SuperTuxKart
tolya
Operating system: linux
SuperTuxKart
Сообщение tolya »
Привет ребята, после обновленя SuperTuxKart до версии 0.9.1 игра вылетает во время загрузки.У меня одного так???
вот лог...
bash-4.3$ supertuxkart
[verbose  ] main: Error messages and other text output will be logged to /home/tolya/.config/supertuxkart/0.8.2/stdout.log.
[info   ] [FileManager]: Data files will be fetched from: '/usr/share/games/supertuxkart/data/'
[info   ] [FileManager]: User directory is '/home/tolya/.config/supertuxkart/0.8.2/'.
[info   ] [FileManager]: Addons files will be stored in '/home/tolya/.local/share/supertuxkart/addons/'.
[info   ] [FileManager]: Screenshots will be stored in '/home/tolya/.cache/supertuxkart/screenshots/'.
[info   ] [FileManager]: User-defined grand prix will be stored in '/home/tolya/.local/share/supertuxkart/grandprix/'.
[info   ] [FileManager]: Asset 0 will be loaded from '/usr/share/games/supertuxkart/data/challenges/'.
[info   ] [FileManager]: Asset 1 will be loaded from '/usr/share/games/supertuxkart/data/fonts/'.
[info   ] [FileManager]: Asset 2 will be loaded from '/usr/share/games/supertuxkart/data/gfx/'.
[info   ] [FileManager]: Asset 3 will be loaded from '/usr/share/games/supertuxkart/data/grandprix/'.
[info   ] [FileManager]: Asset 4 will be loaded from '/usr/share/games/supertuxkart/data/gui/'.
[info   ] [FileManager]: Asset 5 will be loaded from '/usr/share/games/supertuxkart/data/library/'.
[info   ] [FileManager]: Asset 6 will be loaded from '/usr/share/games/supertuxkart/data/models/'.
[info   ] [FileManager]: Asset 7 will be loaded from '/usr/share/games/supertuxkart/data/music/'.
[info   ] [FileManager]: Asset 8 will be loaded from '/usr/share/games/supertuxkart/data/tracks/'.
[info   ] [FileManager]: Asset 9 will be loaded from '/usr/share/games/supertuxkart/data/sfx/'.
[info   ] [FileManager]: Asset 10 will be loaded from '/usr/share/games/supertuxkart/data/shaders/'.
[info   ] [FileManager]: Asset 11 will be loaded from '/usr/share/games/supertuxkart/data/skins/'.
[info   ] [FileManager]: Asset 12 will be loaded from '/usr/share/games/supertuxkart/data/textures/'.
[info   ] [FileManager]: Asset 13 will be loaded from '/usr/share/games/supertuxkart/data/po/'.
[verbose  ] translation: Env var LANGUAGE = 'ru_RU.UTF-8:ru'.
[verbose  ] translation: Language 'Russian (Russia'.
Adding language fallback ru
Irrlicht Engine version 1.8.0
Linux 3.14.39-nrj-desktop-4rosa-i586 #1 SMP PREEMPT Thu Apr 23 12:56:42 UTC 2015 i686
[warn   ] [IrrDriver Temp Logger]: Level 2: X Error: GLXBadFBConfig
[warn   ] [IrrDriver Temp Logger]: Level 2: From call : unknown
[info   ] IrrDriver: OpenGL version: 2.1
[info   ] IrrDriver: OpenGL vendor: Intel Open Source Technology Center
[info   ] IrrDriver: OpenGL renderer: Mesa DRI Intel(R) 965GM x86/MMX/SSE2
[info   ] IrrDriver: OpenGL version string: 2.1 Mesa 10.5.3
[warn   ] irr_driver: Using the fixed pipeline (old GPU, or shaders disabled in options)
[warn   ] [IrrDriver Temp Logger]: Level 2: PNG warning: iCCP: known incorrect sRGB profile
[info   ] GUIEngine: scale: 0.512000
[info   ] player_manager: A new players.xml file will be created.
[info   ] GrandPrixManager: Loading Grand Prix files from /usr/share/games/supertuxkart/data/grandprix/
[info   ] GrandPrixManager: Loading Grand Prix files from /home/tolya/.local/share/supertuxkart/grandprix/
[warn   ] Irrlicht: PNG warning: iCCP: profile 'ICC profile': 1000000h: invalid rendering intent
[warn   ] Irrlicht: PNG warning: iCCP: known incorrect sRGB profile
[warn   ] EventHandler: Error while loading kart 'Adiumy':
[warn   ] EventHandler: Error while loading kart 'Amanda':
[warn   ] EventHandler: Error while loading kart 'Emule':
[warn   ] EventHandler: Error while loading kart 'Gavroche':
Убито
bash-4.3$
Re: SuperTuxKart
У меня она не вылетала, но для комфортной игры пришлось её заново настроить, иначе стала притормаживать (видимо, из-за радикального обновления движка в версии 0.9).
В данном случае, возможно, надо как-то изменить настройки графики (чтобы игра не ругалась на "Using the fixed pipeline (old GPU, or shaders disabled in options)").
tolya
Re: SuperTuxKart
Сообщение tolya »
Pulfer писал(а):У меня она не вылетала, но для комфортной игры пришлось её заново настроить, иначе стала притормаживать (видимо, из-за радикального обновления движка в версии 0.9).
Покапался в конфигах,поставил всё на минимум...Игра запустилась...
После запуска появилось сообщение что версия OpenGL устарела,надо минимум 3.1...
Как обновить???
Re: SuperTuxKart
tolya писал(а):Покапался в конфигах,поставил всё на минимум...Игра запустилась...
Как обновить???
Смотрите в настройках рабочего стола
Но, тут уже зависит от видеокарты... Моя 3.1 не тянет. Легче всего проверить работает или нет - включить эффекты, если при переключении на 3.1 они отключатся - значит увы...
tolya
Re: SuperTuxKart
Сообщение tolya »
OpenGL работает,в настройках 3.1 выбран,эффекты работают вроде бы...но в игре какие-то баги с графикой постоянно...видимо откачусь пока обратно до старой версии...
Re: SuperTuxKart
Как обновить???
Похоже на то, что в драйвере видеокарты нет нужных фич от 3.1. Хотя может она 3.1 вообще не поддерживает.
Re: SuperTuxKart
Игра обновилась до 0.9.2.
Изменения в шрифтах.
