Что случилось с Tor????
Andrew21
Сообщение Andrew21 »
Linux rosa10 4.9.76-nrj-laptop-1rosa-x86_64 #1 SMP PREEMPT Sat Jan 13 13:46:28 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Использую Rosa Fresh R10 на ноуте. Месяц не запускал TOR. И что-то с ним случилось - не запускается. Попробовал из консоли. И вот такая картина выходит:
@rosa10 ~ $ tor
Feb 08 22:08:46.930 [notice] Tor 0.3.1.9 (git-727d3f1b5e6eeda7) running on Linux with Libevent 2.0.21-stable, OpenSSL 1.0.2m, Zlib 1.2.8, Liblzma 5.2.3, and Libzstd N/A.
Feb 08 22:08:46.941 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://www.torproject.org/download/download#warning
Feb 08 22:08:46.941 [notice] Read configuration file "/etc/tor/torrc".
Feb 08 22:08:46.948 [notice] Opening Socks listener on 127.0.0.1:9050
Feb 08 22:08:46.000 [notice] Parsing GEOIP IPv4 file /usr/share/tor/geoip.
Feb 08 22:08:47.000 [notice] Parsing GEOIP IPv6 file /usr/share/tor/geoip6.
Feb 08 22:08:47.000 [notice] Bootstrapped 0%: Starting
Feb 08 22:08:48.000 [notice] Starting with guard context "default"
Feb 08 22:08:48.000 [notice] Bootstrapped 5%: Connecting to directory server
Feb 08 22:08:48.000 [notice] Bootstrapped 10%: Finishing handshake with directory server
Feb 08 22:08:48.000 [notice] Bootstrapped 15%: Establishing an encrypted directory connection
Feb 08 22:08:48.000 [notice] Bootstrapped 20%: Asking for networkstatus consensus
Feb 08 22:08:48.000 [notice] Bootstrapped 25%: Loading networkstatus consensus
Feb 08 22:08:49.000 [notice] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
Feb 08 22:08:49.000 [notice] Bootstrapped 40%: Loading authority key certs
Feb 08 22:08:49.000 [notice] Bootstrapped 45%: Asking for relay descriptors
Feb 08 22:08:49.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6275, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of exit bw = 0% of path bw.)
Feb 08 22:08:50.000 [notice] Bootstrapped 50%: Loading relay descriptors
Feb 08 22:08:52.000 [notice] Bootstrapped 56%: Loading relay descriptors
Feb 08 22:08:53.000 [notice] Bootstrapped 64%: Loading relay descriptors
Feb 08 22:08:54.000 [notice] Bootstrapped 70%: Loading relay descriptors
Feb 08 22:08:55.000 [notice] Bootstrapped 78%: Loading relay descriptors
Feb 08 22:08:55.000 [notice] Bootstrapped 80%: Connecting to the Tor network
Feb 08 22:08:55.000 [notice] Bootstrapped 85%: Finishing handshake with first hop
Feb 08 22:08:55.000 [notice] Bootstrapped 90%: Establishing a Tor circuit
Feb 08 22:08:56.000 [notice] Tor has successfully opened a circuit. Looks like client functionality is working.
Feb 08 22:08:56.000 [notice] Bootstrapped 100%: Done
Feb 08 22:11:48.000 [notice] Interrupt: exiting cleanly.
Что делать? Куда копать?
mexx400
Operating system: Debian
Re: Что случилось с Tor????
Сообщение mexx400 »
Не знаю, можно или нельзя постить ссылки на другие форумы, но так проще, чем переписывать текст оттуда - https://debianforum.ru/index.php?topic= ... ;topicseen
