R8 Install aborts: copying files (rsync) failed with code 23
rolf
Operating system: ROSA Desktop.Fresh release 2012.1 (Desktop) for x86_64
Сообщение rolf »
[rolf@p8z68 2016.1]$ md5sum -c ROSA.FRESH.KDE.R8.x86_64.iso.md5sum
ROSA.FRESH.KDE.R8.x86_64.iso: OK
After choosing a single reiserfs partition for / and activating a swap partition, installation proceeds with the copy progress bar reaching almost to the end. Then, a screen appears with the message, "Copying files (rsync) failed with code 23". Pushing the OK button causes a reboot.
This is the result for both a verified dvd burn of the iso and dd to flash card in a usb reader. Following instructions at bug 5751, where I've reported more details of my attempts, here are the contents of files_copy_error.log:
[rolf@z170i ~]$ cat files_copy_error.log
rsync: set_acl: sys_acl_set_file(var/log/journal, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(var/log/journal/af838596440e426ab64d5c865b18ac85, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(var/log/journal/af838596440e426ab64d5c865b18ac85/.system.journal.fTovUn, ACL_TYPE_ACCESS): Operation not supported (95)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at /builddir/build/BUILD/rsync-3.1.1/main.c(1165) [sender=3.1.1]
[rolf@z170i ~]$
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
