проблеммы с quicksynergy
vvpnet
Сообщение vvpnet »
Не как не могу заставить работать quicksynergy. Компьютеры по имени пингуються.
Вывод сервера rosa r7
$ quicksynergy
(quicksynergy:28486): Gtk-CRITICAL **: IA__gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
[2016-01-28T09:07:32] DEBUG: opening configuration ".quicksynergy/synergy.conf"
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/synergy/ServerApp.cpp,229
[2016-01-28T09:07:32] DEBUG: configuration read successfully
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/synergy/ServerApp.cpp,240
[2016-01-28T09:07:32] DEBUG: plugins dir: /home/vpopov/.synergy/plugins
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/arch/unix/ArchPluginUnix.cpp,51
[2016-01-28T09:07:32] DEBUG: can't open plugins dir: /home/vpopov/.synergy/plugins
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/arch/unix/ArchPluginUnix.cpp,59
[2016-01-28T09:07:32] DEBUG: XOpenDisplay(":0")
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/platform/XWindowsScreen.cpp,920
[2016-01-28T09:07:32] DEBUG: xscreensaver window: 0x00000000
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/platform/XWindowsScreenSaver.cpp,346
[2016-01-28T09:07:32] DEBUG: screen shape: 0,0 2960x1050 (xinerama)
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/platform/XWindowsScreen.cpp,150
[2016-01-28T09:07:32] DEBUG: window is 0x08400004
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/platform/XWindowsScreen.cpp,151
[2016-01-28T09:07:32] DEBUG: adopting new buffer
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/base/EventQueue.cpp,180
[2016-01-28T09:07:32] DEBUG: opened display
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/synergy/Screen.cpp,49
[2016-01-28T09:07:32] DEBUG: registered hotkey ScrollLock (id=ef14 mask=0000) as id=1
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/platform/XWindowsScreen.cpp,748
[2016-01-28T09:07:32] NOTE: started server, waiting for clients
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/synergy/ServerApp.cpp,549
[2016-01-28T09:07:32] DEBUG: event queue is ready
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/base/EventQueue.cpp,118
[2016-01-28T09:07:32] DEBUG: add pending events to buffer
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/base/EventQueue.cpp,120
[2016-01-28T09:07:32] DEBUG: screen "vpopov-PC-LinuxRosa" shape changed
/builddir/build/BUILD/synergy-1.7.4-stable/src/lib/server/Server.cpp,1194
Вывод клиента rosa r6
$ quicksynergy
(quicksynergy:19509): Gtk-CRITICAL **: IA__gtk_widget_set_sensitive: assertion 'GTK_IS_WIDGET (widget)' failed
[2016-01-28T09:08:21] DEBUG: plugins dir: /home/vpopov/.synergy/plugins
[2016-01-28T09:08:21] DEBUG: can't open plugins dir: /home/vpopov/.synergy/plugins
[2016-01-28T09:08:21] DEBUG: XOpenDisplay(":0")
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 53 (X_CreatePixmap)
Value in failed request: 0x0
Serial number of failed request: 16
Current serial number in output stream: 17
Сервер вроде как работает с ubuntu ходит на rosa.
А с rosa на rosa не как - может кто что подскажет...
vvpnet
Re: проблеммы с quicksynergy
Сообщение vvpnet »
Ребята нужна эта программа, на ubunte работает на росе нет. У кого есть возможность поэкспериментируйте можно даже в виртуальной машине испробовать!
vvpnet
Сообщение vvpnet »
Работает только между kde R7 и lxqt(r6), вообщем пришлось переехать на lxqt так с KDE4 конфиликтует(не работает)
vvpnet
Сообщение vvpnet »
Еще заметил что при длительной работе убивает GUI KDE4
