urpmi memory access error(core dumped)
ALUsoft
Operating system: Rosa Linux Wint7 MAC ....
Сообщение ALUsoft »
Hello
I have a big problem with ROSA Desktop Fresh R8.1 release 2014.1 for x86_64
I want to install plasma5 shell. After some problems, that i fixed i realized that rpmdrake urpmi urpme and other install apps dont go anymore.
If i start urpmq as example.
i7KDE64bit rpm # urpmq -i bash
How can i fix this problem ?
Thanks for help and greetings
Andy
Re: urpmi memory access error(core dumped)
Try reinstall ROSA. It's non-specified bug, may be hardware error.
ALUsoft
Сообщение ALUsoft »
Thank you keleg
In the hardware i changed nothing.
Can i install it over an existing installation, without loosing the data and installed things i have ?
I know better way was i install the newest rosa from iso.
Maybe i do this. But all the software i installed for work was gone and i must all reinstall ..as example rawtherapee, inkscape and my development things.
That was.. i think .. over 15 to 20 softwares i installed.
Greetings
Andy
Вернуться в «Desktop»
