Krusader взбрыкнул
Arbichev
Operating system: openSUSE 12.3 x86_64
Krusader взбрыкнул
Сообщение Arbichev »
Понадобилось забэкапить хоум на внешний диск. Подключил диск и запускаю копирование через крусадер. Ругается, что у вас нет прав на запись в эту папку. Хорошо, запускаю терминал и запускаю крусадер от рута. И тут вылезает вот такое
[root@Lenovo-G550 admin]# krusader
krusader(23023)/kdeui (kdelibs): Session bus not found
To circumvent this problem try the following command (with Linux and bash)
export $(dbus-launch)
[root@Lenovo-G550 admin]# export $(dbus-launch)
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
kbuildsycoca4 running...
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.sheet.binary.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.addin.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.slideshow.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.sheet.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.presentation.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-word.template.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.template.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.template.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-word.document.macroEnabled.12"
kbuildsycoca4(30235) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.slide.macroEnabled.12"
QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
X Error: BadWindow (invalid Window parameter) 3
  Major opcode: 20 (X_GetProperty)
  Resource id:  0x1c0001a
  Resource id:  0x1c00048
  Resource id:  0x1c0005a
  Resource id:  0x1c00040
QDBusObjectPath: invalid path ""
  Resource id:  0x1c000fe
  Resource id:  0x1c0019a
  Resource id:  0x1c00108
  Resource id:  0x1c001cd
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.sheet.binary.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.addin.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.slideshow.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.sheet.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.presentation.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-word.template.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.template.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.template.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-word.document.macroEnabled.12"
krusader(30224) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.slide.macroEnabled.12"
Сколько я раньше ни запускал крусадер от рута, никогда такого не было! Что ему не так?
Re: Krusader взбрыкнул
Не работает он из консоли. А от рутта я запускаю с иконки в меню. У меня работает.
может, через su - (с минусом) нужно запускать?
keleg писал(а):может, через su - (с минусом) нужно запускать?
Так работает.
