No More Room in Hell в Steam
tiberiy0
Operating system: rosa frech r5
Сообщение tiberiy0 »
Появляется экран загрузки и через несколько секунд вылет
Game update: AppID 224260 "No More Room in Hell", ProcID 2588, IP 0.0.0.0:0
ERROR: ld.so: object '/home/dmitriy/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pid 2590 != 2589, skipping destruction (fork without exec?)
Generating new string page texture 119: 384x256, total string texture memory is 3,33 MB
SDL video target is 'x11'
Installing breakpad exception handler for appid(gameoverlayui)/version(20151214111647)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number
Using Breakpad minidump system. Version: 0 AppID: 224260
Setting breakpad minidump AppID = 224260
Using breakpad crash handler
Forcing breakpad minidump interfaces to load
Looking up breakpad interfaces from steamclient
Calling BreakpadMiniDumpSystemInit
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198047962728 [API loaded yes]
Steam_SetMinidumpSteamID: Setting Steam ID: 76561198047962728
Did not detect any valid joysticks.
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dbg.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dbg.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen stdshader_dbg.so error=stdshader_dbg.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dx6.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dx6.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen stdshader_dx6.so error=stdshader_dx6.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dx7.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dx7.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen stdshader_dx7.so error=stdshader_dx7.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dx8.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/stdshader_dx8.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen stdshader_dx8.so error=stdshader_dx8.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/nmrih/bin/game_shader_dx6.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/nmrih/bin/game_shader_dx6.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/nmrih/bin/game_shader_dx6.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/nmrih/bin/game_shader_dx6.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/game_shader_dx6.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/game_shader_dx6.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen game_shader_dx6.so error=game_shader_dx6.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/nmrih/bin/game_shader_dx7.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/nmrih/bin/game_shader_dx7.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/nmrih/bin/game_shader_dx7.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/nmrih/bin/game_shader_dx7.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/game_shader_dx7.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/game_shader_dx7.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen game_shader_dx7.so error=game_shader_dx7.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/nmrih/bin/game_shader_dx8.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/nmrih/bin/game_shader_dx8.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/nmrih/bin/game_shader_dx8.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/nmrih/bin/game_shader_dx8.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen /home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/game_shader_dx8.so error=/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/bin/game_shader_dx8.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
failed to dlopen game_shader_dx8.so error=game_shader_dx8.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога
This system supports the OpenGL extension GL_EXT_framebuffer_object.
This system supports the OpenGL extension GL_EXT_framebuffer_blit.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample.
This system DOES NOT support the OpenGL extension GL_APPLE_fence.
This system DOES NOT support the OpenGL extension GL_NV_fence.
This system supports the OpenGL extension GL_ARB_sync.
This system supports the OpenGL extension GL_EXT_draw_buffers2.
This system supports the OpenGL extension GL_EXT_bindable_uniform.
This system DOES NOT support the OpenGL extension GL_APPLE_flush_buffer_range.
This system supports the OpenGL extension GL_ARB_map_buffer_range.
This system supports the OpenGL extension GL_ARB_vertex_buffer_object.
This system supports the OpenGL extension GL_ARB_occlusion_query.
This system DOES NOT support the OpenGL extension GL_APPLE_texture_range.
This system DOES NOT support the OpenGL extension GL_APPLE_client_storage.
This system DOES NOT support the OpenGL extension GL_ARB_uniform_buffer.
This system supports the OpenGL extension GL_ARB_vertex_array_bgra.
This system supports the OpenGL extension GL_EXT_vertex_array_bgra.
This system supports the OpenGL extension GL_ARB_framebuffer_object.
This system DOES NOT support the OpenGL extension GL_GREMEDY_string_marker.
This system supports the OpenGL extension GL_ARB_debug_output.
This system supports the OpenGL extension GL_EXT_direct_state_access.
This system DOES NOT support the OpenGL extension GL_NV_bindless_texture.
This system supports the OpenGL extension GL_AMD_pinned_memory.
This system DOES NOT support the OpenGL extension GL_EXT_framebuffer_multisample_blit_scaled.
This system supports the OpenGL extension GL_EXT_texture_sRGB_decode.
This system DOES NOT support the OpenGL extension GL_NVX_gpu_memory_info.
This system supports the OpenGL extension GL_ATI_meminfo.
This system supports the OpenGL extension GL_EXT_texture_compression_s3tc.
This system DOES NOT support the OpenGL extension GL_EXT_texture_compression_dxt1.
This system DOES NOT support the OpenGL extension GL_ANGLE_texture_compression_dxt3.
This system DOES NOT support the OpenGL extension GL_ANGLE_texture_compression_dxt5.
This system supports the OpenGL extension GL_ARB_buffer_storage.
This system DOES NOT support the OpenGL extension GLX_EXT_swap_control_tear.
OpenGL: AMD Radeon HD 7700 Series 4.4.13372 Compatibility Profile Context 15.101.1001 (4.4.13372)
GL_NV_bindless_texture: DISABLED
GL_AMD_pinned_memory: DISABLED
GL_ARB_buffer_storage: NOT AVAILABLE
GL_EXT_texture_sRGB_decode: AVAILABLE
GL_NVX_gpu_memory_info: UNAVAILABLE
GL_ATI_meminfo: AVAILABLE
GL_ATI_meminfo: GL_TEXTURE_FREE_MEMORY_ATI: Total Free: 1836160, Largest Avail: 1674096, Total Aux: 1698526, Largest Aux Avail: 8192
GL_MAX_SAMPLES_EXT: 8
CShaderDeviceMgrBase::GetRecommendedConfigurationInfo: CPU speed: 3000 MHz, Processor: GenuineIntel
GlobalMemoryStatus: 3706716160
IDirect3DDevice9::Create: BackBufWidth: 1366, BackBufHeight: 768, D3DFMT: 3, BackBufCount: 1, MultisampleType: 0, MultisampleQuality: 0
GL sampler object usage: DISABLED
##### swap interval = 0 swap limit = 1 #####
Could not load program cache file glbaseshaders.cfg
Could not find base GL shader cache file
Could not load program cache file glshaders.cfg
Could not find user GL shader cache file
Precache: Took 0 ms, Vertex 0, Pixel 0
server.so loaded for "No More Room in Hell"
Game removed: AppID 224260 "No More Room in Hell", ProcID 2592
/home/dmitriy/.local/share/Steam/steamapps/common/nmrih/sdk/hl2.sh: строка 67: 2592 Ошибка сегментирования (слепок снят) ${GAME_DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Nemial
Operating system: ROSA Linux
Re: No More Room in Hell в Steam
Сообщение Nemial »
Судя по логам, можно сказать, что не поддерживаются некоторые расширения OpenGL. А на каком драйвере видеокарты вы запускаете игру?
tiberiy0
Nemial писал(а):Судя по логам, можно сказать, что не поддерживаются некоторые расширения OpenGL. А на каком драйвере видеокарты вы запускаете игру?
И на свободном и на fglrx
возможно, просто видюха не тянет?
tiberiy0
keleg писал(а):возможно, просто видюха не тянет?
Тянет.Щас SUSE стоит,на ней на свободном работает норм.
попробуйте еще рецепт из http://forum.rosalab.ru/viewtopic.php?f ... eam#p63118
Вернуться в «Игры и Steam»
