allocation
force_int_or_srgb_cube_texture_complete
init_texture_max_anisotropy
regenerate_struct_names
remove_invariant_and_centroid_for_essl3
scalarize_vec_and_mat_constructor_args
Problems Detected
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Mesa drivers in Linux handle varyings without static use incorrectly: 333885
Applied Workarounds: count_all_in_varyings_packing
Linux AMD drivers incorrectly return initial value of 1 for TEXTURE_MAX_ANISOTROPY: 348237
Applied Workarounds: init_texture_max_anisotropy
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
Linux AMD drivers handle struct scopes incorrectly: 403957
Applied Workarounds: regenerate_struct_names
Linux ATI drivers crash on binding incomplete cube map texture to FBO: 518889
Applied Workarounds: force_cube_map_positive_x_allocation
Use GL_INTEL_framebuffer_CMAA on ChromeOS: 535198
Applied Workarounds: disable_framebuffer_cmaa
Disable partial swaps on Mesa drivers (detected with GL_VERSION): 339493
Applied Workarounds: disable_post_sub_buffers_for_onscreen_surfaces
Decode and encode before generateMipmap for srgb format textures on os except macosx: 634519
Applied Workarounds: decode_encode_srgb_for_generatemipmap
adjust src/dst region if blitting pixels outside read framebuffer on Linux AMD: 664740
Applied Workarounds: adjust_src_dst_region_for_blitframebuffer
AMD drivers in Linux require invariant qualifier to match between vertex and fragment shaders: 659326, 639760
Applied Workarounds: remove_invariant_and_centroid_for_essl3, dont_remove_invariant_for_fragment_input
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Decode and Encode before generateMipmap for srgb format textures on Linux AMD: 634519
Software to Accelerated canvas update breaks Linux AMD: 710029
Applied Workarounds: disable_software_to_accelerated_canvas_upgrade
Force integer or srgb cube map texture complete on Linux AMD: 712117
Applied Workarounds: force_int_or_srgb_cube_texture_complete
Version Information
Data exported	23.02.2018, 15:53:02
Chrome version	Chrome/63.0.3239.132
Operating system	Linux 4.9.76-nrj-desktop-1rosa-x86_64
Software rendering list version	0
Driver bug list version	10.34
ANGLE commit id	unknown hash
2D graphics backend	Skia/63 dbae7001c9805fb0a4b18fd0cbc889941cb39db4-
Command Line	/usr/lib64/chromium-browser/chrome --password-store=basic --enable-threaded-compositing --ignore-gpu-blacklist --enable-accelerated-video --enable-gpu-rasterization --memory-ablation --enable-native-gpu-memory-buffers --incognito --flag-switches-begin --flag-switches-end
Driver Information
Initialization time	151
In-process GPU	false
Passthrough Command Decoder	false
Supports overlays	false
Sandboxed	false
GPU0	VENDOR = 0x1002, DEVICE= 0x68d8
Optimus	false
Optimus	false
AMD switchable	false
Driver vendor	Mesa
Driver version	17.3.3
Driver date
Pixel shader version	1.30
Vertex shader version	1.30
Max. MSAA samples	8
Machine model name
Machine model version
GL_VENDOR	X.Org
GL_RENDERER	AMD REDWOOD (DRM 2.49.0 / 4.9.76-nrj-desktop-1rosa-x86_64, LLVM 3.9.0)
GL_VERSION	3.0 Mesa 17.3.3
GL_EXTENSIONS	GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_packed_pixels GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NVX_gpu_memory_info GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_vdpau_interop GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
Disabled Extensions	GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
Window system binding vendor	SGI
Window system binding version	1.4
Window system binding extensions	GLX_ARB_create_context GLX_ARB_create_context_profile GLX_ARB_create_context_robustness GLX_ARB_fbconfig_float GLX_ARB_framebuffer_sRGB GLX_ARB_multisample GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_EXT_fbconfig_packed_float GLX_EXT_framebuffer_sRGB GLX_EXT_import_context GLX_EXT_libglvnd GLX_EXT_texture_from_pixmap GLX_EXT_visual_info GLX_EXT_visual_rating GLX_MESA_copy_sub_buffer GLX_OML_swap_method GLX_SGI_swap_control GLX_SGIS_multisample GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGIX_visual_select_group GLX_INTEL_swap_event
Window manager	Openbox
XDG_CURRENT_DESKTOP	LXQt
Compositing manager	No
Direct rendering	Yes
Reset notification strategy	0x8261
GPU process crash count	0
System visual ID	33
RGBA visual ID	122
Compositor Information
Tile Update Mode	One-copy
Partial Raster	Enabled
GpuMemoryBuffers Status
ATC	Software only
ATCIA	Software only
DXT1	Software only
DXT5	Software only
ETC1	Software only
R_8	Software only
R_16	Software only
RG_88	Software only
BGR_565	Software only
RGBA_4444	Software only
RGBX_8888	Software only
RGBA_8888	Software only
BGRX_8888	Software only
BGRA_8888	Software only
RGBA_F16	Software only
YVU_420	Software only
YUV_420_BIPLANAR	Software only
UYVY_422	Software only
Display(s) Information
Info	Display[21442665266041858] bounds=0,0 1920x1080, workarea=0,0 1920x1080, scale=1, external
Color space information	{primaries:INVALID, transfer:INVALID, matrix:INVALID, range:INVALID, icc_profile_id:0}
Bits per color component	8
Bits per pixel	24
Log Messages
[23264:23264:0223/154507.429067:ERROR:sandbox_linux.cc(351)] : InitializeSandbox() called with multiple threads in process gpu-process.
Re: ffmpeg
Тут почитай http://bugs.rosalinux.ru/show_bug.cgi?id=8655#c12
Andreas17
Re: ffmpeg
*d0s писал(а): 23 фев 2018, 08:09Если в терминале запустить хромиум то что пишет?
# chromium-browser --ignore-gpu-blacklist --enable-accelerated-video --enable-gpu-rasterization --memory-ablation --enable-native-gpu-memory-buffers
[14079:14079:0223/125723.262449:ERROR:vaapi_wrapper.cc(1212)] vaInitialize failed: unknown libva error
[14040:14071:0223/125724.208199:ERROR:service_manager.cc(157)] Connection InterfaceProviderSpec prevented service: content_renderer from binding interface: blink::mojom::ReportingServiceProxy exposed by: content_browser
[14040:14071:0223/125725.961403:ERROR:service_manager.cc(157)] Connection InterfaceProviderSpec prevented service: content_renderer from binding interface: blink::mojom::ReportingServiceProxy exposed by: content_browser
libpng warning: iCCP: known incorrect sRGB profile
*d0s писал(а): 23 фев 2018, 08:09 Кстати, что показывает chrome://gpu строка "Graphics Feature Status Video Decode:"?
Andreas17
Re: ffmpeg
Алзим писал(а): 23 фев 2018, 12:42 Тут почитай http://bugs.rosalinux.ru/show_bug.cgi?id=8655#c12
Спс за наводку.
Это получается, что VDPAU больше не развивается и Хромиум с ним не работает. Но работает с VA-API.
Оно у меня включено:
Hardware-accelerated video
Hardware-accelerated video where VA-API driver is installed on thesystem. Linux
#enable-accelerated-video
Поставил из пакетов транслятор VDPAU -> VA-API: vaapi-driver-vdpau.
Не работает.
Где-то в Гугле видел, что нужна специальная версия Хромиума. Может у меня не правильная?
Версия 63.0.3239.132 (Сборка ROSA), ROSA 2016.1 (64 бит)
Andreas17
Re: ffmpeg
О, интересно девки пляшут...
после установки драйвера в консоли появились новые сообщения:
[17329:17329:0223/131853.069356:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069424:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 0 and entrypoint 1
[17329:17329:0223/131853.069437:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069447:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 1 and entrypoint 1
[17329:17329:0223/131853.069456:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069466:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 2 and entrypoint 1
[17329:17329:0223/131853.069475:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069484:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 3 and entrypoint 1
[17329:17329:0223/131853.069493:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069504:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 5 and entrypoint 1
[17329:17329:0223/131853.069514:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069522:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 6 and entrypoint 1
[17329:17329:0223/131853.069531:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069540:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 7 and entrypoint 1
[17329:17329:0223/131853.069549:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069557:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 8 and entrypoint 1
[17329:17329:0223/131853.069567:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069577:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 9 and entrypoint 1
[17329:17329:0223/131853.069587:ERROR:vaapi_wrapper.cc(465)] vaQuerySurfaceAttributes failed VA error: invalid parameter
[17329:17329:0223/131853.069595:ERROR:vaapi_wrapper.cc(335)] GetMaxResolution failed for va_profile 10 and entrypoint 1
vdpau_video: vaTerminate(): config ID 0x01000000 is still allocated, destroying
Я так понял, враппер инициализировался, но что-то пошло не так.
Что касается плееров то:
RMP - ускорения нет и фз как включить.
SMPlayer - включается через настройки и прекрасно работает.
mpv - включается добавлением строчки hwdec=vdpau в mpv.conf, работает.
vlc - не работает, после установки плагина из пакетов для поддержки VDPAU и включением опций в настройках тоже не работает.
Re: ffmpeg
Можешь попробовать из Тестовых реп. Там скоро (после зеркалирования — в течении нескольких часов) должен появиться Хромиум 64. Там патч отвечающий за аппаратное ускорение обновлён.
Сам я в этом мало чем могу помочь, т.к. мой комп акселерацию не поддерживает.
К тому же, в Хромиум 64 в chrome://gpu/ должна появиться строка Video Acceleration Information.
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 23 фев 2018, 13:25 Что касается плееров то:
Для ромпа вручную
$ mcedit ~/.config/rosamp/rosamp.ini
driver\vo=
Только у меня почему-то перестал понимать vdpau.
Для mpv hwdec=auto и посмотреть что будет после Using hardware decoding.
vlc глюкавый. Особенно с mkv нет слов.
В SMPlayer можно выбрать как mplayer так mpv (на вкус).
Последний раз редактировалось *d0s 23 фев 2018, 13:57, всего редактировалось 1 раз.
Andreas17
Re: ffmpeg
Алзим писал(а): 23 фев 2018, 13:30 Можешь попробовать из Тестовых реп. Там скоро (после зеркалирования — в течении нескольких часов) должен появиться Хромиум 64. Там патч отвечающий за аппаратное ускорение обновлён.
Походу пока не запилили. Будем ждать.
Andreas17
Re: ffmpeg
*d0s писал(а): 23 фев 2018, 13:52 Для ромпа вручную
У меня там xv был прописан какой-то. Подставил vdpau и заработало. Спс.
С плеерам в принципе норм. VLC не особо нужен. Пользую его редко и только когда файл битый или с непонятным форматом.
*d0s
Re: ffmpeg
Сообщение *d0s »
У оперы дела хуже.
Re: ffmpeg
Я удалил ROMP и пользуюсь SMPlayer. Он все DVD фильмы показывал в формате 4:3, хоть фильм и был 16:9.
*d0s
Re: ffmpeg
Сообщение *d0s »
Barmalei писал(а): 23 фев 2018, 17:09 Он все DVD фильмы показывал в формате 4:3, хоть фильм и был 16:9.
Видимо опять вручную править чтоб автоматом.
*d0s
Re: ffmpeg
Сообщение *d0s »
$ opera --ignore-gpu-blacklist --enable-accelerated-video --enable-gpu-rasterization --memory-ablation --enable-native-gpu-memory-buffers
Вроде картинка стала лучше. Или это кажется?
Andreas17
Re: ffmpeg
Поставил Chromium 64. Не работает. :(
[23323:23323:0302/202745.557278:ERROR:vaapi_wrapper.cc(286)] vaInitialize failed: unknown libva error
Andreas17
Re: ffmpeg
Ещё для разнообразия установил Chrome.
Версия 64.0.3282.186 (Официальная сборка), (64 бит)
Стартует без ошибок. Но ускорение также не работает.
Вот что оба браузера пишут в настройках...
Re: ffmpeg
Andreas17 писал(а): 02 мар 2018, 20:56 Ещё для разнообразия установил Chrome.
Попробуй самый новый, http://abf-downloads.rosalinux.ru/rosa2 ... n/release/
Но, я уверен, что не поможет. Проблему ищи в системе и драйверах.
Andreas17
Re: ffmpeg
Так и есть.
Вчера попробовал поставить открытые драйвера на видюху. Ну а вдруг?
Не помогло. Похоже враппер не совместим с моей GTX 650. :(
*d0s
Re: ffmpeg
Сообщение *d0s »
У меня возникают два варианта, где надо поправить /etc/X11/xorg.conf.d/20-radeon.conf:
1. Либо отключить опцию dri3
2. Либо перейти c exa на glamor
но эти варианты мне не очень удобны.
*d0s
Re: ffmpeg
Сообщение *d0s »
С капзиллой такие же заморочки https://github.com/QupZilla/qupzilla/issues/1952
Только ни фига не выходит. Все время crashlog.
Запускаю так
qupzilla --ignore-gpu-blacklist --enable-accelerated-video-decode --enable-gpu-memory-buffer-video-frames --enable-gpu-compositing
а в итоге lxtask выдает
/usr/lib64/qt5/libexec/QtWebEngineProcess --type=renderer --disable-gpu-memory-buffer-video-frames --enable-gpu-memory-buffer-video-frames --enable-threaded-compositing --use-gl=desktop --траля-ля
как убрать --disable-gpu-memory-buffer-video-frames?
Andreas17
Re: ffmpeg
У меня такая же опция включена. На что она влияет?
Как я понял в Qupzilla нет плагина vp9->h264, поэтому и ускорение фих знает как проверить.
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 12 мар 2018, 16:43 У меня такая же опция включена. На что она влияет?
Не знаю, но хотелось бы enable.
Для начала
https://www.youtube.com/html5
https://html5test.com/
https://www.quirksmode.org/html5/tests/video.html
Думаю ответы искать здесь.
Тут непонятные тесты https://www.youtube.com/watch?v=Ctjm1kxw-BM
Re: ffmpeg
А что-то выключено? У меня всё включено.
Andreas17
Re: ffmpeg
У меня все галочки стоят. Все видео с этой ссылки https://www.quirksmode.org/html5/tests/video.html проигрываются. Ускорения нет.
Re: ffmpeg
Чтобы ускорение было, надо чтобы видеокарта поддерживала и скорее всего дополнительные драйвера.
Точно не знаю, т.к. у меня древняя встроенная видеокарта и аккселерацию не поддерживает.
*d0s
Re: ffmpeg
Сообщение *d0s »
Не знаю, может как-то принудительно в окружение прописать ~.bashrc
export LIBVA_DRIVER_NAME=vdpau
export LIBVA_DRIVER_NAME=vaapi
Алзим писал(а): 12 мар 2018, 19:44 Чтобы ускорение было, надо чтобы видеокарта поддерживала и скорее всего дополнительные драйвера.
Ну мы и пытаемся это выяснить. Как это точно выяснить?
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 12 мар 2018, 19:30 У меня все галочки стоят. Все видео с этой ссылки https://www.quirksmode.org/html5/tests/video.html проигрываются. Ускорения нет.
А какое содержимое?
$ ls -l /usr/lib64/dri
$ ls -l /usr/lib/dri
У меня в альте вот такая херня
итого 82044
-rw-r--r-- 1 root root  4263576 июл 12  2017 i965_drv_video.so
-rw-r--r-- 1 root root 26549688 янв 22 15:56 nouveau_drv_video.so
lrwxrwxrwx 1 root root       18 июл  7  2017 nvidia_drv_video.so -> vdpau_drv_video.so
-rw-r--r-- 2 root root 26549688 янв 22 15:56 r600_drv_video.so
-rw-r--r-- 2 root root 26549688 янв 22 15:56 radeonsi_drv_video.so
lrwxrwxrwx 1 root root       18 июл  7  2017 s3g_drv_video.so -> vdpau_drv_video.so
-rw-r--r-- 1 root root    97168 ноя 20  2014 vdpau_drv_video.so
итого 56764
lrwxrwxrwx 1 root root       18 июл 14  2017 nvidia_drv_video.so -> vdpau_drv_video.so
-rw-r--r-- 2 root root 29005872 янв 22 15:56 r600_drv_video.so
-rw-r--r-- 2 root root 29005872 янв 22 15:56 radeonsi_drv_video.so
lrwxrwxrwx 1 root root       18 июл 14  2017 s3g_drv_video.so -> vdpau_drv_video.so
-rw-r--r-- 1 root root   108384 ноя 20  2014 vdpau_drv_video.so
Последний раз редактировалось *d0s 12 мар 2018, 20:24, всего редактировалось 1 раз.
Re: ffmpeg
В Хромиуме по этой ссылке chrome://gpu/ что пишет?
*d0s
Re: ffmpeg
Сообщение *d0s »
Алзим писал(а): 12 мар 2018, 20:23 В Хромиуме по этой ссылке chrome://gpu/ что пишет?
Хромиум не показатель.
https://forum.rosalinux.ru/viewtopic.ph ... 894#p92766
*d0s
Operating system: OS X
Re: ffmpeg
Сообщение *d0s »
Все я понял. Для хрома нужен ваапи, а у меня отсутствует vaapi_drv_video.so
Re: ffmpeg
vaapi конечно нужен и крайне желательно интеловская карточка.
*d0s
Re: ffmpeg
Сообщение *d0s »
*d0s писал(а): 12 мар 2018, 20:32 Все я понял. Для хрома нужен ваапи, а у меня отсутствует vaapi_drv_video.so
Я загнул. Похоже такого драйвера в природе не существует.
Вот и непонятно
$ chromium --incognito --ignore-gpu-blacklist --enable-accelerated-video --enable-gpu-rasterization --memory-ablation --enable-native-gpu-memory-buffers
(chromium:10437): Gtk-WARNING **: Theme parsing error: applications.css:21:0: Expected a valid selector
[10510:10510:0313/004731.948375:ERROR:sandbox_linux.cc(344)] InitializeSandbox() called with multiple threads in process gpu-process.
[19:83:0313/004746.030987:ERROR:adm_helpers.cc(62)] Failed to query stereo recording.
[12:96:0313/004746.411682:ERROR:adm_helpers.cc(62)] Failed to query stereo recording.
[24:95:0313/004746.423147:ERROR:adm_helpers.cc(62)] Failed to query stereo recording.
Re: ffmpeg
*d0s
Re: ffmpeg
Сообщение *d0s »
Можно еще вот этим попробовать
$ gst-launch-1.0 playbin uri=file:///home/joe/foo.avi
Установка конвейера в состояние PAUSED…
Подготовка конвейера (PREROLL)…
Получен контекст из элемента «vaapisink0»: gst.vaapi.Display=context, gst.vaapi.Display=(GstVaapiDisplay)"\(GstVaapiDisplayGLX\)\ vaapidisplayglx1";
Stream with high frequencies VQ coding
No accelerated IMDCT transform found
Перераспределение латентности…
Получен контекст из элемента «playsink»: gst.vaapi.Display=context, gst.vaapi.Display=(GstVaapiDisplay)"\(GstVaapiDisplayGLX\)\ vaapidisplayglx1";
Конвейер подготовлен (PREROLLED)…
Установка конвейера в состояние PLAYING…
New clock: GstPulseSinkClock
XIO:  fatal IO error 11 (Ресурс временно недоступен) on X server ":0"
      after 297 requests (275 known processed) with 1 events remaining.
$ gst-play-1.0 file:///home/joe/foo.avi
Нажмите «k» для показа списка клавиатурных комбинаций.
Сейчас проигрывается /media/ratnik/Elements/MY/V/F/Blade Runner 'Final Cut'.mkv
Redistribute latency...
Prerolled./ 1:57:36.8
Could not seek.
Could not seek.
Prerolled.
Could not seek.
1:15:17.0 / 1:57:36.8
Could not seek.
1:34:06.1 / 1:57:36.8
Could not seek.
Достигнут конец списка воспроизведения.
Удручающе.
Andreas17
Re: ffmpeg
Конечно GTX 650 поддерживает ускорение.
*d0s
Re: ffmpeg
Сообщение *d0s »
Обновил mesa, drm ... Перестал mplayer чудить.
romp и umplayer не хотят дружит с vdpau.
Andreas17
Re: ffmpeg
А что за видюха?
В "~/.config/rosamp/rosamp.ini" есть строчка "driver\vo=vdpau"?
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 30 мар 2018, 21:31 В "~/.config/rosamp/rosamp.ini" есть строчка "driver\vo=vdpau"?
Конечно.
У меня непонятная ситуация. Время от времени romp & umplayer глючат, то проигрывают видео то нет.
Последний раз редактировалось *d0s 31 мар 2018, 14:41, всего редактировалось 1 раз.
Andreas17
Re: ffmpeg
Я тоже вчера в ROMP глюк нашёл.
Некоторые файлы проигрывает только звук.
Если ускорение отключить, то всё нормально.
Начал сравнивать, всё вроде одинаковое (у меня все видосы в mp4/h264). Кроме разрешения!
720p - норм проигрывает. 1080p - чёрный экран и только звук.
*d0s
Re: ffmpeg
Сообщение *d0s »
Andreas17 писал(а): 31 мар 2018, 12:59 720p - норм проигрывает. 1080p - чёрный экран и только звук.
Аналогично. Ранее забыл об этом упомянуть.
Где-то на NVIDIA Developer Forums обсуждалось, что это старый баг mplayer.
Andreas17
ffmpeg
Похоже наконец починили ffmpeg. :)
Только ещё надо установить пакет CUDA - nvidiaXXX-cuda-opencl.
Теперь можно проиграть файл:
ffplay -codec:v h264_cuvid video.mp4
Проверил в панели NVIDIA, ускорение работает как надо.
Или конвертировать ютубовский видос из VP9 в h264:
ffmpeg -i input.webm -c:v h264_nvenc output.mp4
У меня на GTX 650 получается в 10 раз быстрее, чем на 4х ядрах процессора (0.9x против 0.09x).
