[SOLVED] ROSA R6 NetworkManager - MATE
dareksmok
i5-4570 CPU @ 3.20GHz
NVIDIA GeForce GT 1030
8 GB RAM
Сообщение dareksmok »
Hello
Fresh R6 ROSA installed KDE on your computer. In the next step doinstalowałem environment mat.
Unfortunately, after starting the environment MATE I could not connect to the Internet.
The solution was to install the package: networkmanager-applet
Install Howto
1 Enable ROSA Main repository on Install and Remove Software"
Update packages list:
2 # urpmi.update -a
Install networkmanager-applet rpm package:
3 # urpmi networkmanager-applet
http://pkgs.org/rosa-2012.1/rosa-main-r ... 6.rpm.html
Network-manager-applet is a system tray applet which lets you easily connect to different networks. It is created for GNOME's notification area but it also works for other desktop environments which provide a system tray like KDE or XFCE. It displays the available networks and allows to easily switch between them. For encrypted networks it will prompt the user for the key/passphrase and it can optionally store them in the gnome-keyring.
You should also add the applet to autostart
System-> Preferences-> Startup programs
 nm-applet
What to install a mate environment: http://pkgs.org/download/task-mate
1 Enable ROSA Contrib repository on Install and Remove Software"
2 # urpmi.update -a
Install task-mate rpm package:
3 # urpmi task-mate
ROSA Fresh R10 MATE - 64 bit
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
