edit SimpleWelcome
euphonious
Operating system: Rosa Desktop Fresh 2014.1
edit SimpleWelcome
Сообщение euphonious »
How can I edit the SimpleWelcome menu/launcher so that I may add an entry that was not generated automatically?
ShalokShalom
Operating system: ROSA
Re: edit SimpleWelcome
Сообщение ShalokShalom »
You install something and the launcher dont appear ?
Then restart, if the issue stays then, please note, which app ?
Or do you mean, how to add something personal ?
Right click on start button/edit?
euphonious
The specific scenario I am referring to is when I download a binary that is not in the repos (e.g., Mendeley) or I need a newer package than what is in the repos (e.g., Praat). I would like to add a launcher to the SimpleWelcome menu.
euphonious
keleg писал(а):Right click on start button/edit?
Thank you. I feel stupid for not knowing that. It's the same way the kicker menu is edited.
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
