I'd like to update this page: https://trac.ffmpeg.org/wiki/Downstreams
What versions of ffmpeg are the currently support ROSA releases using, and what are the EOL dates for these releases?
Thanks.
						End of Life (EOL) Dates
Re: End of Life (EOL) Dates
ROSA 2014.1 uses ffmpeg 2.5.x now. EOL is correct: "fall, 2016".Uelen писал(а):I'd like to update this page: https://trac.ffmpeg.org/wiki/Downstreams
ROSA 2012.1 uses ffmpeg 2.1.x. It's no longer officially supported release so you can move it to "End-of-life releases" table. EOL is 08.10.2014, when ROSA 2014.1 was released.
Updated. Thanks for the info and quick reply.
