Rosa desktop R6 - проблемы со звуком [решено]
Общение и разговоры
Amino
Operating system: Rosa desktop R6
Сообщение Amino »
Доброго психического здоровья!
Мне оно не помешало бы.
Неделю как пользую Rosa Desktop К6...точнее она меня пользует и в хвост и в гриву.
Собсна во что сейчас уперся рогом
vitamin@ROSA-PC ~ $ sudo lspci |grep Audio
[sudo] пароль для vitamin:
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
vitamin@ROSA-PC ~ $ sudo alsactl -v
alsactl version 1.1.0
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
00:02.0 VGA compatible controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.1 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 2
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIB (ICH10) LPC Interface Controller
00:1f.2 IDE interface: Intel Corporation 82801JI (ICH10 Family) 4 port SATA IDE Controller #1
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
00:1f.5 IDE interface: Intel Corporation 82801JI (ICH10 Family) 2 port SATA IDE Controller #2
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 02)
03:00.0 IDE interface: JMicron Technology Corp. JMB368 IDE controller
Как видим грит что у мну intel audio .... Я не спорю мож оно и так но ток - разевает рот но вот чето не поет.
Под виндой присутствовал еще и Realtek через который собсно и пело.
вызываю PulseAudio - фиктивное устройство и все.
Настройку оборудования - там только snd_hda_intel а вот snd_hda_codec_realtek - отсутствует.
выручайте братцы - все бубны что были изорвал а новых не завезли
Re: Rosa desktop R6
Здравствуйте! Этих сведений, возможно, будет не достаточно для разработчиков. Лучше сделайте HW-probe и полученную ссылку выложите в эту тему.
Amino
Rosa desktop R6
Сообщение Amino »
Готова
vitamin@ROSA-PC ~ $ hw-probe -all -upload -id PC_NAME
Probe for hardware ... Ok
Reading logs ... Ok
Uploaded to DB, Thank you!
Probe URL: https://linux-hardware.org/?probe=1bbd200c3d
Я прально понял что это в базу занесено теперь?
А дальше....
Re: Rosa desktop R6
а pavucontrol на вкладке "конфигурация" все устройства видит?
Amino
Re: Rosa desktop R6
Сообщение Amino »
pavucontrol ..... Хм.....вызвал тоже что и PulseAudio - фиктивное устройство и более никаких устройство
Re: Rosa desktop R6
Насколько я понял в пробе не видно звукового контроллера вообще.
У него видно только HDMI и Display Port звук.
euspectre
Re: Rosa desktop R6
Сообщение euspectre »
Barmalei писал(а):Насколько я понял в пробе не видно звукового контроллера вообще.
Контроллер виден:
pci:8086-3a3e-1849-0888 » 04-03 detected sound snd_hda_intel Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
Модули snd_hda* загружены. Судя по journalctl, какие-то звуковые устройства обнаружены. Где-то дальше проблема.
Amino
Re: Rosa desktop R6
Сообщение Amino »
Может я не правильно это понимаю?
Re: Rosa desktop R6
Дайте этот экран вашего pavucontrol
Re: Rosa desktop R6
Контроллер виден:
Это HD Audio Controller для дисплей порт я так понял.
Не знаю как в Линь выглядет, но у меня на Вынь есть AMD HD Audio Controller который встает с дровами видео и Realtek 6 канальный.
Вот у него этот Realtek не видно.
Я еще специально просмотрел пробы десктопов в вашей базе и у многих по 2 sound.
Последний раз редактировалось Barmalei 15 дек 2015, 10:35, всего редактировалось 1 раз.
Amino
Re: Rosa desktop R6
Сообщение Amino »
Re: Rosa desktop R6
keleg писал(а):Дайте этот экран вашего pavucontrol
А у меня почему то на буке не кажет HDMI. Или нужно шнур воткнуть чтобы показало?
Re: Rosa desktop R6
а если со старым ядром перегрузиться? И еще, alsamixer по F6 что кажет?
Amino
Re: Rosa desktop R6
Сообщение Amino »
keleg писал(а):а если со старым ядром перегрузиться? И еще, alsamixer по F6 что кажет?
и вам - доброе утро.
я наверно не совсем точно выразился - я начинающий линуксо вод и это мой первый линух так, что старых ядер у мну нет.
P.S это все программа - импорта замещения. Будь она не ладна :(
Amino
Re: Rosa desktop R6
Сообщение Amino »
Люди Ау..... Слухать хотца
Re: Rosa desktop R6
1) про ядра. Если вы ставили с релизного образа, а потом обновлялись, то в начальном меню загрузки можно выбрать загрузку со старым ядром. Попробуйте.
2) Запустите в konsole alsamixer и нажмите там f6 - какие карты покажет?
Amino
Re: Rosa desktop R6
Сообщение Amino »
[quote="keleg"]1) про ядра. Если вы ставили с релизного образа, а потом обновлялись, то в начальном меню загрузки можно выбрать загрузку со старым ядром. Попробуйте.
Таки да есть в меню - дополнительные блаблабла там два пункта 1) linux 4.1.13 и 2) linux 3.14.44
запускал оба и в обоих
2) Запустите в konsole alsamixer - vitamin@ROSA-PC ~ $ alsamixer
cannot open mixer: Нет такого файла или каталога
и хотелось по подробнее в этом месте ибо про alsa курил во многих местах но так и не понял - как вызвать и где вооще оно если пишется что pulseaudio вместо
Re: Rosa desktop R6
Amino писал(а): - vitamin@ROSA-PC ~ $ alsamixer
Упс... а вот в этом месте сломано. Альсамиксер точно есть в образе, где-то вы что-то снесли.
Так, а если в лайв-режиме с флэшки загрузиться - есть ли там звук и работает ли alsamixer?
Попробуйте для этого образ с обновлениями, http://file-store.rosalinux.ru/api/v1/f ... 60e9b297d9
Amino
Re: Rosa desktop R6
Сообщение Amino »
На данный момент я уже дома как бы...но могу поклясться, что ничего не сносил....
возможно я не правильно действовал при установки системы.
после первой загрузки я прошел в систему и сделал обновление. не помню чтоб там сообщало, что придется снести чегото ибо не совместимо.
но как вариант - возможно.
остается вопрос -как все вернуть на круги своя если это всеж произошло
Amino
Re: Rosa desktop R6
Сообщение Amino »
Зашел в управление программами.
Набрал alsamixer.
Нет такого приложения.....есть другие но установка ни к чему положительному не привела.
Вычитал вот на сайте
" Включить звук с AlsaMixer
1. Откройте терминал и выполните следующую команду:
alsamixer
Если AlsaMixer не установлен, то установите его с помощью следующей команды:
sudo apt-get install gnome-alsamixer"
Установил таки да
Вот результат
vitamin@ROSA-PC ~ $ gnome-alsamixer
(process:15999): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::sm-connect after class was initialised
(process:15999): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::show-crash-dialog after class was initialised
(process:15999): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::display after class was initialised
(process:15999): GLib-GObject-WARNING **: Attempt to add property GnomeProgram::default-icon after class was initialised
Amino
Re: Rosa desktop R6
Сообщение Amino »
keleg писал(а): Альсамиксер точно есть в образе, где-то вы что-то снесли.
Есть еще такой вопрос..... Если я снес то фаил конфигурации тоже удаляется или остается? - alsa-base.conf
этого файла нет там где должен быть /etc/modprobe.d/
Re: Rosa desktop R6
Это смотря как сносить :-)
Amino
Re: Rosa desktop R6
Сообщение Amino »
keleg писал(а): Это смотря как сносить :-)
Очевидно жеж - не преднамеренно
Amino
Re: Rosa desktop R6
Сообщение Amino »
keleg писал(а): Попробуйте для этого образ с обновлениями, http://file-store.rosalinux.ru/api/v1/f ... 60e9b297d9
И так. Все сделал но как грится от перемены ничего не изменилось кроме сноса всего, что настроил до этого.
Хотелось бы чтоб это того стоило
А пока вот скрин как просили
Re: Rosa desktop R6
Ну я просил ведь просто в лайве загрузиться и посмотреть, для этого что-то сносить было необязательно.... Ладно, давайте тогда пробу еще раз.
Re: Rosa desktop R6
keleg писал(а):Ну я просил ведь просто в лайве загрузиться и посмотреть, для этого что-то сносить было необязательно.... Ладно, давайте тогда пробу еще раз.
Задам тут вопрос.
Вот у меня звук на десктопе
1. VIA VT1708S High Definition Audio - тут она как snd_hda_intel и SBx00 Azalia (Intel HDA)
2. Sound Display Port Radeon - тут она как snd_hda_intel и Redwood HDMI Audio [Radeon HD 5000 Series]
Почему для разных производителей Интел? Они что чип Интел используют? Или в этом все заключено Intel® High Definition Audio Specification?
Amino
Rosa desktop R6
Сообщение Amino »
keleg писал(а):Ну я просил ведь просто в лайве загрузиться.
А че так можно было? :shock: Мне не предложил при загрузке ...или я неправильно прочел :(
URL пробы: https://linux-hardware.org/?probe=11d8aa58b6
Rosa desktop R6
Не прочитали. Тут от R5 но и на R6 так же.
Re: Rosa desktop R6
Кодека 2 - Codec: Realtek ALC888 и Codec: Intel Eaglelake HDMI, а устройство 1 только.
Re: Rosa desktop R6
Barmalei писал(а): Почему для разных производителей Интел? Они что чип Интел используют? Или в этом все заключено Intel® High Definition Audio Specification?
Пока писал, сами же и ответили. Стандарт High Definition Audio. По-видимому, часть программного кода для оборудования универсальна.
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а): Не прочитали. Тут от R5 но и на R6 так же.
Слепошарый че..... тренировка будет :D
Re: Rosa desktop R6
У меня на буке нет HDMI в звуках, это то что нет проприетарных дров?
Amino
Re: Rosa desktop R6
Сообщение Amino »
Так что жеж делать то братцы ...ннадо поставить дрова на ALC888
Re: Rosa desktop R6
Amino писал(а):Так что жеж делать то братцы ...ннадо поставить дрова на ALC888
Ждать специалистов. Насколько я понял это она и есть. (ICH10 Family) HD Audio Controller
HDMI нету.
Давно было но вот так решали проблему. У нас в базе не нашел такого Intel Corporation 82801JI. http://gentoo.ru/node/23330
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а):.....нашел такого Intel Corporation 82801JI. http://gentoo.ru/node/23330
Тут gentu предлогаешь а я вот порыл и ubutu ...все бы нечего но больно слова - страшные и незнакомые
Кто бы это - http://aptget.org/2011/07/14/alsa-alsac ... ek-alc888/ - применительно к Rosa растолковал
Amino
Re: Rosa desktop R6
Сообщение Amino »
Порывшись в инете прихожу к выводу, что это очень распространенная хрень. И в suse и ubuntu и в gentu (это только то что я встретил и запомнил) все одна и таже [thm - вместо realteka определяется intel hdmi и народ правит ручками. Не понимаю - а изначально это - невозможно корректно ставить?
P.S Я щас взорвусь как триста тон тротила....открываю редактор соединений а там - пусто...вчера там было соединение и сеть не трогал....сейчас вроде сеть есть но изменить IP например - не могу ибо редактировать - нечего
Re: Rosa desktop R6
Все то что пишут устарело кроме одного. Там alsa предлагают обновить, но у нас уже намного новее той что там.
Единственное что можно попробовать это создать файл
/etc/asound.conf и в него вписать
pcm.!default {
type hw
card Intel
ctl.!default {
type hw
card Intel
или
pcm.!default {
type pulse
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а): Единственное что можно попробовать это создать файл
Впишем...да не вопрос...но например моя не понимай......а Rosa понимай?
P.S/ это ток теперь в понедельник смогу проверить.
Re: Rosa desktop R6
Попытка не пытка. По моему должна понимать, нашел в alsa.conf
@hooks [
func load
files [
@func concat
strings [
{ @func datadir }
"/alsa.conf.d/"
"/etc/asound.conf"
"~/.asoundrc"
errors false
По этому конфигу тут более подробнее http://xbmc.ru/wiki/index.php?title=%D0 ... _asound.rc
По этому описанию нужно в консоли ввести aplay -l
найти свою карту и вписать наверное не card Intel, а card х и device х, хотя можно и оба варианта по очереди.
Например
pcm.!default {
type hw
card 0
device 3
ctl.!default {
type hw
card 0
device 3
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а): Попытка не пытка. По моему должна понимать, нашел в alsa.conf
Тоже порыл в этом направлении....хм.....народ грит, что это имеет смысл только если
aplay -l чего то отображает отличное от - device_list:268: no soundcards found...
может я чего неправильно понял?
Amino
Re: Rosa desktop R6
Сообщение Amino »
....И в третий раз закинул невод.....переустановил RosA
А воз и ныне там.
Ох и веселое жеж это занятие - звук извлекать. Дурдом мля
vitamin@ROSA-PC ~ $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Я так понимаю что это уже совсем близко к желанному звуку?
Re: Rosa desktop R6
Amino писал(а):....И в третий раз закинул невод.....переустановил RosA
А воз и ныне там.
Subdevices: 1/1
Subdevices: 1/1
Пробуйте файл /etc/asound.conf
pcm.!default {
type hw
card 0
device 0
ctl.!default {
type hw
card 0
device 0
У меня при таком раскладе само автоматом работает.
aplay -l
card 0: PCH [HDA Intel PCH], device 0: CX20757 Analog [CX20757 Analog]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а): Пробуйте файл /etc/asound.conf
Если это все что там должно быть - то - не работает нефига
Re: Rosa desktop R6
pavucontrol сейчас тоже ничего не показует?
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а): pavucontrol сейчас тоже ничего не показует?
Кажит вот
Re: Rosa desktop R6
Кажит вот
А если нажать на этот HDMI есть там еще что? Если есть Аналоговый, то выбирайте и слушайте.
Amino
Re: Rosa desktop R6
Сообщение Amino »
Barmalei писал(а): А если нажать на этот HDMI есть там еще что? Если есть Аналоговый, то выбирайте и слушайте.
Ну конечно жеж ... как я сам не догадалсязаглянул во все складки....тьфу блин...вкладки :)
...и ничего там ни нашел и только надпись на дверях оставил...
Amino
Re: Rosa desktop R6
Сообщение Amino »
Чудеса да и только....пригрозил ему что снесу нах все и болванку в шредер отправлю....включаю с утреца и обо на - список нарисовался. Да много так всего нарисовалось аж глаза разбегаются...не далеко правда ибо напротив всех пунктов - не подключено красуется
Amino
Re: Rosa desktop R6
Сообщение Amino »
УРААААААААА! ЗАРАБОТАЛАААА!
В общем - вырубил....зашел в BIOS - вырубил звук..... Загрузил......снова вырубил......в BIOS - врубил звук....загрузил и О чудо
ВСЕМ СПАСИБО, ЧТО НЕ ОСТАВИЛИ БЕЗ ВНИМАНИЯ.
P/S Как тут темы закрываются?
Re: Rosa desktop R6
Amino писал(а):УРААААААААА! ЗАРАБОТАЛАААА!
Добавьте в название темы [решено].
Amino
Re: Rosa desktop R6
Сообщение Amino »
Галахов Роман писал(а): Добавьте в название темы [решено].
Я как то склонен думать что это - Impossible. ибо в FAQ и на форме не наблюдаю таких button которые жамкаются с этой целью.
Если че то я слепошарый :)
Re: Rosa desktop R6
зачем жамкать-то? Нажимаешь на изменить и правишь заголовок. Тут по старинке все, ручками :-)
Amino
Re: Rosa desktop R6 - проблемы со звуком [решено]
Сообщение Amino »
Решено то решено..НО.....
Не до конца как оказалось.
При подключении в разъем на front panel или external ports(кому как нравится) звука - нет.
Подскажите где чего жамкнуть чтобы было
Вернуться в «Курилка»
