iwscanner
iwscanner
Не работает
samsung serge # iwscanner
(process:16097): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
QGtkStyle cannot be used together with the GTK_Qt engine.
kdesu(16097)/kdeui (kdelibs): Session bus not found
To circumvent this problem try the following command (with Linux and bash)
export $(dbus-launch)
/usr/bin/iwscanner: строка 3: 16097 Аварийный останов         (слепок снят) kdesu /usr/share/iwscanner/iwscanner.py
samsung serge # gdb iwscanner
GNU gdb (Linaro GDB) 7.7.1_2014.06_1-12 ()
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
warning: /etc/gdbinit.d/gdb-heap.py: Нет такого файла или каталога
"/usr/bin/iwscanner": not in executable format: Формат файла не распознан
(gdb) run
Starting program:
No executable file specified.
Use the "file" or "exec-file" command.
(gdb) bt
No stack.
(gdb) quit
samsung serge #
GDB обновите, 8.0 вышла
А какие программы еще есть для сканирования wifi?
Re: iwscanner
tverskoy писал(а): А какие программы еще есть для сканирования wifi?
linssid
