utorrent for Linux
utorrent for Linux
Есть utorrent для ubuntu https://utorrent.info/utorrent-dlya-linux/ захотелось посмотреть, что за программа
Там указание "Запускаем под рутом папку, где лежит utserver и запускаем его. Далее в браузере идем по адресу http://localhost:8080/gui/"
Попробовал в chroot - Rosabootstrap, но не смог разобраться как консольно запустить utserver:
roman-TravelMate-8372 roman # cd /home/roman/files/ROSABOOTSTRAP/06.02.16/rosabootstrap-master/ROSA
roman-TravelMate-8372 ROSA # chroot ./ /bin/bash
roman-TravelMate-8372 / # urpmi --auto-select --auto-update
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "ru_RU.UTF-8",
        LC_ALL = (unset),
        LC_PAPER = "ru_RU.UTF-8",
        LC_ADDRESS = "ru_RU.UTF-8",
        LC_MONETARY = "ru_RU.UTF-8",
        LC_NUMERIC = "ru_RU.UTF-8",
        LC_TELEPHONE = "ru_RU.UTF-8",
        LC_MESSAGES = "ru_RU.UTF-8",
        LC_IDENTIFICATION = "ru_RU.UTF-8",
        LC_COLLATE = "ru_RU.UTF-8",
        LC_MEASUREMENT = "ru_RU.UTF-8",
        LC_CTYPE = "ru_RU.UTF-8",
        LC_TIME = "ru_RU.UTF-8",
        LC_NAME = "ru_RU.UTF-8",
        LANG = "ru_RU.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Can't read /proc/self/mountinfo: No such file or directory
medium "Main" is up-to-date
medium "Main Updates" is up-to-date
medium "Main32" is up-to-date
medium "Main32 Updates" is up-to-date
medium "Contrib" is up-to-date
medium "Contrib Updates" is up-to-date
medium "Non-free" is up-to-date
medium "Non-free Updates" is up-to-date
medium "Non-free32" is up-to-date
medium "Non-free32 Updates" is up-to-date
medium "Restricted" is up-to-date
medium "Restricted Updates" is up-to-date
medium "Restricted32" is up-to-date
medium "Restricted32 Updates" is up-to-date
Packages are up to date
roman-TravelMate-8372 / # exit
exit
roman-TravelMate-8372 ROSA # mc
roman-TravelMate-8372 home # rosa
Команда rosa не найдена. Возможно, имелось в виду:
  Команда 'ros' из пакета пакет 'librouteros' (main)
roman-TravelMate-8372 home # su
roman-TravelMate-8372 home # cd /home/roman/files/ROSABOOTSTRAP/06.02.16/rosabootstrap-master/ROSA
roman-TravelMate-8372 / # mc
bash: mc: command not found
roman-TravelMate-8372 / # cd /home/roman/files/ROSABOOTSTRAP/06.02.16/rosabootstrap-master/ROSA/home/utorrent-server-alpha-v3_3/
bash: cd: /home/roman/files/ROSABOOTSTRAP/06.02.16/rosabootstrap-master/ROSA/home/utorrent-server-alpha-v3_3/: No such file or directory
roman-TravelMate-8372 / # cd /home/utorrent-server-alpha-v3_3/
roman-TravelMate-8372 utorrent-server-alpha-v3_3 # utserver
bash: utserver: command not found
roman-TravelMate-8372 utorrent-server-alpha-v3_3 # sh utserver
utserver: utserver: cannot execute binary file
roman-TravelMate-8372 utorrent-server-alpha-v3_3 # sh utserver.sh
sh: utserver.sh: No such file or directory
roman-TravelMate-8372 utorrent-server-alpha-v3_3 # chmod rwx utserver
chmod: invalid mode: 'rwx'
Try 'chmod --help' for more information.
roman-TravelMate-8372 utorrent-server-alpha-v3_3 # chmod --help
Usage: chmod [OPTION]... MODE[,MODE]... FILE...
  or:  chmod [OPTION]... OCTAL-MODE FILE...
  or:  chmod [OPTION]... --reference=RFILE FILE...
Change the mode of each FILE to MODE.
With --reference, change the mode of each FILE to that of RFILE.
  -c, --changes          like verbose but report only when a change is made
  -f, --silent, --quiet  suppress most error messages
  -v, --verbose          output a diagnostic for every file processed
      --no-preserve-root  do not treat '/' specially (the default)
      --preserve-root    fail to operate recursively on '/'
      --reference=RFILE  use RFILE's mode instead of MODE values
  -R, --recursive        change files and directories recursively
      --help     display this help and exit
      --version  output version information and exit
Each MODE is of the form '[ugoa]*([-+=]([rwxXst]*|[ugo]))+|[-+=][0-7]+'.
Report chmod bugs to bug-coreutils@gnu.org
GNU coreutils home page: <http://www.gnu.org/software/coreutils/>
General help using GNU software: <http://www.gnu.org/gethelp/>
Report chmod translation bugs to <http://translationproject.org/team/>
For complete documentation, run: info coreutils 'chmod invocation'
roman-TravelMate-8372 utorrent-server-alpha-v3_3 # chmod 777 utserver
Какой командой это делается?
Проброс портов из chroot, как я понял идет автоматически.
Не очень хочется давать тестируемой программе полномочия в основной системе.
thunderamur
Operating system: Rosa Fresh
Re: utorrent for Linux
Сообщение thunderamur »
utorrent вообще опустился после одного известного скандала. Но после фразы "запускаем торентокачалку под рутом", я бы про него вообще забыл.
Virtualbox заюзай и не мучайся.
awl
Сообщение awl »
Роман, а какие особые преимущества имеет μtorrent перед другими линуксовыми торрент-клиентами (Ktorrent, qBittorrent etc.)?
OMNE NIMIUM NOCET
awl писал(а):Роман, а какие особые преимущества имеет μtorrent перед другими линуксовыми торрент-клиентами (Ktorrent, qBittorrent etc.)?
Я просто хотел попробовать - это сервер на java, значит независим от Linux окружения, да и по описанию - распакуй в папку/ запусти сервер - войди на его web страницу - должен быть очень легок в установке/настройке... Не понравилось - стер папку и все. Но это в теории, а на практике надо пробовать.
thunderamur писал(а):Virtualbox заюзай и не мучайся.
Устанавливать/настраивать - больше времени уйдет, чем с chroot, да и дополнительные 10-15 gb на диске нужно найти . Я уже думал про Vbox - надо будет найти время провести тесты там.
Если надо качалку с возможностью "войти на его web страницу", то MLDonkey вроде как поддерживает BitTorrent. Про "независим от Linux окружения" не вполне понятно, но тоже работает и на других ОС.
mlnet_strings.ru_RU.UTF-8.gz
руссификация - поместить содержимое архива в папку ~/.mldonkey
(34.32 КБ) 1065 скачиваний
trs писал(а):Если надо качалку с возможностью "войти на его web страницу", то MLDonkey вроде как поддерживает BitTorrent. Про "независим от Linux окружения" не вполне понятно, но тоже работает и на других ОС.
Надо будет посмотреть. Но я, в прошлом сообщении, забыл упомянуть, еще одно преимущество utorrent/Deluge/Ktorrent - параллельная работа с несколькими загрузками/раздачами, что не умеет, например, transmission. Надо будет проверить это в MLDonkey.
Установил Utorrent на NAS
Неделю работает хорошо.
tolya
Operating system: linux
Сообщение tolya »
С год назад устанавливал сие поделие... работает хорошо... но пользоваться им крайне не удобно... Доступна либо консоль, либо веб-интерфейс... Кому это надо???
Берёте "старый" системник или ноутбук и делаете торрент-качалку с доступом по сети, можно с подключением к ТВ, и пульт ДУ припаять. :)
tolya
Сообщение tolya »
trs писал(а):Берёте "старый" системник или ноутбук и делаете торрент-качалку с доступом по сети, можно с подключением к ТВ, и пульт ДУ припаять. :)
Только если так использовать, да и то, есть же нормальные торрент-клиенты в репозитории, qbittorrent или та же трансмиссия умеют через веб-интерфейс работать.
