BZFlag
bmccall3
Operating system: Rosa linux R5
BZFlag
Сообщение bmccall3 »
BZFlag won't start, when I use konsole to launch it I get "Segmentation fault (core dumped)".
Any help on this would be appreciated. I am currently running R10.
JasinSwift
Operating system: https://bestazy.com
Re: BZFlag
Сообщение JasinSwift »
Do any other OpenGL games work? (Or even glxgears?) Have you tried turning off desktop effects (if you have them enabled)?
Give me feed back.
regards.
-Jasin.
But man is not made for defeat. A man can be destroyed but not defeated.
bmccall3
Re: BZFlag
yes all other OpenGL games work and glxgears runs fine when I type it in the shell. Turned off window compositer still BZflag would not start. When I type it into the shell I get the following :Segmentation fault (core dumped).
Вернуться в «Desktop»
