New to Rosa - great but last update destroy it
marlenejo
Operating system: Linux Mint 17,7, rosa R7, peppermint 6, windows 7,8,10
Сообщение marlenejo »
Hello,
Install ROSA Lxqt R9 on a netbook Asus EEEpc 1000 and on an older Pentium Duo PC. Installation when without hiccups and both work fine. However I just update both with the latest proposed updates. Sadly both machines are now unusable. The panel of the netbook keep crashing to finally an useless desktop. Same with the PC, panel crash and it return to the login screen.
I am wondering if I should continue using it since it so unreliable.
Re: New to Rosa - great but last update destroy it
It's already fix, switch to console (ctrl+alt+F2) anf update
urpmi --auto-update
marlenejo
Thanks Keleg. Works now. I just pick a bad time to try the distro. Hopefully, the team will be more careful before releasing updates.
Continuing testing ....
Thanks :lol:
R9 is non stable, it first release of new platform.
R8.1 stable release.
Вернуться в «Desktop»
