installing compiling tools dependencies
che7pu
Operating system: rosa kde
Сообщение che7pu »
hello.
In ubuntu if you want to build a package from source you should install "apt-get install build-essential checkinstall". this would grab some packages needed for compile job.
What should we install in rosa for get all we need to compile from the source. (right now I am missing rpcgen package which should be with glibc but it isn't).
thanks.
Anaximandar
Operating system: ROSA Desktop Fresh R13.2 LXQt x86_64
Re: installing compiling tools dependencies
Сообщение Anaximandar »
I'm not quite sure, but I think this will help. Install the following packages.
autoconf
automake
pkgconfi
intltool
makedepend
checkinstall
If you want to create RPM packages, also add
rpm-build
Kind regards
Anaximandar
Вернуться в «Desktop»
