problem of move files
Mr.MoMo
Operating system: Rosa Fresh R6
Сообщение Mr.MoMo »
Hello
First I would like to thank you for this beautiful distribution
Secondly, I have a problem I hope that you will help me in fix it
It is that the disk is divided into two parts I can not move files between parts the files in the system partition only home I can move files in the same parts and other part I can not move files just can view
mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
devtmpfs on /dev type devtmpfs (rw,nosuid,size=4036792k,nr_inodes=1009198,mode=75 5)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode =000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /sys/fs/cgroup type tmpfs (rw,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_age nt=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/bfqio type cgroup (rw,nosuid,nodev,noexec,relatime,bfqio)
/dev/sda1 on / type ext4 (rw,noatime,data=ordered)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=300,minproto=5,m axproto=5,direct)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime,mode=755)
mqueue on /dev/mqueue type mqueue (rw,relatime)
tmpfs on /tmp type tmpfs (rw)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
gvfsd-fuse on /run/user/500/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=500,group_id=500 )
/dev/sda5 on /media/senator/82c3a39e-c2fa-4091-bd8b-895564642adb type ext4 (rw,nosuid,nodev,relatime,data=ordered,uhelper=udi sks2)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
Re: problem of move files
please, send hw-probe after error. The probe include logs and configuration.
Mr.MoMo
Сообщение Mr.MoMo »
I tried to open the file as Root
I can edit and move files
How can I move files without Root ?
Mayavimmer
Operating system: Rosa Fresh 2012.1 64bit
Сообщение Mayavimmer »
Looks like you have a permissions problem -- not Rosa's fault. Your question could perhaps be best handled on a generic Linux forum like Stackoverflow.
Anyway try checking that the folder/directory you are moving the files to is writeable by your user. You can do that from Dolphin by right clicking on the folder and then clicking on properties.
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
