PHP not working
prabhuchelladurai
Operating system: ubuntu 14.04
PHP not working
Сообщение prabhuchelladurai »
I am trying to install magestead in ROSA R7.
I have installed LAMP using 'Install & Remove Software'
when I issued the command 'php -ini | grep intl' it says 'bash: php: command not found'
when i try to install php using 'urpmi php' it says
'Unknown option: upgrade
Package php-cgi-5.6.22-2-rosa2014.1.x86_64 is already installed'
what is the problem? how can i solve it?
Thanks.
Re: PHP not working
Install php-cli package, it should help.
prabhuchelladurai
Re: PHP not working
Oh thank you very much bro.. thanks a lot... it works!!!
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
