Смена схемы энергопотребления процессора
Поставил образ 10579 c автотестинга.
Решил поменять схему энергопотребления процессора:
MyHome1 pastordi # cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
performance
MyHome1 pastordi # echo ondemand > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
bash: echo: ошибка записи: Недопустимый аргумент
MyHome1 pastordi # cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors
performance powersave
MyHome1 pastordi #
вот еще:
MyHome1 pastordi # cpupower frequency-set -g ondemand
Setting cpu: 0
Error setting new values. Common errors:
- Do you have proper administration rights? (super-user?)
- Is the governor you requested available and modprobed?
- Trying to set an invalid policy?
- Trying to set a specific frequency, but userspace governor is not available,
   for example because of hardware which cannot be set to a specific frequency
   or because the userspace governor isn't loaded?
MyHome1 pastordi #
Работа сервиса:
MyHome1 pastordi # systemctl status cpupower
cpupower.service - Configure CPU power related settings
   Loaded: loaded (/lib/systemd/system/cpupower.service; enabled)
   Active: active (exited) since Пн 2015-04-27 08:24:12 MSK; 7h ago
  Process: 4335 ExecStart=/usr/bin/cpupower $CPUPOWER_START_OPTS (code=exited, status=0/SUCCESS)
 Main PID: 4335 (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/cpupower.service
апр 27 08:24:12 MyHome1 cpupower[4335]: Setting cpu: 0
апр 27 08:24:12 MyHome1 cpupower[4335]: Setting cpu: 1
апр 27 08:24:12 MyHome1 cpupower[4335]: Setting cpu: 2
апр 27 08:24:12 MyHome1 cpupower[4335]: Setting cpu: 3
апр 27 08:24:12 MyHome1 systemd[1]: Started Configure CPU power related settings.
MyHome1 pastordi #
В ядре все включено, и самое прикольное, что ondemand по дефолту стоит. А cpupower показывает что perfomance. Как это понимать?
MyHome1 pastordi # zgrep CPU_FREQ /proc/config.gz
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=m
CONFIG_CPU_FREQ_STAT_DETAILS=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
MyHome1 pastordi #
Где что заблокированно? Не пойму. Раньше менялось, теперь нет. И почему в scaling_available_governors нет других схем?
Под root'ом ничего сделать нельзя. Хм... Или я чёта туплю?
Ядро 3.14.33
Re: Смена схемы энергопотребления процессора
В новом ядре (сегодня улетит в тестинг) схемы автоматом ставятся как надо.
keleg писал(а):В новом ядре (сегодня улетит в тестинг) схемы автоматом ставятся как надо.
:) мне не нужно "как надо", мне нужно ondemand.
А у тебя сам сервис не падает потому что ondemand не поддерживается?
keleg писал(а):А у тебя сам сервис не падает потому что ondemand не поддерживается?
Я выше выхлоп привел. Ничего не падает. Просто хочу ondemand.
Карочи поменял на ondemand. :( cpupower не стартует, режим по умолчанию стоит powersave.
Верну обратно, конечно. Но... это не нормально как-то. Даже режим не поменять, их 5 шт, а доступно 2 всего. :(
euspectre
Сообщение euspectre »
PastorDi писал(а):Карочи поменял на ondemand. :( cpupower не стартует, режим по умолчанию стоит powersave.
У тебя, вероятно, система использует не драйвер acpi_cpufreq, а более новый intel_pstate. Посмотри, что выдаст
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver.
acpi_cpufreq поддерживает "ondemand" governor + ещё несколько.
intel_pstate поддерживает "powersave" (наиболее близко к "ondemand" для acpi_cpufreq, несмотря на название) и "performance".
У нас по умолчанию ставится "ondemand", если используется драйвер acpi_cpufreq, и "powersave", если intel_pstate.
В ядре , действительно, включена поддержка основных governors для обоих драйверов, но сам выбор драйвера (acpi_cpufreq или intel_pstate) определяется железом, мы на это не влияем.
Угу, спасиб!
Да точно, intel_pstate используется. И после сноса cpupower из системы, заметил, что режим powersave ставится автоматом.
euspectre
Отлично! Да, так и должно быть.
*d0s
Operating system: OS X
Сообщение *d0s »
PastorDi писал(а): Угу, спасиб!
Поясните пожалуйста, т.е. снесли cpupower и снова поставил его. Так?
А то у меня такая же фигня со стартом cpupower.
Снес его совсем.
После того по дефолту "powersave" стал режим.
Сейчас новый cpupower есть в репах. Обновите его.
А что у вас с cpupower?
*d0s
Сообщение *d0s »
PastorDi писал(а): Снес его совсем.
Я не стал ждать Вашего ответа и удалил его, а потом снова поставил.
Было так
cpupower.service               loaded failed failed    Configure CPU power related se
теперь так
   Active: active (exited) since Сб 2015-05-02 14:50:21 NOVT; 15min ago
  Process: 4064 ExecStart=/usr/bin/cpupower $CPUPOWER_START_OPTS (code=exited, status=0/SUCCESS)
 Main PID: 4064 (code=exited, status=0/SUCCESS)
Правда появилось ещё кое-что. Ранее этого не было.
Помечены красным (systemctl -a)
auditd.service dm.service ipsec.service livesys-late.service ntpdate.service remount-rootfs.service shorewall6.service vboxadd-timesync.service ypbind.service syslog.target
P.S. Чуть не забыл, я удалил shorewall6. На фига я его ставил.
перегрузите комп после удаления shorewall' или:
systemctl daemon-reload
Ну а дальше , если еще есть "красные", надо по каждому разбираться.
systemctl status <сервис>
Кстати, можете еще дерево иерархии сервисов вывести. Оно большое, но полезное,сразу видно какой сервис от чего зависит и что запускает.
systemd-cgls
*d0s
Сообщение *d0s »
systemctl status auditd.service
auditd.service
   Loaded: not-found (Reason: No such file or directory)
   Active: inactive (dead)
systemctl status dm.service
dm.service
systemctl status ipsec.service
ipsec.service
systemctl status livesys-late.service
systemctl status ntpdate.service
ntpdate.service - Set time via NTP
   Loaded: loaded (/lib/systemd/system/ntpdate.service; static)
   Active: failed (Result: exit-code) since Сб 2015-05-02 14:50:58 NOVT; 1h 4min ago
 Main PID: 4613 (code=exited, status=1/FAILURE)
systemctl status remount-rootfs.service
systemctl status vboxadd-timesync.service
vboxadd-timesync.service - LSB: VirtualBox Additions Service
   Loaded: loaded (/etc/rc.d/init.d/vboxadd-timesync)
   Active: failed (Result: exit-code) since Сб 2015-05-02 14:50:24 NOVT; 1h 6min ago
systemctl status ypbind.service
ypbind.service
systemctl status syslog.target
syslog.target
Вроде удалял shorewall6. Странно. :o Ладно, оставлю его пока.
У меня установлен virtualbox (http://forum.rosalab.ru/viewtopic.php?f ... 84a#p43816).
Так это у вас вывод из системы которая загружена в VirtualBox'е ? Не на реальном железе?
*d0s
Сообщение *d0s »
PastorDi писал(а):Так это у вас вывод из системы которая загружена в VirtualBox'е ? Не на реальном железе?
На реальном.
├─1 /lib/systemd/systemd --switched-root --system --deserialize 23
├─user.slice
│ └─user-501.slice
│   ├─session-c1.scope
│   │ ├─ 3306 kdeinit4: konsole [kdeinit]
│   │ ├─ 3308 /bin/bash
│   │ ├─ 4539 systemd-cgls
│   │ ├─ 4540 /bin/bash
│   │ ├─ 5204 -:0
│   │ ├─ 6857 /bin/sh /usr/bin/startkde
│   │ ├─ 7609 /usr/bin/dbus-launch --exit-with-session --sh-syntax
│   │ ├─ 7610 /bin/dbus-daemon --fork --print-pid 5 --print-address 7 --sessi...
│   │ ├─ 7624 s2u --daemon=yes
│   │ ├─ 7710 /usr/lib64/kde4/libexec/start_kdeinit +kcminit_startup
│   │ ├─ 7711 kdeinit4: kdeinit4 Running...
│   │ ├─ 7712 kdeinit4: klauncher [kdeinit] --fd=9
│   │ ├─ 7714 kdeinit4: kded4 [kdeinit]
│   │ ├─ 7716 /usr/lib64/gam_server
│   │ ├─ 7719 kdeinit4: kglobalaccel [kdeinit]
│   │ ├─ 7732 /usr/bin/kactivitymanagerd
│   │ ├─ 7741 kwrapper4 ksmserver
│   │ ├─ 7742 kdeinit4: ksmserver [kdeinit]
│   │ ├─ 7755 kwin
│   │ ├─ 7761 kdeinit4: plasma-desktop [kdeinit]
│   │ ├─ 7762 /usr/bin/baloo_file
│   │ ├─ 7765 ksysguardd
│   │ ├─ 7767 /usr/bin/rosa-launcher -s
│   │ ├─ 7805 /usr/bin/kuiserver
│   │ ├─ 7808 /usr/bin/akonadi_control
│   │ ├─ 7810 akonadiserver
│   │ ├─ 7814 /usr/sbin/mysqld --defaults-file=/home/makosh/.local/share/akon...
│   │ ├─ 7854 kdeinit4: krunner [kdeinit]
│   │ ├─ 7858 /usr/bin/python /usr/share/system-config-printer/applet.py
│   │ ├─ 7860 /usr/bin/perl /usr/bin/mdkapplet
│   │ ├─ 7861 /usr/bin/xsettings-kde
│   │ ├─ 7865 kdeinit4: klipper [kdeinit]
│   │ ├─ 7866 /usr/lib64/kde4/libexec/polkit-kde-authentication-agent-1
│   │ ├─ 7870 /usr/bin/pulseaudio --start --log-target=syslog
│   │ ├─ 7872 kdeinit4: kmix [kdeinit]
│   │ ├─ 7878 /usr/lib64/pulse/gconf-helper
│   │ ├─ 7880 /usr/lib64/gconfd-2
│   │ ├─ 7890 /usr/bin/knotify4
│   │ ├─ 7911 /usr/bin/akonadi_agent_launcher akonadi_akonotes_resource akona...
│   │ ├─ 7912 /usr/bin/akonadi_baloo_indexer --identifier akonadi_baloo_index...
│   │ ├─ 7913 /usr/bin/akonadi_agent_launcher akonadi_contacts_resource akona...
│   │ ├─ 7914 /usr/bin/akonadi_agent_launcher akonadi_ical_resource akonadi_i...
│   │ ├─ 7915 /usr/bin/akonadi_agent_launcher akonadi_maildir_resource akonad...
│   │ ├─ 7916 /usr/bin/akonadi_maildispatcher_agent --identifier akonadi_mail...
│   │ ├─ 7917 /usr/bin/akonadi_mailfilter_agent --identifier akonadi_mailfilt...
│   │ ├─ 7918 /usr/bin/akonadi_migration_agent --identifier akonadi_migration...
│   │ ├─ 7919 /usr/bin/akonadi_newmailnotifier_agent --identifier akonadi_new...
│   │ ├─ 7920 /usr/bin/akonadi_notes_agent --identifier akonadi_notes_agent
│   │ ├─ 7955 /bin/cat
│   │ ├─ 7956 /bin/cat
│   │ ├─ 7959 /bin/cat
│   │ ├─ 7960 /bin/cat
│   │ ├─ 7961 /bin/cat
│   │ ├─16269 /usr/lib64/gvfsd
│   │ ├─16273 /usr/lib64/gvfsd-fuse /run/user/501/gvfs -f -o big_writes
│   │ ├─18346 /usr/lib64/at-spi-bus-launcher
│   │ ├─18349 /bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf ...
│   │ ├─18352 /usr/lib64/at-spi2-registryd --use-gnome-session
│   │ ├─21840 /usr/bin/vlc --started-from-file
│   │ ├─22985 kdeinit4: kio_file [kdeinit] file local:/run/user/501/ksocket-m...
│   │ ├─24134 kdeinit4: kio_file [kdeinit] file local:/run/user/501/ksocket-m...
│   │ ├─24135 kdeinit4: kio_thumbnail [kdeinit] thumbnail local:/run/user/501...
│   │ ├─26772 /usr/bin/firefox
│   │ ├─26822 /usr/lib/mozilla/kmozillahelper
│   │ └─32508 kdeinit4: kwrite [kdeinit] /media/makosh/1CD80B3B301925CE/pos/
│   └─user@501.service
│     ├─6835 /lib/systemd/systemd --user
│     ├─6859 (sd-pam)
│     └─dbus.service
│       └─7571 /bin/dbus-daemon --session --address=systemd: --nofork --nopid...
└─system.slice
  ├─bluetooth.service
  │ └─7773 /usr/lib64/bluetooth/bluetoothd
  ├─udisks2.service
  │ ├─ 7735 /usr/lib/udisks2/udisksd --no-debug
  │ └─32389 /sbin/mount.ntfs /dev/sdd1 /media/makosh/1CD80B3B301925CE -o rw,n...
  ├─polkit.service
  │ └─4245 /usr/lib/polkit-1/polkitd --no-debug
  ├─systemd-udevd.service
  │ └─500 /lib/systemd/systemd-udevd
  ├─systemd-journald.service
  │ └─496 /lib/systemd/systemd-journald
  ├─kdm.service
  │ ├─4068 /usr/bin/kdm -nodaemon
  │ └─4097 /etc/X11/X :0 vt1 -nolisten tcp -auth /var/run/xauth/A:0-OKAj6b
  ├─accounts-daemon.service
  │ └─4054 /usr/lib64/accounts-daemon
  ├─rpcbind.service
  │ └─4610 /sbin/rpcbind -w -i
  ├─nscd.service
  │ └─4039 /usr/sbin/nscd --foreground
  ├─cups.service
  │ └─7881 /usr/sbin/cupsd -f
  ├─avahi-daemon.service
  │ ├─4066 avahi-daemon: running [suntek-To-be-filled-by-O-E-M.local]
  │ └─4075 avahi-daemon: chroot helper
  ├─dbus.service
  │ └─4045 /bin/dbus-daemon --system --address=systemd: --nofork --nopidfile ...
  ├─rtkit-daemon.service
  │ └─4037 /usr/lib64/rtkit-daemon
  ├─upower.service
  │ └─4036 /usr/lib64/upowerd
  ├─systemd-logind.service
  │ └─4035 /lib/systemd/systemd-logind
  ├─NetworkManager.service
  │ ├─4044 /usr/sbin/NetworkManager --no-daemon
  │ └─9180 /sbin/dhclient -d -sf /usr/lib64/nm-dhcp-helper -pf /var/run/dhcli...
  ├─nmb.service
  │ └─4719 /usr/sbin/nmbd
  ├─acpid.service
  │ └─4027 /usr/sbin/acpid -f
  ├─rsyslog.service
  │ └─4024 /sbin/rsyslogd -n
  ├─sensord.service
  │ └─4156 /usr/sbin/sensord -i 1m -l 20m -f daemon
  ├─ntpd.service
  │ ├─5230 /usr/sbin/ntpd -u ntp:ntp -g
  │ └─5241 /usr/sbin/ntpd -u ntp:ntp -g
  ├─smartd.service
  │ └─4017 /usr/sbin/smartd -n
  ├─openl2tp.service
  │ └─4713 /usr/sbin/openl2tpd
  ├─avahi-dnsconfd.service
  │ └─4011 /usr/sbin/avahi-dnsconfd -s
  ├─ModemManager.service
  │ └─3998 /usr/sbin/ModemManager
  ├─autofs.service
  │ └─4613 /usr/sbin/automount --pid-file /run/autofs.pid
  ├─hddtemp.service
  │ └─3997 /usr/sbin/hddtemp -dF -l 127.0.0.1 /dev/hd? /dev/sd?
  ├─clamav-freshclam.service
  │ └─4679 /usr/bin/freshclam --config-file=/etc/freshclam.conf -d
  ├─mdmonitor.service
  │ └─3999 /sbin/mdadm --monitor --scan -f --pid-file=/run/mdadm/mdadm.pid
  ├─crond.service
  │ └─5223 /usr/sbin/crond -n
  ├─atd.service
  │ └─3994 /usr/sbin/atd -f
  ├─usbmuxd.service
  │ └─3993 /usr/sbin/usbmuxd -u -f -U usbmux
  ├─xl2tpd.service
  │ └─4584 /usr/sbin/xl2tpd -D
  ├─mandi.service
  │ └─5191 /usr/sbin/mandi -d
  ├─preload.service
  │ └─5236 /usr/sbin/preload --verbose 1
  ├─saslauthd.service
  │ ├─4726 saslauthd -m /var/run/saslauthd -a pam
  │ ├─4727 saslauthd -m /var/run/saslauthd -a pam
  │ ├─4728 saslauthd -m /var/run/saslauthd -a pam
  │ ├─4729 saslauthd -m /var/run/saslauthd -a pam
  │ └─4731 saslauthd -m /var/run/saslauthd -a pam
  └─xinetd.service
    └─4627 xinetd -stayalive -reuse -pidfile /var/run/xinetd.pid
Не обращайте внимания на эти сервисы. :) Они просто не подключены.
*d0s
Сообщение *d0s »
PastorDi писал(а):Не обращайте внимания на эти сервисы. :) Они просто не подключены.
Ну что ж, значит жить буду. Спасибо! Ваше здоровье! :beer:
