Частое падение firefox
Сегодня Firefox что-то постоянно начал падать:
roman2@roman2-TravelMate-8372 ~ $ firefox
(firefox:18258): GLib-GObject-WARNING **: The property GtkSettings:gtk-menu-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
(firefox:18258): GLib-GObject-WARNING **: The property GtkSettings:gtk-button-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
1471545216519   addons.manager  WARN    Exception calling callback: ReferenceError: Application is not defined (chrome://clickyoutubed/content/clickYoutube_overlay.js:88:5) JS Stack trace: clickYoutubeD</this.checkVer/<@clickYoutube_overlay.js:88:5 < safeCall@AddonManager.jsm:179:5 < makeSafe/<@AddonManager.jsm:195:25 < Handler.prototype.process@Promise-backend.js:937:23 < this.PromiseWalker.walkerLoop@Promise-backend.js:816:7 < this.PromiseWalker.scheduleWalkerLoop/<@Promise-backend.js:750:11 < this.Utils.openWindow@utils.jsm:147:10 < this.Utils.prompt@utils.jsm:280:3 < sm_restorePrompt@SessionManagerHelper.js:744:37 < sm_check_for_crash@SessionManagerHelper.js:679:32 < SessionManagerHelper.observe@SessionManagerHelper.js:243:5 < SessionStartup.prototype._onSessionFileRead@nsSessionStartup.js:135:5 < Handler.prototype.process@Promise-backend.js:937:23 < this.PromiseWalker.walkerLoop@Promise-backend.js:816:7 < this.PromiseWalker.scheduleWalkerLoop/<@Promise-backend.js:750:11
ARTUR: - SHOW
console.error: httptohttps:
  Message: Module `sdk/widget` is not found at resource://gre/modules/commonjs/sdk/widget.js
  Stack:
    CuddlefishLoader/options<.load@resource://gre/modules/commonjs/sdk/loader/cuddlefish.js:79:18
@resource://jid0-ad08rz08inqbntcg20zwy84a73i-at-jetpack/httptohttps/lib/main.js:5:15
run@resource://gre/modules/commonjs/sdk/addon/runner.js:147:19
startup/</<@resource://gre/modules/commonjs/sdk/addon/runner.js:87:9
Handler.prototype.process@resource://gre/modules/Promise-backend.js:937:23
this.PromiseWalker.walkerLoop@resource://gre/modules/Promise-backend.js:816:7
this.PromiseWalker.scheduleWalkerLoop/<@resource://gre/modules/Promise-backend.js:750:11
  Stack:
(process:18776): GLib-CRITICAL **: g_path_get_basename: assertion 'file_name != NULL' failed
(<unknown>:18776): GLib-GObject-WARNING **: The property GtkSettings:gtk-menu-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
(<unknown>:18776): GLib-GObject-WARNING **: The property GtkSettings:gtk-button-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
[Child 18776] WARNING: pipe error (3): Соединение разорвано другой стороной: file /builddir/build/BUILD/firefox-47.0/ipc/chromium/src/chrome/common/ipc_channel_posix.cc, line 448
[Child 18776] ###!!! ABORT: Aborting on channel error.: file /builddir/build/BUILD/firefox-47.0/ipc/glue/MessageChannel.cpp, line 2027
Ошибка сегментирования
roman2@roman2-TravelMate-8372 ~ $ su
Пароль:
roman2-TravelMate-8372 roman2 # hw-probe -all -upload -id galtravhgfhry
Probe for hardware ... Ok
Reading logs ... Ok
Uploaded to DB, Thank you!
Probe URL: https://linux-hardware.org/?probe=c6fabea070
Re: Частое падение firefox
roman2@roman2-TravelMate-8372 ~ $ gdb firefox
GNU gdb (Linaro GDB) 7.7.1_2014.06_1-10 ()
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
warning: /etc/gdbinit.d/gdb-heap.py: Нет такого файла или каталога
Reading symbols from firefox...Missing separate debuginfo for /usr/lib64/firefox-47.0/firefox
Try: urpmf /usr/lib/debug/.build-id/47/34146dda75fcd96ce2c5881b499ad782f71d57.debug
(no debugging symbols found)...done.
(gdb) run
Starting program: /usr/bin/firefox
Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
Try: urpmf /usr/lib/debug/.build-id/df/bbdc4f456fc17e09ddfff2a135c790644c44bc.debug
Missing separate debuginfo for /lib64/libpthread.so.0
Try: urpmf /usr/lib/debug/.build-id/36/c1262afaf4431b6c7cd0268093db50bc94b6be.debug
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Missing separate debuginfo for /lib64/libdl.so.2
Try: urpmf /usr/lib/debug/.build-id/73/0bc6304308c046abf73002ca27113a49a14dd2.debug
Missing separate debuginfo for /lib64/libstdc++.so.6
Try: urpmf /usr/lib/debug/.build-id/d7/d111c1ae77bcb909ba5d0eef0cd1b3f5b9575e.debug
Missing separate debuginfo for /lib64/libm.so.6
Try: urpmf /usr/lib/debug/.build-id/94/934f1c396e29bf1ccb9d7ee8e08b0ef449316a.debug
Missing separate debuginfo for /lib64/libgcc_s.so.1
Try: urpmf /usr/lib/debug/.build-id/bb/68a599f30924ba5668d19fbd66abbc5ebf0951.debug
Missing separate debuginfo for /lib64/libc.so.6
Try: urpmf /usr/lib/debug/.build-id/6a/0bbcace9f3297e710f49a040e5b59beaa57a33.debug
Missing separate debuginfo for /usr/lib64/firefox-47.0/liblgpllibs.so
Try: urpmf /usr/lib/debug/.build-id/f2/cb018c52e458680271763998b0ebc3820c3d07.debug
Missing separate debuginfo for /usr/lib64/firefox-47.0/libmozgtk.so
Try: urpmf /usr/lib/debug/.build-id/ea/66d87bef5183528b02c115287069f102daefbc.debug
Missing separate debuginfo for /usr/lib64/libgtk-3.so.0
Try: urpmf /usr/lib/debug/.build-id/a0/dfedc7cbbc773c188f5258f96ffb7d03337ef5.debug
Missing separate debuginfo for /usr/lib64/libgdk-3.so.0
Try: urpmf /usr/lib/debug/.build-id/14/cd8bbe2acd8f67ef083695a11ccdcfc9deef90.debug
Missing separate debuginfo for /lib64/libgmodule-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/6c/706f77e7539af5393773d2d054a86cce939170.debug
Missing separate debuginfo for /usr/lib64/libpangocairo-1.0.so.0
Try: urpmf /usr/lib/debug/.build-id/3c/735f6caa4f15976ed3fe12c9b99615de052074.debug
Missing separate debuginfo for /usr/lib64/libX11.so.6
Try: urpmf /usr/lib/debug/.build-id/fd/58c741cdfe539f4949ad40e4750b46d6127fb7.debug
Missing separate debuginfo for /usr/lib64/libXi.so.6
Try: urpmf /usr/lib/debug/.build-id/94/fdb99080f9d0976dfe18cddcd01986f3081537.debug
Missing separate debuginfo for /usr/lib64/libXfixes.so.3
Try: urpmf /usr/lib/debug/.build-id/52/7c5015e6f4eb94731fcde29af25cb8fcdad9e4.debug
Missing separate debuginfo for /usr/lib64/libcairo-gobject.so.2
Try: urpmf /usr/lib/debug/.build-id/5e/cc76b7cfb361da06f8d44c866586e47de0de26.debug
Missing separate debuginfo for /usr/lib64/libcairo.so.2
Try: urpmf /usr/lib/debug/.build-id/a4/2e38a9a52afa0813f79915f4deaca20257b325.debug
Missing separate debuginfo for /usr/lib64/libgdk_pixbuf-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/6c/a7f64fa42c9378c9712dabc700a6506c259e17.debug
Missing separate debuginfo for /usr/lib64/libatk-1.0.so.0
Try: urpmf /usr/lib/debug/.build-id/03/558d06ab0383d7bc73c1d31d1c44fb180f1e77.debug
Missing separate debuginfo for /usr/lib64/libatk-bridge-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/32/050018e89c6bf85129bc058880fa4c2b58e95d.debug
Missing separate debuginfo for /usr/lib64/libepoxy.so.0
Try: urpmf /usr/lib/debug/.build-id/6c/b8a845e134b59e68bf887278058fb5f8921105.debug
Missing separate debuginfo for /usr/lib64/libpangoft2-1.0.so.0
Try: urpmf /usr/lib/debug/.build-id/78/e276becae9a4fb5bf308b6136169bdbecb3264.debug
Missing separate debuginfo for /usr/lib64/libpango-1.0.so.0
Try: urpmf /usr/lib/debug/.build-id/74/ecaa136e3ac746d6effe87ab3a616eb4e8f93e.debug
Missing separate debuginfo for /usr/lib64/libfontconfig.so.1
Try: urpmf /usr/lib/debug/.build-id/11/a55f551725c40208613c44c50157feedee6cf7.debug
Missing separate debuginfo for /lib64/libgio-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/56/c681a5ad548c3443b30b28785b4fe56c3f77a1.debug
Missing separate debuginfo for /lib64/libgobject-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/7c/347543fd8f348025848547e7e4a2eb0154b286.debug
Missing separate debuginfo for /lib64/libglib-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/42/b4625a8decaac6e81f93bd37b15605251a5f35.debug
Missing separate debuginfo for /usr/lib64/libXinerama.so.1
Try: urpmf /usr/lib/debug/.build-id/8c/bce987c00aa556695325c1c8cb9f1e31d099ab.debug
Missing separate debuginfo for /usr/lib64/libXrandr.so.2
Try: urpmf /usr/lib/debug/.build-id/1a/41acbbba8db073b2b20cafbefa2a5a5789bf3d.debug
Missing separate debuginfo for /usr/lib64/libXcursor.so.1
Try: urpmf /usr/lib/debug/.build-id/61/166d09073ad2a7b71df1d5e5eb58d1286036a5.debug
Missing separate debuginfo for /usr/lib64/libXcomposite.so.1
Try: urpmf /usr/lib/debug/.build-id/df/92e9f440f2ab0b9ade03a36c291ff7d2337f7c.debug
Missing separate debuginfo for /usr/lib64/libXdamage.so.1
Try: urpmf /usr/lib/debug/.build-id/fe/20966e5594462728669101f49a06fa2b113b0c.debug
Missing separate debuginfo for /usr/lib64/libXext.so.6
Try: urpmf /usr/lib/debug/.build-id/c5/3a0f87a4b98e82f327968df8d253d56be01d68.debug
Missing separate debuginfo for /usr/lib64/libfreetype.so.6
Try: urpmf /usr/lib/debug/.build-id/4b/1835335e069d074240ec4af5eeaba473a1fc17.debug
Missing separate debuginfo for /usr/lib64/libxcb.so.1
Try: urpmf /usr/lib/debug/.build-id/dd/f5b9211c8f6c9029bd4bc62e104e90dff2b0cd.debug
Missing separate debuginfo for /usr/lib64/libpixman-1.so.0
Try: urpmf /usr/lib/debug/.build-id/99/d1053386afa42d54e35e6e914d5a5dc1f2d2c5.debug
Missing separate debuginfo for /usr/lib64/libpng16.so.16
Try: urpmf /usr/lib/debug/.build-id/f8/cd28c85fdd2980f7898c36cc64fb29fefe316a.debug
Missing separate debuginfo for /usr/lib64/libxcb-shm.so.0
Try: urpmf /usr/lib/debug/.build-id/44/83215bae9accbfc1d165881c94d1a04517744a.debug
Missing separate debuginfo for /usr/lib64/libxcb-render.so.0
Try: urpmf /usr/lib/debug/.build-id/da/2f2042680bd7693350edcfe6f1d99a95a5248b.debug
Missing separate debuginfo for /usr/lib64/libXrender.so.1
Try: urpmf /usr/lib/debug/.build-id/1a/c7662a8ff6096be6d33912d43b7da423c04d56.debug
Missing separate debuginfo for /lib64/librt.so.1
Try: urpmf /usr/lib/debug/.build-id/38/f6cc0832ac8bb9e4e0b2a092f4c6d621db2408.debug
Missing separate debuginfo for /usr/lib64/libatspi.so.0
Try: urpmf /usr/lib/debug/.build-id/32/60c66604d32da3da43d085e91135742eaa6bd1.debug
Missing separate debuginfo for /lib64/libdbus-1.so.3
Try: urpmf /usr/lib/debug/.build-id/d7/785cb257de7173ae6af164ddfb44c232245441.debug
Missing separate debuginfo for /usr/lib64/libharfbuzz.so.0
Try: urpmf /usr/lib/debug/.build-id/3a/da36a46273da2fba01ceb1b5b6d751814f65d8.debug
Missing separate debuginfo for /usr/lib64/libxml2.so.2
Try: urpmf /usr/lib/debug/.build-id/55/18a4bcd486df000ed24ad633f0c4fb65645f2c.debug
Missing separate debuginfo for /lib64/libresolv.so.2
Try: urpmf /usr/lib/debug/.build-id/66/42b18cc2818b0e43f7981c71990c8e6eed4422.debug
Missing separate debuginfo for /usr/lib64/libffi.so.6
Try: urpmf /usr/lib/debug/.build-id/f0/84a5b091d2cfbde855f024b250e98e2355f67d.debug
Missing separate debuginfo for /lib64/libpcre.so.1
Try: urpmf /usr/lib/debug/.build-id/a9/4ed84b4d5a741a24ae97759b94dbe2b51a71a7.debug
Missing separate debuginfo for /usr/lib64/libbz2.so.1
Try: urpmf /usr/lib/debug/.build-id/7b/bdec1780e17c4f660cd4f613b96f7163461e7e.debug
Missing separate debuginfo for /usr/lib64/libXau.so.6
Try: urpmf /usr/lib/debug/.build-id/12/a1f43252012def5af5205c3623f7b6550df739.debug
Missing separate debuginfo for /usr/lib64/libXdmcp.so.6
Try: urpmf /usr/lib/debug/.build-id/9e/f2f321989632db141a1f891ffc2623ddb51ecb.debug
Missing separate debuginfo for /usr/lib64/libgraphite2.so.3
Try: urpmf /usr/lib/debug/.build-id/49/120316f7a05bb96b1d088933fa5bb2d07a8400.debug
Missing separate debuginfo for /lib64/liblzma.so.5
Try: urpmf /usr/lib/debug/.build-id/83/ed9cea27a86f9a6471a79ca69d3ff9a01a381d.debug
Missing separate debuginfo for /usr/lib64/firefox-47.0/libxul.so
Try: urpmf /usr/lib/debug/.build-id/e0/a03fbfe568d574fa18ed861291d54f3a439760.debug
Missing separate debuginfo for /lib64/libplds4.so
Try: urpmf /usr/lib/debug/.build-id/ba/9d6b72e97121426d0c0913a879fc18495de710.debug
Missing separate debuginfo for /lib64/libplc4.so
Try: urpmf /usr/lib/debug/.build-id/ee/a52cf6ea98970c12adb742ed242f28e7bfe6db.debug
Missing separate debuginfo for /lib64/libnspr4.so
Try: urpmf /usr/lib/debug/.build-id/77/7e3d02a6880fdc12eea0b74b1608785f9e05fe.debug
Missing separate debuginfo for /lib64/libssl3.so
Try: urpmf /usr/lib/debug/.build-id/6c/27141b81b74504c5da178cf746e47ccb612b22.debug
Missing separate debuginfo for /lib64/libsmime3.so
Try: urpmf /usr/lib/debug/.build-id/44/70a818634b60d84179b7d1ef3164cbaf1a4045.debug
Missing separate debuginfo for /lib64/libnssutil3.so
Try: urpmf /usr/lib/debug/.build-id/17/692c41bf1c70823b5d4393e332a21167cf97fa.debug
Missing separate debuginfo for /lib64/libnss3.so
Try: urpmf /usr/lib/debug/.build-id/72/7e86dc41b42cc7f6eb19c6176b658d1bd48d4c.debug
Missing separate debuginfo for /usr/lib64/libsqlite3.so.0
Try: urpmf /usr/lib/debug/.build-id/97/bc7396aa5258320ad33eea769a979795629c56.debug
Missing separate debuginfo for /usr/lib64/libjpeg.so.8
Try: urpmf /usr/lib/debug/.build-id/5a/126fa60ac2bffe440b3102d29ac0987727be8c.debug
Missing separate debuginfo for /usr/lib64/libasound.so.2
Try: urpmf /usr/lib/debug/.build-id/10/fd46ba005c51a0d3d4375a0d058312271b8731.debug
Missing separate debuginfo for /usr/lib64/libdbus-glib-1.so.2
Try: urpmf /usr/lib/debug/.build-id/71/d860044af9b6be7ab0eb2dd609771710a8a56b.debug
Missing separate debuginfo for /usr/lib64/libstartup-notification-1.so.0
Try: urpmf /usr/lib/debug/.build-id/5b/8f13d04e2a66ada7a920d89643966e0a74ab2f.debug
Missing separate debuginfo for /usr/lib64/libXt.so.6
Try: urpmf /usr/lib/debug/.build-id/11/65ca59ec3c6dce84025e81b39c46cbe6124f08.debug
Missing separate debuginfo for /usr/lib64/libproxy.so.1
Try: urpmf /usr/lib/debug/.build-id/d1/0312904982491e49d71da5a10bf27b18ad8c84.debug
Missing separate debuginfo for /usr/lib64/libxcb-util.so.1
Try: urpmf /usr/lib/debug/.build-id/bc/9d3fa3ea4867910153f62c59d2c1b20da2345b.debug
Missing separate debuginfo for /usr/lib64/libX11-xcb.so.1
Try: urpmf /usr/lib/debug/.build-id/02/46bea8b6c0a5618b7829e17def64b785769228.debug
Missing separate debuginfo for /usr/lib64/libSM.so.6
Try: urpmf /usr/lib/debug/.build-id/ac/af781e0671f2848d506db17c923e8bd06489af.debug
Missing separate debuginfo for /usr/lib64/libICE.so.6
Try: urpmf /usr/lib/debug/.build-id/d8/668df15d6c751cc5fdbf0d073c8ae109b91da8.debug
Missing separate debuginfo for /usr/lib64/libicui18n.so.53
Try: urpmf /usr/lib/debug/.build-id/24/27c30b305cd5a08c276c24935a258565299a32.debug
Missing separate debuginfo for /usr/lib64/libicuuc.so.53
Try: urpmf /usr/lib/debug/.build-id/a6/61b1d076265f8b663288ba5e545cae6121b8d2.debug
Missing separate debuginfo for /usr/lib64/libicudata.so.53
Try: urpmf /usr/lib/debug/.build-id/46/ba310626af937b2de15b6caa6a0a87af641dff.debug
Missing separate debuginfo for /lib64/libgthread-2.0.so.0
Try: urpmf /usr/lib/debug/.build-id/48/f14af073d81376d0ddf21df9d6bb1c6db68851.debug
Detaching after fork from child process 5929.
Missing separate debuginfo for /usr/lib64/gconv/UTF-16.so
Try: urpmf /usr/lib/debug/.build-id/70/2c12a36a49882bbe0b08bf5b8300eb3d2e9ad0.debug
[New Thread 0x7fffe3fd2700 (LWP 5930)]
[Thread 0x7fffe3fd2700 (LWP 5930) exited]
Detaching after fork from child process 5931.
Missing separate debuginfo for /usr/lib64/gtk-3.0/modules/libcanberra-gtk-module.so
Try: urpmf /usr/lib/debug/.build-id/0b/8d099646a6893772dc0ee37b454c9d8f2a9800.debug
Missing separate debuginfo for /usr/lib64/libcanberra-gtk3.so.0
Try: urpmf /usr/lib/debug/.build-id/93/b2d78a4ce35c391020abcbe54c40337cdf6cb7.debug
Missing separate debuginfo for /usr/lib64/libcanberra.so.0
Try: urpmf /usr/lib/debug/.build-id/0d/23c3c5bca5b1a20ac5d7af2b6f57586d2fe6fa.debug
Missing separate debuginfo for /usr/lib64/libvorbisfile.so.3
Try: urpmf /usr/lib/debug/.build-id/9a/7307e6f85ff4638c6f9933c70bcd0406b7a480.debug
Missing separate debuginfo for /usr/lib64/libtdb.so.1
Try: urpmf /usr/lib/debug/.build-id/48/39565e6fda267667068797db3fbc557a7fc451.debug
Missing separate debuginfo for /usr/lib64/libltdl.so.7
Try: urpmf /usr/lib/debug/.build-id/64/f6ce82635bb49511fb8b7e746295d55407f631.debug
Missing separate debuginfo for /usr/lib64/libvorbis.so.0
Try: urpmf /usr/lib/debug/.build-id/ac/8eac7db929068d90a544e89907c7918deb0b85.debug
Missing separate debuginfo for /usr/lib64/libogg.so.0
Try: urpmf /usr/lib/debug/.build-id/e5/49e2fc01e5ca2807136ab32034b6c0f9c8fb60.debug
Missing separate debuginfo for /usr/lib64/gio/modules/libgvfsdbus.so
Try: urpmf /usr/lib/debug/.build-id/4b/d9fe5d2d135543c87a94ad1ae8d370475c9a42.debug
Missing separate debuginfo for /usr/lib64/gvfs/libgvfscommon.so
Try: urpmf /usr/lib/debug/.build-id/88/1fc13d87bbe4041df15bfbef7367bb84ef317d.debug
Missing separate debuginfo for /lib64/libudev.so.1
Try: urpmf /usr/lib/debug/.build-id/d9/1a022d817fa6d90c8df0031cb183af37ec2ddb.debug
[New Thread 0x7fffe3fd2700 (LWP 5932)]
Missing separate debuginfo for /lib64/libnss_mdns4_minimal.so.2
Try: urpmf /usr/lib/debug/.build-id/10/e49ec8dd69536013f453a3d52b97472f467ee8.debug
Missing separate debuginfo for /lib64/libnss_files.so.2
Try: urpmf /usr/lib/debug/.build-id/ae/2129281554827e24e4868a6b88f66c15b8694d.debug
[New Thread 0x7fffe1bf0700 (LWP 5933)]
[New Thread 0x7fffdff61700 (LWP 5934)]
[New Thread 0x7fffdf760700 (LWP 5935)]
Missing separate debuginfo for /usr/lib64/firefox-47.0/browser/components/libbrowsercomps.so
Try: urpmf /usr/lib/debug/.build-id/fe/c6883728727346fd205b441b23f72a0606be74.debug
[New Thread 0x7fffdebe4700 (LWP 5936)]
[New Thread 0x7fffde3e3700 (LWP 5937)]
[New Thread 0x7fffde1e2700 (LWP 5938)]
[New Thread 0x7fffddfe1700 (LWP 5939)]
[New Thread 0x7fffddde0700 (LWP 5940)]
[New Thread 0x7fffddbdf700 (LWP 5941)]
[New Thread 0x7fffdd9de700 (LWP 5942)]
[New Thread 0x7fffdd7dd700 (LWP 5943)]
[New Thread 0x7fffdd5dc700 (LWP 5944)]
[New Thread 0x7fffdbeff700 (LWP 5945)]
Missing separate debuginfo for /usr/lib64/pango/1.8.0/modules/pango-basic-fc.so
Try: urpmf /usr/lib/debug/.build-id/06/7e714788d9b25828456a8af25dcc39382e3781.debug
Missing separate debuginfo for /usr/lib64/libpulse.so.0
Try: urpmf /usr/lib/debug/.build-id/44/c1cbbf29e4106fc25c1cd4187ddd884ad853f2.debug
Missing separate debuginfo for /usr/lib64/pulseaudio/libpulsecommon-8.0.so
Try: urpmf /usr/lib/debug/.build-id/b8/eb61bd11ad38adbd9267204d24e0377b8bfd4b.debug
Missing separate debuginfo for /usr/lib64/libXtst.so.6
Try: urpmf /usr/lib/debug/.build-id/7f/a3d848855aa0ee051292b096221f9da52c8a49.debug
Missing separate debuginfo for /lib64/libsystemd.so.0
Try: urpmf /usr/lib/debug/.build-id/fa/446241fe53ff59cb9cb2a57e68d02b750f3f9e.debug
Missing separate debuginfo for /usr/lib64/libjson-c.so.2
Try: urpmf /usr/lib/debug/.build-id/77/9bc0a619e20158a07fff47dc8edd5bd9753264.debug
Missing separate debuginfo for /lib64/libwrap.so.0
Try: urpmf /usr/lib/debug/.build-id/d4/92a7aa89e05f89bfbee796cd901297fe9a1146.debug
Missing separate debuginfo for /usr/lib64/libsndfile.so.1
Try: urpmf /usr/lib/debug/.build-id/6e/56384a832ed8d9efdd901c28163bbdd43f978f.debug
Missing separate debuginfo for /usr/lib64/libasyncns.so.0
Try: urpmf /usr/lib/debug/.build-id/4f/7a6c95f68cf986e15eaeb45f09146e1cb9ba59.debug
Missing separate debuginfo for /lib64/libcap.so.2
Try: urpmf /usr/lib/debug/.build-id/8e/03ab1474d6e929e675841da6cb33f0a5b16c18.debug
Missing separate debuginfo for /usr/lib64/libgcrypt.so.20
Try: urpmf /usr/lib/debug/.build-id/e2/409d67cba85003feadb62da125096c1a245b9a.debug
Missing separate debuginfo for /lib64/libnsl.so.1
Try: urpmf /usr/lib/debug/.build-id/c6/625a540e906a2743a94658e9a260c78311e2e0.debug
Missing separate debuginfo for /usr/lib64/libFLAC.so.8
Try: urpmf /usr/lib/debug/.build-id/0f/40efde2245b722847ec30517200406ee60f1b9.debug
Missing separate debuginfo for /usr/lib64/libvorbisenc.so.2
Try: urpmf /usr/lib/debug/.build-id/78/595ca133eb490497942418fb9c1722c3a10ce9.debug
Missing separate debuginfo for /lib64/libgpg-error.so.0
Try: urpmf /usr/lib/debug/.build-id/df/b235bf42ab02bd4ce7d7a7eb0a0f720c5a838c.debug
[New Thread 0x7fffe217e700 (LWP 5946)]
[New Thread 0x7fffd8eff700 (LWP 5947)]
Missing separate debuginfo for /lib64/libsoftokn3.so
Try: urpmf /usr/lib/debug/.build-id/e2/48c2e8a7a5aa8b83c61e254f65ea6f00c3b06f.debug
Missing separate debuginfo for /lib64/libnssdbm3.so
Try: urpmf /usr/lib/debug/.build-id/26/3fc0919a9b4544eea6c39f9d40734ef54ac71b.debug
Missing separate debuginfo for /lib64/libfreebl3.so
Try: urpmf /usr/lib/debug/.build-id/17/35156688702442e5d1ccb5c43d3164d7e663bd.debug
Missing separate debuginfo for /lib64/libnssckbi.so
Try: urpmf /usr/lib/debug/.build-id/19/8e090d2679e592c8908df3cfc8871cde558fdb.debug
[New Thread 0x7fffd787c700 (LWP 5948)]
[New Thread 0x7fffd707b700 (LWP 5949)]
[New Thread 0x7fffd5fff700 (LWP 5950)]
[New Thread 0x7fffd47ff700 (LWP 5951)]
[New Thread 0x7fffd32ff700 (LWP 5952)]
[New Thread 0x7fffd25ff700 (LWP 5953)]
[New Thread 0x7fffd0bff700 (LWP 5954)]
[New Thread 0x7fffd03fe700 (LWP 5955)]
[New Thread 0x7fffcfdff700 (LWP 5956)]
Detaching after fork from child process 5957.
(firefox:5925): GLib-GObject-WARNING **: The property GtkSettings:gtk-menu-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
(firefox:5925): GLib-GObject-WARNING **: The property GtkSettings:gtk-button-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
[New Thread 0x7fffccfff700 (LWP 5958)]
Missing separate debuginfo for /usr/lib64/libproxy/0.4.7/modules/config_gnome3.so
Try: urpmf /usr/lib/debug/.build-id/f1/54b0b571adeb6308705a330c5195e97911babc.debug
[New Thread 0x7fffcabe9700 (LWP 5959)]
Missing separate debuginfo for /usr/lib64/libproxy/0.4.7/modules/config_kde4.so
Try: urpmf /usr/lib/debug/.build-id/b3/9c7ee8c24db2f2f6aeaab57d163f6bf09c986c.debug
Missing separate debuginfo for /usr/lib64/libkdecore.so.5
Try: urpmf /usr/lib/debug/.build-id/cc/76e249ae58748acb946e0a6c7d146d0a35929b.debug
Missing separate debuginfo for /usr/lib64/libQtCore.so.4
Try: urpmf /usr/lib/debug/.build-id/0b/6212acc894d6c9c43acc6082c80142b6d2adc8.debug
Missing separate debuginfo for /usr/lib64/libQtNetwork.so.4
Try: urpmf /usr/lib/debug/.build-id/ef/822d1af994d07a4ddbe6cc807690be7fccfa52.debug
Missing separate debuginfo for /usr/lib64/libQtDBus.so.4
Try: urpmf /usr/lib/debug/.build-id/a6/2238f37fde34f421308bcfe35b931319457267.debug
Missing separate debuginfo for /usr/lib64/libfam.so.0
Try: urpmf /usr/lib/debug/.build-id/00/59d50d1f75ebdff52ee647c7ba535e13e6dcf9.debug
Missing separate debuginfo for /usr/lib64/libssl.so.1.0.0
Try: urpmf /usr/lib/debug/.build-id/bd/8545e3ab539964bbd2a7e3306d46332ddcdd0b.debug
Missing separate debuginfo for /usr/lib64/libcrypto.so.1.0.0
Try: urpmf /usr/lib/debug/.build-id/af/917cf76198aa4e80e60457183a4b057740b49b.debug
Missing separate debuginfo for /usr/lib64/libQtXml.so.4
Try: urpmf /usr/lib/debug/.build-id/ab/0d1c6fab5f37fbdce1517b17bb761375a431dc.debug
[New Thread 0x7fffc9eff700 (LWP 5968)]
[New Thread 0x7fffc96fe700 (LWP 5969)]
[New Thread 0x7fffc8bff700 (LWP 5970)]
[New Thread 0x7fffc81ff700 (LWP 5971)]
Missing separate debuginfo for /lib64/libnss_nis.so.2
Try: urpmf /usr/lib/debug/.build-id/00/2568c79aabfc8e1811ebc26b55e845c96c5668.debug
Missing separate debuginfo for /lib64/libnss_dns.so.2
Try: urpmf /usr/lib/debug/.build-id/4f/8ca6321ceb7d179ced505a2c16ee1f449f0132.debug
[Thread 0x7fffd5fff700 (LWP 5950) exited]
[New Thread 0x7fffc72ff700 (LWP 5972)]
[New Thread 0x7fffc64ff700 (LWP 5973)]
[Thread 0x7fffc96fe700 (LWP 5969) exited]
[New Thread 0x7fffc59ff700 (LWP 5974)]
[New Thread 0x7fffc57fe700 (LWP 5975)]
[New Thread 0x7fffc4ffd700 (LWP 5976)]
[New Thread 0x7fffc47fc700 (LWP 5977)]
[New Thread 0x7fffc3ffb700 (LWP 5978)]
[New Thread 0x7fffc37fa700 (LWP 5979)]
[New Thread 0x7fffc2ff9700 (LWP 5980)]
[New Thread 0x7fffc27f8700 (LWP 5981)]
[New Thread 0x7fffc96fe700 (LWP 5982)]
[Thread 0x7fffc9eff700 (LWP 5968) exited]
[New Thread 0x7fffc9eff700 (LWP 5983)]
[New Thread 0x7fffd5fff700 (LWP 5984)]
[Thread 0x7fffd5fff700 (LWP 5984) exited]
[Thread 0x7fffc96fe700 (LWP 5982) exited]
[New Thread 0x7fffc04ff700 (LWP 5985)]
[New Thread 0x7fffc96fe700 (LWP 5986)]
[Thread 0x7fffc9eff700 (LWP 5983) exited]
Missing separate debuginfo for /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
Try: urpmf /usr/lib/debug/.build-id/6f/0ea9c99bea1598813f59851cbe57ed26910458.debug
Missing separate debuginfo for /usr/lib64/librsvg-2.so.2
Try: urpmf /usr/lib/debug/.build-id/24/c60ad0836e4ed2f9d6bc593e939a3d94be6067.debug
Missing separate debuginfo for /usr/lib64/libcroco-0.6.so.3
Try: urpmf /usr/lib/debug/.build-id/f3/a5b64675832c41a305e2ec8619f99e4d259053.debug
[New Thread 0x7fffc9eff700 (LWP 5987)]
[New Thread 0x7fffd5fff700 (LWP 5988)]
[Thread 0x7fffc9eff700 (LWP 5987) exited]
[Thread 0x7fffc96fe700 (LWP 5986) exited]
[New Thread 0x7fffc9eff700 (LWP 5989)]
[Thread 0x7fffd5fff700 (LWP 5988) exited]
Missing separate debuginfo for /usr/lib64/libXss.so.1
Try: urpmf /usr/lib/debug/.build-id/ed/8144eae008e27f4789df18044282c35e4a2c2f.debug
Missing separate debuginfo for /usr/lib64/libcanberra-0.30/libcanberra-pulse.so
Try: urpmf /usr/lib/debug/.build-id/2b/8954d4083f0798e2793a9d2b7c7fee41de4b33.debug
[New Thread 0x7fffd5fff700 (LWP 5990)]
[New Thread 0x7fffc96fe700 (LWP 5991)]
[Thread 0x7fffc9eff700 (LWP 5989) exited]
[New Thread 0x7fffc9eff700 (LWP 5992)]
[New Thread 0x7fffb3eff700 (LWP 5993)]
[New Thread 0x7fffb36fe700 (LWP 5994)]
[New Thread 0x7fffb2efd700 (LWP 5995)]
[New Thread 0x7fffb24ff700 (LWP 5996)]
[New Thread 0x7fffb1cfe700 (LWP 5997)]
[New Thread 0x7fffb14fd700 (LWP 5998)]
[New Thread 0x7fffb0cfc700 (LWP 5999)]
[New Thread 0x7fffb04fb700 (LWP 6000)]
[Thread 0x7fffc96fe700 (LWP 5991) exited]
[Thread 0x7fffb14fd700 (LWP 5998) exited]
[Thread 0x7fffb3eff700 (LWP 5993) exited]
[Thread 0x7fffb24ff700 (LWP 5996) exited]
[Thread 0x7fffb0cfc700 (LWP 5999) exited]
[Thread 0x7fffb2efd700 (LWP 5995) exited]
[Thread 0x7fffb1cfe700 (LWP 5997) exited]
[Thread 0x7fffb36fe700 (LWP 5994) exited]
1471546026104   addons.manager  WARN    Exception calling callback: ReferenceError: Application is not defined (chrome://clickyoutubed/content/clickYoutube_overlay.js:88:5) JS Stack trace: clickYoutubeD</this.checkVer/<@clickYoutube_overlay.js:88:5 < safeCall@AddonManager.jsm:179:5 < makeSafe/<@AddonManager.jsm:195:25 < Handler.prototype.process@Promise-backend.js:937:23 < this.PromiseWalker.walkerLoop@Promise-backend.js:816:7 < this.PromiseWalker.scheduleWalkerLoop/<@Promise-backend.js:750:11 < this.Utils.openWindow@utils.jsm:147:10 < this.Utils.prompt@utils.jsm:280:3 < sm_restorePrompt@SessionManagerHelper.js:744:37 < sm_check_for_crash@SessionManagerHelper.js:679:32 < SessionManagerHelper.observe@SessionManagerHelper.js:243:5 < SessionStartup.prototype._onSessionFileRead@nsSessionStartup.js:135:5 < Handler.prototype.process@Promise-backend.js:937:23 < this.PromiseWalker.walkerLoop@Promise-backend.js:816:7 < this.PromiseWalker.scheduleWalkerLoop/<@Promise-backend.js:750:11
ARTUR: - SHOW
[New Thread 0x7fffb1cfe700 (LWP 6001)]
[New Thread 0x7fffb2efd700 (LWP 6002)]
[New Thread 0x7fffb0cfc700 (LWP 6003)]
[New Thread 0x7fffb14fd700 (LWP 6004)]
[New Thread 0x7fffd3fbe700 (LWP 6282)]
[New Thread 0x7fffacc53700 (LWP 6283)]
[New Thread 0x7fffac452700 (LWP 6284)]
Detaching after fork from child process 6285.
Vector smash protection is enabled.
Failed to open VDPAU backend libvdpau_va_gl.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
[New Thread 0x7fffa83ff700 (LWP 6296)]
[New Thread 0x7fffa79ff700 (LWP 6302)]
[New Thread 0x7fffa71fe700 (LWP 6303)]
[New Thread 0x7fffa69fd700 (LWP 6304)]
[Thread 0x7fffc72ff700 (LWP 5972) exited]
[Thread 0x7fffc64ff700 (LWP 5973) exited]
  Stack:
  Stack:
[New Thread 0x7fffc64ff700 (LWP 6873)]
[New Thread 0x7fffc72ff700 (LWP 6874)]
[New Thread 0x7fffa11ff700 (LWP 6875)]
[New Thread 0x7fffa09fe700 (LWP 6876)]
[New Thread 0x7fff9ffff700 (LWP 6877)]
[New Thread 0x7fff9e3ff700 (LWP 6878)]
[New Thread 0x7fff9dbfe700 (LWP 6879)]
[New Thread 0x7fff9d1ff700 (LWP 6880)]
[New Thread 0x7fff98eff700 (LWP 6896)]
[Thread 0x7fffa11ff700 (LWP 6875) exited]
[New Thread 0x7fffa11ff700 (LWP 6905)]
[Thread 0x7fffa11ff700 (LWP 6905) exited]
Detaching after fork from child process 6906.
[New Thread 0x7fffa11ff700 (LWP 6908)]
(process:6906): GLib-CRITICAL **: g_path_get_basename: assertion 'file_name != NULL' failed
(<unknown>:6906): GLib-GObject-WARNING **: The property GtkSettings:gtk-menu-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
(<unknown>:6906): GLib-GObject-WARNING **: The property GtkSettings:gtk-button-images is deprecated and shouldn't be used anymore. It will be removed in a future version.
[New Thread 0x7fff94cff700 (LWP 6935)]
[New Thread 0x7fff94afe700 (LWP 6936)]
[New Thread 0x7fff948fd700 (LWP 6937)]
Missing separate debuginfo for /usr/lib64/firefox-47.0/libmozavutil.so
Try: urpmf /usr/lib/debug/.build-id/70/998202f9ca874f1bb8d2811b839b6c0d760e6e.debug
Missing separate debuginfo for /usr/lib64/firefox-47.0/libmozavcodec.so
Try: urpmf /usr/lib/debug/.build-id/93/5ab510a2f6796eac9d2f015ba4e4feebdad933.debug
Missing separate debuginfo for /usr/lib64/libspeex.so.1
Try: urpmf /usr/lib/debug/.build-id/fc/0bc9c7691fef8a3b82ab80b0a749acef8b76eb.debug
Missing separate debuginfo for /usr/lib64/libavcodec.so.56
Try: urpmf /usr/lib/debug/.build-id/4e/84976dd37c8748a38e633670385bf5edce01b0.debug
Missing separate debuginfo for /usr/lib64/libswresample.so.1
Try: urpmf /usr/lib/debug/.build-id/09/1d49922fa6a110061cde02561cdfa48cdb82ae.debug
Missing separate debuginfo for /usr/lib64/libavutil.so.54
Try: urpmf /usr/lib/debug/.build-id/5e/050e4df6fb3f764e6d98bf96ab24b1ea1b1354.debug
Missing separate debuginfo for /usr/lib64/libva.so.1
Try: urpmf /usr/lib/debug/.build-id/4b/ccc0426098d1b73fd656d0444568e6c4abbbbc.debug
Missing separate debuginfo for /usr/lib64/libxvidcore.so.4
Try: urpmf /usr/lib/debug/.build-id/73/5f9c225e46b422f01ca824099c1822b7437237.debug
Missing separate debuginfo for /usr/lib64/libx265.so.68
Try: urpmf /usr/lib/debug/.build-id/52/9615b2d955de9f3982c9de49919dcf78ad31c5.debug
Missing separate debuginfo for /usr/lib64/libx264.so.142
Try: urpmf /usr/lib/debug/.build-id/40/3ba8774212b4d7531886f81914ab883b7f1826.debug
Missing separate debuginfo for /usr/lib64/libwavpack.so.1
Try: urpmf /usr/lib/debug/.build-id/d3/03ed4c2c61b114e96bb53b1c71b3f71af09e0d.debug
Missing separate debuginfo for /usr/lib64/libvpx.so.1
Try: urpmf /usr/lib/debug/.build-id/eb/148bd76e3028ee4714894eb03c892d5cb51cd8.debug
Missing separate debuginfo for /usr/lib64/libvo-amrwbenc.so.0
Try: urpmf /usr/lib/debug/.build-id/e6/6183e27df8d6275618091102267b42dd41a922.debug
Missing separate debuginfo for /usr/lib64/libvo-aacenc.so.0
Try: urpmf /usr/lib/debug/.build-id/4b/4ff06b45db6096c11f5e47c7aae8a973c40f37.debug
Missing separate debuginfo for /usr/lib64/libtheoraenc.so.1
Try: urpmf /usr/lib/debug/.build-id/f9/ff8d7dd5e5381d856c16fa348bca6b05a35f4a.debug
Missing separate debuginfo for /usr/lib64/libtheoradec.so.1
Try: urpmf /usr/lib/debug/.build-id/42/8c1b98518383123ccd7adf0d4e6d44866599e5.debug
Missing separate debuginfo for /usr/lib64/libschroedinger-1.0.so.0
Try: urpmf /usr/lib/debug/.build-id/50/265962ae3717e4d86771d39b44eea5c0ac24b7.debug
Missing separate debuginfo for /usr/lib64/libopus.so.0
Try: urpmf /usr/lib/debug/.build-id/34/da95cef6432b1fcdca984828cfdc1972c14842.debug
Missing separate debuginfo for /usr/lib64/libopenjpeg.so.5
Try: urpmf /usr/lib/debug/.build-id/e7/1cc2f06459f0f3b36aff987783ee1d66f72f48.debug
Missing separate debuginfo for /usr/lib64/libopencore-amrwb.so.0
Try: urpmf /usr/lib/debug/.build-id/d1/73f3b3decc26db5e8340eb1ca9e34ff0d21596.debug
Missing separate debuginfo for /usr/lib64/libopencore-amrnb.so.0
Try: urpmf /usr/lib/debug/.build-id/ed/cfa266ac9929f03016168f67f8b0489ab6602a.debug
Missing separate debuginfo for /usr/lib64/libmp3lame.so.0
Try: urpmf /usr/lib/debug/.build-id/91/b8800367f226afdf04cca53a776ed0ec9d347d.debug
Missing separate debuginfo for /usr/lib64/libgsm.so.1
Try: urpmf /usr/lib/debug/.build-id/7c/6b7a72dd3e246776258cf64af33185d227a50b.debug
Missing separate debuginfo for /usr/lib64/libcelt0.so.2
Try: urpmf /usr/lib/debug/.build-id/7c/d91229097beb48392a1388d0dcfe9c74aa9f8e.debug
Missing separate debuginfo for /usr/lib64/libsoxr.so.0
Try: urpmf /usr/lib/debug/.build-id/4a/902a61298ec61f98b2084cb973868c63e8abd0.debug
Missing separate debuginfo for /usr/lib64/liborc-0.4.so.0
Try: urpmf /usr/lib/debug/.build-id/ad/146b41738306341c947f7ef0fe81c3427c4418.debug
[New Thread 0x7fffd01fd700 (LWP 7128)]
[New Thread 0x7fffd01bc700 (LWP 7130)]
[New Thread 0x7fffcf5e5700 (LWP 7133)]
[New Thread 0x7fffcf543700 (LWP 7135)]
[New Thread 0x7fffc96fe700 (LWP 7134)]
[New Thread 0x7fffc96bd700 (LWP 7137)]
[New Thread 0x7fffc967c700 (LWP 7138)]
[New Thread 0x7fff8c148700 (LWP 7139)]
[Thread 0x7fff8c148700 (LWP 7139) exited]
[New Thread 0x7fff8c148700 (LWP 7141)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffc37fa700 (LWP 5979)]
0x00007fffeb3354d9 in ?? () from /usr/lib64/firefox-47.0/libxul.so
(gdb) bi
Undefined command: "bi".  Try "help".
(gdb) bt
#0  0x00007fffeb3354d9 in  () at /usr/lib64/firefox-47.0/libxul.so
#1  0x00007fffeaee7cd7 in  () at /usr/lib64/firefox-47.0/libxul.so
#2  0x00007fffeb06e782 in  () at /usr/lib64/firefox-47.0/libxul.so
#3  0x00007fffeae4ae47 in  () at /usr/lib64/firefox-47.0/libxul.so
#4  0x00007fffeae4fd6a in  () at /usr/lib64/firefox-47.0/libxul.so
#5  0x00007fffeae5166a in  () at /usr/lib64/firefox-47.0/libxul.so
#6  0x00007fffeae1313b in  () at /usr/lib64/firefox-47.0/libxul.so
#7  0x00007fffeae15187 in  () at /usr/lib64/firefox-47.0/libxul.so
#8  0x00007fffeae15f63 in  () at /usr/lib64/firefox-47.0/libxul.so
#9  0x00007fffeae13332 in  () at /usr/lib64/firefox-47.0/libxul.so
#10 0x00007fffeae1319b in  () at /usr/lib64/firefox-47.0/libxul.so
#11 0x00007fffeae1d0d5 in  () at /usr/lib64/firefox-47.0/libxul.so
#12 0x00007fffeae19277 in  () at /usr/lib64/firefox-47.0/libxul.so
#13 0x00007ffff7bc5645 in start_thread () at /lib64/libpthread.so.0
#14 0x00007ffff6ecbdfd in clone () at /lib64/libc.so.6
(gdb) exit
Undefined command: "exit".  Try "help".
(gdb) exite
Undefined command: "exite".  Try "help".
(gdb) quite
Undefined command: "quite".  Try "help".
(gdb) quit
A debugging session is active.
        Inferior 1 [process 5925] will be killed.
Quit anyway? (y or n) n
Not confirmed.
(gdb) exit
Ни разу не упал.
Роман, вы про какую версию Огнелиса пишите?
Если про тестовую, то он и будет падать. Он тесты не прошёл.
Я не понимаю почему тестовый Огнелис не удалят из реп. Я периодически с ним сталкиваюсь. Я ставлю в виртуалке систему, подключаю тестовые репы и естественно тут же ставиться «бракованный» Огнелис. Для меня это не особо актуально, т.к. я пользуюсь Хромиумом. Но, я за то, чтобы удалить из тестовых репозиториев нерабочий Огнелис.
Если вы жалуетесь на тот Огнелис, который в стабильном репозитории, то ищите проблему у себя в компе. Стабильная версия стоит давно и жалоб на неё нет. Скорее всего, у вас проблема в чём-то другом, но это отражается на ФайрФоксе. К тому же, насколько я помню, Бармалей пользуется этим браузером постоянно. И если он пишет, что не падает, значит он проверил.
Версия есть в логах: firefox-47.0
А если запустить с отключенными дополнениями?
firefox -safe-mode
trs писал(а):Версия есть в логах: firefox-47.0
Странно…
Сейчас перепроверил в Виртуалке. Там тестовые репы. Везде 47-ая версия.
Я за номерами Огнелиса не смотрю, т.к. не пользуюсь. Но, если везде одна, значит новую добавили.
nvk
Operating system: ROSA R13
Сообщение nvk »
У меня тоже стоит 47-ая версия. Никаких проблем нет. Все работает без сбоев!
Алзим писал(а):Роман, вы про какую версию Огнелиса пишите?
Не помню откуда. Но могу сказать сразу - с момента когда, только, началась тема про Пятничное тестирование, я включил тестовые репозитории и до сих пор не отключаю... То есть полностью втянут в процесс... :)
firefox -safe-mode
Я не знаю, что вчера было =@ , но сегодня он не падает. При этом обновлений не было
roman2@roman2-TravelMate-8372 ~ $ rpm -qa --last
perf-4.6.7-1-rosa2014.1.x86_64                Ср 17 авг 2016 21:15:39
kernel-nrj-desktop-4.6-devel-latest-4.6.7-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:15:39
kernel-nrj-desktop-4.6.7-1rosa-x86_64-1-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:14:50
kernel-nrj-laptop-4.4.18-1rosa-x86_64-1-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:14:18
kernel-nrj-laptop-4.4-latest-4.4.18-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:14:16
kernel-nrj-desktop-4.6-latest-4.6.7-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:14:16
kernel-headers-4.6.7-1-rosa2014.1.x86_64      Ср 17 авг 2016 21:14:16
kernel-nrj-desktop-devel-4.6.7-1rosa-x86_64-1-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:11:04
kernel-nrj-laptop-devel-4.4.18-1rosa-x86_64-1-1-rosa2014.1.x86_64 Ср 17 авг 2016 21:07:55
cpupower-4.6.7-1-rosa2014.1.x86_64            Ср 17 авг 2016 21:07:55
moc-2.6.0-1.beta2.svn2912.3-rosa2014.1.x86_64 Вт 16 авг 2016 22:20:47
moc-doc-2.6.0-1.beta2.svn2912.3-rosa2014.1.noarch Вт 16 авг 2016 22:20:46
mp3diags-doc-1.3.04-1-rosa2014.1.x86_64       Ср 10 авг 2016 22:28:53
mp3diags-1.3.04-1-rosa2014.1.x86_64           Ср 10 авг 2016 22:28:49
owncloud-client-2.2.3-1-rosa2014.1.x86_64     Ср 10 авг 2016 22:28:41
okularplugin-1.0.1-1-rosa2014.1.x86_64        Ср 10 авг 2016 22:28:41
lib64owncloudsync0-2.2.3-1-rosa2014.1.x86_64  Ср 10 авг 2016 22:28:41
lib64ocsync0-2.2.3-1-rosa2014.1.x86_64        Ср 10 авг 2016 22:28:41
dkms-virtualbox-5.0.26-2-rosa2014.1.x86_64    Ср 10 авг 2016 22:26:59
virtualbox-5.0.26-2-rosa2014.1.x86_64         Ср 10 авг 2016 22:26:44
Видимо у firefox какой-то специфический глюк...
Писали что 47 глюченный, он так и висит в тестинге. Уже 48 вышел, пора его тестить.
Утром час работал - не падал (все настройки одинаковые), вечером час работал - не падал (все настройки одинаковые), писал сюда - нормально, но как, только, зашел на ulmart.ru - тут же упал... и потом еще 3 раза подряд, при попытке загрузить сайт. А ведь и вчера я тоже пытался поработать с на ulmart.ru, но firefox не давал. Случайность или нет, но факт остается фактом.
Barmalei писал(а):Писали что 47 глюченный, он так и висит в тестинге. Уже 48 вышел, пора его тестить.
Просто, возможно, репозиторий 2014.1 - уже законсервирован, а последний firefox там - 47...
Да нет, вроде. У меня без тестингов 46 версия. Тут в пятничном тестировании вроде писали что 47 глючный.
PS. Вот нашел http://forum.rosalab.ru/viewtopic.php?f ... 600#p74487
firefox может быть одинаковой версии, но дополнения у всех наверняка разные. Например, про 1-Click YouTube Video Download пишут: «Работает с Firefox 3.6 - 45.*».
Бармолей, Firefox 48.0.1 уже вышла. http://www.opennet.ru/opennews/art.shtml?num=44998
48.0 тоже глюченная. http://bugs.rosalinux.ru/show_bug.cgi?id=7259
Да они совсем не глючные.
Просто это у нас так при сборке получается.
Я пользуюсь только сборками с оффсайта.
Там нет никаких проблем.
Ни с работой, ни с локализацией.
Скачал архив, распаковал в скрытую папку и в меню изменил кнопку запуска
на бинарник в этой папке.
И сделал симлинк ~/.mozilla/plugins на /usr/lib64/mozilla/plugins
Наш собирается с привязкой к системным файлам, а этот работает автономно.
При выходе новой версии просто заменяю файлы в этой папке на файлы из нового архива.
И переустановить очень легко, если хочешь погонять другую версию.
Скачал любую версию, так как доступы все когда либо вышедшие, и заменил файлы.
Сейчас посмотрю 48.0.1 http://archive.mozilla.org/pub/firefox/ ... x86_64/ru/
З.Ы.
Что интересно, наша сборка Firefox всегда открывает abf на английском,
и переходит на русский после входа.
Версия с оффсайта открывает всегда на русском.
И кстати, seamonkey не обновляется, потому что вроде не собирается версия x86_64,
но если скачать x86_64 отсюда https://download-installer.cdn.mozilla. ... 1/contrib/
и так-же распаковать и добавить в меню, и установить русскую локализацию seamonkey-2.9.1.ru.langpack.xpi
из https://download-installer.cdn.mozilla. ... /langpack/
то отлично работает.
VictorR2007 писал(а):Да они совсем не глючные.
Виктор, я знаю, что Огнелис хорошо работает на той же Винде и на других системах.
Но, я стараюсь пользоваться росиными сборками.
Если он для РОСЫ не собирается по нормальному, значит для меня он глюченный. :)
К тому же, выход минорной версии ради исправления ошибок, тоже о чём-то говорит.
Алзим писал(а):К тому же, выход минорной версии ради исправления ошибок, тоже о чём-то говорит.
Ясно, что ошибки есть и постоянно идёт их исправление.
Как и во всех других программах.
Я от том, что разработка и сборка firefox, это их постоянная и основная работа.
Они хорошо знают код, и у них получаются отлично скомпиленные программы.
У нас же нужно привязывать к системным либам.
Потом накладывается 10 патчей.
Не всегда программа получается хорошо собранной.
Да и проявляющиеся в наших сборках проблемы с переводом говорят
о каких-то проблемах в собранной программе.
Но если не гоняться за новыми версиями, то вполне пойдёт и наша любая стабильная сборка. :)
VictorR2007 писал(а): Но если не гоняться за новыми версиями, то вполне пойдёт и наша любая стабильная сборка. :)
Виктор, я уверен, что вы лучше меня знаете как переводиться слово Фрешь (Fresh). :)
В РОСЕ Фрешь, как и в Федоре, чем новее, тем лучше. :)
А в остальном я с вами полностью согласен.
Скачал 48.0.1 - распокавал в папку в /home/roman/ - запустил firefox-bin - работает, причем он через синхронизацию, подтянул и учетку и дополнения и пароли...
Осталось сделать ссылку на рабочий стол...
Галахов Роман писал(а):Скачал 48.0.1 - распокавал в папку в /home/roman/ - запустил firefox-bin - работает, причем он через синхронизацию, подтянул и учетку и дополнения и пароли...
Я всегда указываю для запуска firefox, но похоже они являются дублями с firefox-bin.
А подтягивает старый профиль из-за того, что Firefox всегда использует файлы профиля в ~/.mozilla/firefox
Не важно, откуда он установлен, профиль всегда в одном месте.
Тоже закинул 48, работает отлично.
