Падает docky
Joker
Operating system: Rosa Fresh
Падает docky
Сообщение Joker »
Запускается она нормально, но как только пытаешся её настроить -она падает!
$ docky
[Info  14:18:46.280] Docky version: 2.1.4 Release
[Info  14:18:46.282] Kernel version: 4.1.19.3
[Info  14:18:46.282] CLR version: 4.0.30319.17020
[Error 14:18:46.386] [SystemService] Could not initialize power manager dbus: 'Could not load type 'Docky.Services.SystemService+IUPowerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'Docky.Services.SystemService+IUPower'.'
[Info  14:18:46.386] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
  at System.Reflection.Emit.TypeBuilder.CreateType () [0x00000] in <filename unknown>:0
  at DBus.TypeImplementer.GetImplementation (System.Type declType) [0x00000] in <filename unknown>:0
  at DBus.BusObject.GetObject (DBus.Connection conn, System.String bus_name, DBus.ObjectPath object_path, System.Type declType) [0x00000] in <filename unknown>:0
  at DBus.Connection.GetObject (System.Type type, System.String bus_name, DBus.ObjectPath path) [0x00000] in <filename unknown>:0
  at DBus.Connection.GetObject[IUPower] (System.String bus_name, DBus.ObjectPath path) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeBattery () [0x00000] in <filename unknown>:0
[Error 14:18:46.388] [SystemService] Could not initialize Network Manager dbus: 'Could not load type 'Docky.Services.SystemService+INetworkManagerProxy' from assembly 'DBus.Proxies, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' because it is implements the inaccessible interface 'Docky.Services.SystemService+INetworkManager'.'
[Info  14:18:46.388] [SystemService]   at System.Reflection.Emit.TypeBuilder.CreateTypeInfo () [0x00000] in <filename unknown>:0
  at DBus.Connection.GetObject[INetworkManager] (System.String bus_name, DBus.ObjectPath path) [0x00000] in <filename unknown>:0
  at Docky.Services.SystemService.InitializeNetworkManager () [0x00000] in <filename unknown>:0
[Info  14:18:46.394] [ThemeService] Setting theme: Classic
[Warn  14:18:46.406] [DesktopItemService] Could not find remap file '/home/lesha/.local/share/docky/remaps.ini'!
[Info  14:18:46.493] [DockServices] Dock services initialized.
[Info  14:18:46.596] [PluginManager] Loaded "Trash".
[Fatal 14:18:46.749] [GLib] Source ID 73 was not found when attempting to remove it
[Fatal 14:18:46.750] [GLib] Source ID 76 was not found when attempting to remove it
[Fatal 14:18:46.750] [GLib] Source ID 72 was not found when attempting to remove it
Cairo.Surface is leaking, programmer is missing a call to Dispose
Set MONO_CAIRO_DEBUG_DISPOSE to track allocation traces
[Info  14:18:58.941] [PluginManager] Loaded "Docky.Widgets,1.0".
Exception in Gtk# callback delegate
  Note: Applications can use GLib.ExceptionManager.UnhandledException to handle the exception.
System.TypeInitializationException: An exception was thrown by the type initializer for Docky.ConfigurationWindow ---> System.DllNotFoundException: libgnome-desktop-2.so.17
  at (wrapper managed-to-native) Gnome.DesktopItem:gnome_desktop_item_new_from_file (intptr,int,intptr&)
  at Gnome.DesktopItem.NewFromFile (System.String file, DesktopItemLoadFlags flags) [0x00000] in <filename unknown>:0
  at Docky.ConfigurationWindow.get_AutoStart () [0x00000] in <filename unknown>:0
  at Docky.ConfigurationWindow..ctor () [0x00000] in <filename unknown>:0
  at Docky.ConfigurationWindow..cctor () [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at Docky.Items.DockyItem.<OnGetMenuItems>m__7A (System.Object o, System.EventArgs a) [0x00000] in <filename unknown>:0
  at Docky.Menus.MenuItem.SendClick () [0x00000] in <filename unknown>:0
  at Docky.Menus.MenuItemWidget.OnButtonReleaseEvent (Gdk.EventButton evnt) [0x00000] in <filename unknown>:0
  at Gtk.Widget.buttonreleaseevent_cb (IntPtr widget, IntPtr evnt) [0x00000] in <filename unknown>:0
   at GLib.ExceptionManager.RaiseUnhandledException(System.Exception e, Boolean is_terminal)
   at Gtk.Widget.buttonreleaseevent_cb(IntPtr widget, IntPtr evnt)
   at Gtk.Application.gtk_main()
   at Gtk.Application.Run()
   at Docky.Docky.Main(System.String[] args)
[Fatal 14:18:59.039] [GLib] Source ID 113 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 119 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 143 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 145 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 117 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 148 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 163 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 149 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 112 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 161 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 118 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 157 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 130 was not found when attempting to remove it
[Fatal 14:18:59.039] [GLib] Source ID 115 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 140 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 153 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 124 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 138 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 134 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 132 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 137 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 126 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 146 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 116 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 165 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 159 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 175 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 128 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 412 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 136 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 150 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 173 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 167 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 171 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 151 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 180 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 409 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 155 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 169 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 93 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 94 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 40 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 61 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 105 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 110 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 62 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 88 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 41 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 77 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 84 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 78 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 74 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 81 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 67 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 85 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 79 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 86 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 89 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 16 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 25 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 43 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 83 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 64 was not found when attempting to remove it
[Fatal 14:18:59.040] [GLib] Source ID 101 was not found when attempting to remove it
Unhandled Exception:
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for Docky.ConfigurationWindow ---> System.DllNotFoundException: libgnome-desktop-2.so.17
Joker
Re: Падает docky
Сообщение Joker »
Паставил пакет libgnome-desktop-2.so.17
Вроде как оно стало нормально относительно настроек
