Makehuman не работает
У нас есть отличная программа для 3D-моделирования человеческого тела - Makehuman. К сожалению, в Росе R9 она не запускается:
$ makehuman
NO VERSION file detected retrieving revision info from HG
NOTICE: Failed to get hg version number from command line: [Errno 2] No such file or directory (This is just a head's up, not a critical error)
NOTICE: Failed to get hg version number using hglib: No module named hglib (This is just a head's up, not a critical error)
NOTICE: Failed to get hg version from file: [Errno 2] No such file or directory: '/usr/share/.hg/cache/tags' (This is just a head's up, not a critical error)
Detected HG revision: r? (UNKNOWN)
Initialized logging
VERSION: 1.0.2 (r? UNKNOWN) [none found]
HG REVISION: r? (UNKNOWN) [none found]
SHORT VERSION: v1.0.2
BASEMESH VERSION: hm08
IS BUILT (FROZEN): No
IS RELEASE VERSION: No
WORKING DIRECTORY: /usr/share/makehuman
HOME LOCATION: /home/atolstoy
SYS.VERSION: 2.7.12 (default, Feb  5 2017, 20:03:30)  [GCC 5.3.1 20160412 (ROSA)]
SYS.PLATFORM: linux2
PLATFORM.MACHINE: x86_64
PLATFORM.PROCESSOR: x86_64
PLATFORM.UNAME.RELEASE: 4.9.20-nrj-desktop-1rosa-x86_64
PLATFORM.LINUX_DISTRIBUTION: ROSA Desktop Fresh R9 2016.1
NUMPY.VERSION: 1.12.0
No OpenGL_accelerate module loaded: No module named OpenGL_accelerate
PYQT.VERSION: 4.8.7
PYQT.SVG_SUPPORT: supported
PYOPENGL.VERSION: 3.1.0
GL.VENDOR: VMware, Inc.
GL.RENDERER: Gallium 0.4 on llvmpipe (LLVM 3.9, 256 bits)
GL.VERSION: 2.1 Mesa 17.1.2
GLSL.VERSION: 1.30
GL.EXTENSION: GL_ARB_multisample enabled (0x samples)
Creating new texture for image data/textures/texture_notfound.png.
GL.EXTENSION: GL_ARB_texture_non_power_of_two enabled
./lib/texture.py:111: FutureWarning: comparison to `None` will result in an elementwise object comparison in the future.
  if pixels == None:
initTexture: 256, 256, False
Setting language to english
shortcuts.ini out of date; ignoring
Theme default version 1.0.0
  File "makehuman.py", line 426, in <module>
    main()
  File "makehuman.py", line 418, in main
    application.run()
  File "./core/mhmain.py", line 1576, in run
    self.start()
  File "./lib/qtui.py", line 663, in start
    self.OnInit()
  File "./core/mhmain.py", line 1558, in OnInit
    self.setTheme("default")
  File "./core/mhmain.py", line 919, in setTheme
    self.log_window.updateView()
  File "./lib/qtui.py", line 618, in updateView
    self.setItemColor(i, log.getLevelColor(ilevel))
  File "./lib/qtgui.py", line 782, in setItemColor
    self.item(row).setForeground(self.getBrush(color))
  File "./lib/qtgui.py", line 746, in getBrush
    cls._brushes[color] = QtGui.QBrush(QtGui.QColor(color))
TypeError: arguments did not match any overloaded call:
  QColor(Qt.GlobalColor): argument 1 has unexpected type 'NoneType'
  QColor(int): too many arguments
  QColor(Any): argument 1 has unexpected type 'NoneType'
  QColor(): argument 1 has unexpected type 'NoneType'
  QColor(int, int, int, alpha: int = 255): argument 1 has unexpected type 'NoneType'
