[SOLVED] Failed python-requests update
Mayavimmer
Operating system: Rosa Fresh 2012.1 64bit
Сообщение Mayavimmer »
My R6 64-bit fails to update python-requests:
# LC_ALL=C urpmi python-requests
    $MIRRORLIST: media/contrib/updates/python-requests-2.7.0-1-rosa2014.1.noarch.rpm
installing python-requests-2.7.0-1-rosa2014.1.noarch.rpm from /var/cache/urpmi/rpms
Preparing...                     ###########################################################################################################################
      1/1: python-requests       ###########################################################################################################################
error: unpacking of archive failed on file /usr/lib/python2.7/site-packages/requests/packages/chardet: cpio: rename failed - Is a directory
ERROR: 'unpack' failed for python-requests-2.7.0-1-rosa2014.1.noarch:
EDIT 2015-10-22: Double fault! Not only does it not work, but when attempting to update with MandrivaUpdate it fails silently. Normal fault behavior should be to pop an error dialog, like it does on my other two, still broken, updates: apache and ncurses.
NOTE: The error message from the urpmi attempt is more useful than that of MandrivaUpdate, indicating that /usr/lib/python2.7/site-packages/requests/packages/chardet is a directory.
# LC_ALL=C MandrivaUpdate
error: unpacking of archive failed on file /usr/lib/python2.7/site-packages/requests/packages/chardet: cpio: rename failed - Resource temporarily unavailable
EDIT 2015-10-23: SOLVED, it works now.
Последний раз редактировалось Mayavimmer 23 окт 2015, 12:04, всего редактировалось 1 раз.
Mayavimmer
Re: Failed python-requests update
Added EDIT 2015-10-22
d_uragan
Сообщение d_uragan »
Will be fixed soon with rebuild of python-requests package. A quick workaround is to remove python-requests manually without any dependencies ("sudo rpm -e --nodeps python-requests") and then launching update again.
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
