STEAM_RUNTIME=0
STEAM_RUNTIME=0
Перестал Стим так запускаться перестал, сначала пожаловался на отсутствие /usr/lib/libbz2.so.1.0, сделал симлинк с /usr/lib/libbz2.so.1.0.0, теперь на модули ГТК жалуется, еще какие-то ошибки
serge@samsung ~ $ STEAM_RUNTIME=0 steam
Running Steam on rosadesktopfresh 2016.1 64-bit
STEAM_RUNTIME is disabled by the user
[2018-02-02 12:35:55] Startup - updater built Jan 25 2018 21:24:55
[2018-02-02 12:35:55] Opted in to client beta 'publicbeta' via beta file
You are in the 'publicbeta' client beta.
Installing breakpad exception handler for appid(steam)/version(1516948201)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2018-02-02 12:35:55] Checking for update on startup
[2018-02-02 12:35:55] Проверка на наличие обновлений...
[2018-02-02 12:35:56] Download skipped: /client/steam_client_publicbeta_ubuntu12 version 1516948201, installed version 1516948201
[2018-02-02 12:35:56] Nothing to do
[2018-02-02 12:35:56] Проверка установки...
[2018-02-02 12:35:56] Performing checksum verification of executable files
[2018-02-02 12:35:57] Verification complete
(steam:28984): Gtk-WARNING **: Загружаемый модуль тем не найден в module_path: «adwaita»,
CApplicationManagerPopulateThread took 12 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
CAppInfoCacheReadFromDiskThread took 60 milliseconds to initialize
Setting VR Path Registry config path to /home/serge/.local/share/Steam/config
vr/vrmanager.cpp (196) : Assertion Failed: BFileExists( /home/serge/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrpathreg ) failed
Assert( Assertion Failed: BFileExists( /home/serge/.local/share/Steam/steamapps/common/SteamVR/bin/linux64/vrpathreg ) failed ):vr/vrmanager.cpp:196
No minidump written, nothing to upload.
Setting VR Path Registry log path to /home/serge/.local/share/Steam/logs
Generating new string page texture 2: 48x256, total string texture memory is 49,15 KB
Generating new string page texture 3: 256x256, total string texture memory is 311,30 KB
Could not create Vulkan instance :
ERROR_EXTENSION_NOT_PRESENT
[0202/123600.207188:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
[0202/123601.208061:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
roaming config store loaded successfully - 3076 bytes.
migrating temporary roaming config store
(steam:28984): GLib-GObject-WARNING **: gsignal.c:2523: signal 'child-added' is invalid for instance '0x57aba128' of type 'GtkMenu'
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Refresh rate: 0
Unable to read VR Path Registry from /home/serge/.config/openvr/openvrpaths.vrpath
[0202/123602.208333:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
process 28984: arguments to dbus_connection_ref() were incorrect, assertion "connection->generation == _dbus_current_generation" failed in file /builddir/build/BUILD/dbus-1.10.14/dbus/dbus-connection.c line 2686.
This is normally a bug in some application using the D-Bus library.
  D-Bus not built with -rdynamic so unable to print a backtrace
[0202/123603.208839:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
../common/pipes.cpp (766) : CClientPipe::BWriteAndReadResult: BWaitResult failed, disconnected
../common/pipes.cpp (766) : Fatal assert failed: ../common/pipes.cpp, line 766.  Application exiting.
Assert( CClientPipe::BWriteAndReadResult: BWaitResult failed, disconnected ):../common/pipes.cpp:766
/home/serge/.local/share/Steam/steam.sh: строка 927: 28984 Аварийный останов         (слепок снят) $STEAM_DEBUGGER "$STEAMROOT/$STEAMEXEPATH" "$@"
_ExitOnFatalAssert
Re: STEAM_RUNTIME=0
Наверное не то сделал с симлинком.
Посмотрел у себя, и это симлинки libbz2.so.1.0 на файл libbz2.so.1.0.4.
У меня они лежат в
~/.local/share/Steam/ubuntu12_32/steam-runtime/i386/lib/i386-linux-gnu/
ещё в
~/.local/share/Steam/ubuntu12_32/steam-runtime.old/i386/lib/i386-linux-gnu/
ещё в
~/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/lib/x86_64-linux-gnu/
ещё в
~/.local/share/Steam/ubuntu12_32/steam-runtime.old/amd64/lib/x86_64-linux-gnu/
Re: STEAM_RUNTIME=0
Как вариант, если повредились файлы, можно попробовать переименовать ~/.local/share/Steam.
После запуска будет создана новая папка ~/.local/share/Steam.
Скопировать ~/.local/share/Steam/ubuntu12_32/ и ~/.local/share/Steam/ubuntu12_64/
из новой ~/.local/share/Steam в переименованную.
Потом удалить новую и переименовать назад старую папку.
Re: STEAM_RUNTIME=0
VictorR2007 писал(а): 02 фев 2018, 14:23 Наверное не то сделал с симлинком.
У меня они лежат в
ещё в
ещё в
ещё в
STEAM_RUNTIME=0 это запуск без библиотек Стим
Вернуться в «Игры и Steam»
