journalctl ошибки
journalctl ошибки
Поставил вчера систему с нуля. Обновил с тестинга, дрова fglrx поставил.
В jourlalctl пачечька ошибок:
[root@MyHome1 pastordi]# journalctl -p err
-- Logs begin at Пн 2015-04-06 00:51:43 MSK, end at Вт 2015-04-07 13:24:18 MSK. --
апр 06 00:51:53 MyHome1 pulseaudio[7681]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 00:51:53 MyHome1 pulseaudio[7709]: [pulseaudio] pid.c: Daemon already running.
апр 06 00:52:14 MyHome1 kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10102msec
апр 06 00:52:25 MyHome1 kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10027msec
апр 06 00:52:26 MyHome1 kernel: [drm:si_dpm_set_power_state] *ERROR* si_set_sw_state failed
апр 06 00:52:26 MyHome1 kernel: [drm:r600_ib_test] *ERROR* radeon: fence wait failed (-35).
апр 06 00:52:26 MyHome1 kernel: [drm:radeon_ib_ring_tests] *ERROR* radeon: failed testing IB on GFX ring (-35).
апр 06 00:52:26 MyHome1 kdm[4546]: X server for display :0 terminated unexpectedly
апр 06 00:52:26 MyHome1 kdm_greet[8018]: GreeterPlugin fprintd does not exist
апр 06 00:52:29 MyHome1 systemd-logind[4529]: Failed to apply ACLs: No such file or directory
апр 06 00:52:32 MyHome1 pulseaudio[8300]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 00:52:32 MyHome1 pulseaudio[8347]: [pulseaudio] pid.c: Daemon already running.
апр 06 00:57:23 MyHome1 kdm[4546]: Cannot execute 'grub-set-default': not in $PATH.
апр 06 00:57:23 MyHome1 kdm[4546]: Cannot execute 'grub': not in $PATH.
апр 06 00:57:29 MyHome1 nmbd[5619]: [2015/04/06 00:57:29.953104,  0] ../source3/nmbd/nmbd.c:57(terminate)
апр 06 00:57:29 MyHome1 nmbd[5619]: Got SIGTERM: going down...
апр 06 00:57:29 MyHome1 rpcbind[5503]: rpcbind terminating on signal. Restart with "rpcbind -w"
апр 06 00:57:30 MyHome1 systemd[1]: Failed unmounting Temporary Directory.
апр 06 00:57:30 MyHome1 kernel: watchdog watchdog0: watchdog did not stop!
-- Reboot --
апр 06 03:57:57 MyHome1 kernel: radeon 0000:01:00.0: Invalid ROM contents
апр 06 00:58:05 MyHome1 systemd[1]: Failed to start Configure CPU power related settings.
апр 06 00:58:13 MyHome1 kdm_greet[4744]: GreeterPlugin fprintd does not exist
апр 06 00:58:21 MyHome1 nmbd[5499]: [2015/04/06 00:58:21.010797,  0] ../source3/nmbd/nmbd.c:949(main)
апр 06 00:58:21 MyHome1 nmbd[5499]: standard input is not a socket, assuming -D option
апр 06 00:58:21 MyHome1 nmbd[5620]: [2015/04/06 00:58:21.011825,  0] ../lib/util/become_daemon.c:136(daemon_ready)
апр 06 00:58:44 MyHome1 nmbd[5620]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
апр 06 00:58:44 MyHome1 nmbd[5620]: апр 06 00:58:44 MyHome1 nmbd[5620]: Samba name server MYHOME1 is now a local master browser for workgrou
апр 06 00:58:44 MyHome1 nmbd[5620]: апр 06 00:58:44 MyHome1 nmbd[5620]: *****
апр 06 00:58:52 MyHome1 systemd-udevd[542]: timeout '/bin/sh -c '[ -f /dev/.in_sysinit ] && echo in_sysinit=1 || :''
апр 06 00:58:52 MyHome1 systemd-udevd[517]: timeout '/bin/sh -c '[ -f /dev/.in_sysinit ] && echo in_sysinit=1 || :''
апр 06 00:58:52 MyHome1 systemd-udevd[517]: timeout 'net_create_ifcfg'
апр 06 00:58:52 MyHome1 systemd-udevd[517]: timeout 'net_action'
апр 06 00:58:52 MyHome1 systemd-udevd[542]: timeout 'net_create_ifcfg'
апр 06 00:58:52 MyHome1 systemd-udevd[542]: timeout 'net_action'
апр 06 00:59:14 MyHome1 systemd-logind[4555]: Failed to apply ACLs: No such file or directory
апр 06 00:59:25 MyHome1 pulseaudio[8340]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 00:59:25 MyHome1 pulseaudio[8383]: [pulseaudio] pid.c: Daemon already running.
апр 06 00:59:59 MyHome1 kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10024msec
апр 06 01:00:10 MyHome1 kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10038msec
апр 06 01:00:11 MyHome1 kernel: [drm:si_dpm_set_power_state] *ERROR* si_set_sw_state failed
апр 06 01:00:11 MyHome1 kernel: [drm:r600_ib_test] *ERROR* radeon: fence wait failed (-35).
апр 06 01:00:11 MyHome1 kernel: [drm:radeon_ib_ring_tests] *ERROR* radeon: failed testing IB on GFX ring (-35).
апр 06 01:00:11 MyHome1 kdm[4570]: X server for display :0 terminated unexpectedly
апр 06 01:00:11 MyHome1 kdm_greet[8687]: GreeterPlugin fprintd does not exist
апр 06 01:00:15 MyHome1 systemd-logind[4555]: Failed to apply ACLs: No such file or directory
апр 06 01:00:17 MyHome1 pulseaudio[9122]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 01:00:17 MyHome1 pulseaudio[9164]: [pulseaudio] pid.c: Daemon already running.
апр 06 01:19:08 MyHome1 nmbd[5620]: [2015/04/06 01:19:08.456611,  0] ../source3/nmbd/nmbd.c:57(terminate)
апр 06 01:19:08 MyHome1 nmbd[5620]: Got SIGTERM: going down...
апр 06 01:19:08 MyHome1 rpcbind[5504]: rpcbind terminating on signal. Restart with "rpcbind -w"
апр 06 01:19:08 MyHome1 kdm[8680]: :0[8680]: pam_systemd(kde:session): Failed to release session: Refusing activation, D-Bus is shutting dow
апр 06 01:19:08 MyHome1 kdm[8680]: :0[8680]: pam_close_session() failed: Cannot make/remove an entry for the specified session
апр 06 01:19:08 MyHome1 systemd[1]: Failed unmounting Temporary Directory.
апр 06 01:19:09 MyHome1 kernel: watchdog watchdog0: watchdog did not stop!
-- Reboot --
апр 06 04:19:55 MyHome1 kernel: radeon 0000:01:00.0: Invalid ROM contents
апр 06 01:20:02 MyHome1 systemd[1]: Failed to start Configure CPU power related settings.
апр 06 01:20:12 MyHome1 kdm_greet[5385]: GreeterPlugin fprintd does not exist
апр 06 01:20:16 MyHome1 systemd-logind[4498]: Failed to apply ACLs: No such file or directory
апр 06 01:20:17 MyHome1 nmbd[5568]: [2015/04/06 01:20:17.143225,  0] ../source3/nmbd/nmbd.c:949(main)
апр 06 01:20:17 MyHome1 nmbd[5568]: standard input is not a socket, assuming -D option
апр 06 01:20:17 MyHome1 nmbd[5627]: [2015/04/06 01:20:17.144135,  0] ../lib/util/become_daemon.c:136(daemon_ready)
апр 06 01:20:28 MyHome1 pulseaudio[6370]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 01:20:28 MyHome1 pulseaudio[6424]: [pulseaudio] pid.c: Daemon already running.
апр 06 01:20:40 MyHome1 nmbd[5627]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
апр 06 01:20:40 MyHome1 nmbd[5627]: апр 06 01:20:40 MyHome1 nmbd[5627]: Samba name server MYHOME1 is now a local master browser for workgrou
апр 06 01:20:40 MyHome1 nmbd[5627]: апр 06 01:20:40 MyHome1 nmbd[5627]: *****
апр 06 01:21:11 MyHome1 kernel: radeon 0000:01:00.0: ring 3 stalled for more than 10340msec
апр 06 01:21:11 MyHome1 kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10340msec
апр 06 01:21:23 MyHome1 kernel: radeon 0000:01:00.0: ring 0 stalled for more than 10296msec
апр 06 01:21:23 MyHome1 kernel: [drm:si_dpm_set_power_state] *ERROR* si_set_sw_state failed
апр 06 01:21:23 MyHome1 kernel: [drm:r600_ib_test] *ERROR* radeon: fence wait failed (-35).
апр 06 01:21:23 MyHome1 kernel: [drm:radeon_ib_ring_tests] *ERROR* radeon: failed testing IB on GFX ring (-35).
апр 06 01:21:23 MyHome1 kdm[4550]: X server for display :0 terminated unexpectedly
апр 06 01:21:24 MyHome1 kdm_greet[6872]: GreeterPlugin fprintd does not exist
апр 06 01:21:27 MyHome1 systemd-logind[4498]: Failed to apply ACLs: No such file or directory
апр 06 01:21:30 MyHome1 pulseaudio[7238]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 01:21:30 MyHome1 pulseaudio[7281]: [pulseaudio] pid.c: Daemon already running.
апр 06 01:33:34 MyHome1 kdm[4550]: Cannot execute 'grub-set-default': not in $PATH.
апр 06 01:33:34 MyHome1 kdm[4550]: Cannot execute 'grub': not in $PATH.
апр 06 01:33:41 MyHome1 nmbd[5627]: [2015/04/06 01:33:41.110802,  0] ../source3/nmbd/nmbd.c:57(terminate)
апр 06 01:33:41 MyHome1 nmbd[5627]: Got SIGTERM: going down...
апр 06 01:33:41 MyHome1 rpcbind[5588]: rpcbind terminating on signal. Restart with "rpcbind -w"
апр 06 01:33:41 MyHome1 systemd[1]: Failed unmounting Temporary Directory.
-- Reboot --
апр 07 00:43:56 MyHome1 kernel: radeon 0000:01:00.0: Invalid ROM contents
апр 06 21:44:03 MyHome1 systemd[1]: Failed to start Configure CPU power related settings.
апр 06 21:44:16 MyHome1 kdm_greet[5471]: GreeterPlugin fprintd does not exist
апр 06 21:44:18 MyHome1 nmbd[5490]: [2015/04/06 21:44:18.977865,  0] ../source3/nmbd/nmbd.c:949(main)
апр 06 21:44:18 MyHome1 nmbd[5490]: standard input is not a socket, assuming -D option
апр 06 21:44:18 MyHome1 nmbd[5595]: [2015/04/06 21:44:18.978827,  0] ../lib/util/become_daemon.c:136(daemon_ready)
апр 06 21:44:20 MyHome1 systemd-logind[4555]: Failed to apply ACLs: No such file or directory
апр 06 21:44:24 MyHome1 pulseaudio[6358]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 21:44:24 MyHome1 pulseaudio[6380]: [pulseaudio] pid.c: Daemon already running.
апр 06 21:44:41 MyHome1 nmbd[5595]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
апр 06 21:44:41 MyHome1 nmbd[5595]: апр 06 21:44:41 MyHome1 nmbd[5595]: Samba name server MYHOME1 is now a local master browser for workgrou
апр 06 21:44:41 MyHome1 nmbd[5595]: апр 06 21:44:41 MyHome1 nmbd[5595]: *****
апр 06 21:56:27 MyHome1 systemd-coredump[10227]: Process 10226 (monitor-get-edi) dumped core.
апр 06 21:56:27 MyHome1 systemd-coredump[10229]: Process 10228 (monitor-get-edi) dumped core.
апр 06 21:56:27 MyHome1 systemd-coredump[10231]: Process 10230 (monitor-get-edi) dumped core.
апр 06 21:57:27 MyHome1 systemd-coredump[11536]: Process 11535 (monitor-get-edi) dumped core.
апр 06 21:57:27 MyHome1 systemd-coredump[11538]: Process 11537 (monitor-get-edi) dumped core.
апр 06 21:57:27 MyHome1 systemd-coredump[11540]: Process 11539 (monitor-get-edi) dumped core.
апр 06 21:59:12 MyHome1 nmbd[5595]: [2015/04/06 21:59:12.682929,  0] ../source3/nmbd/nmbd.c:57(terminate)
апр 06 21:59:12 MyHome1 nmbd[5595]: Got SIGTERM: going down...
апр 06 21:59:12 MyHome1 nmbd[5595]: [2015/04/06 21:59:12.683026,  0] ../source3/libsmb/nmblib.c:873(send_udp)
апр 06 21:59:12 MyHome1 nmbd[5595]: Packet send failed to 192.168.1.255(138) ERRNO=Операция не позволена
апр 06 21:59:12 MyHome1 nmbd[5595]: [2015/04/06 21:59:12.684155,  0] ../source3/libsmb/nmblib.c:873(send_udp)
апр 06 21:59:12 MyHome1 rpcbind[5511]: rpcbind terminating on signal. Restart with "rpcbind -w"
апр 06 21:59:12 MyHome1 kdm[5467]: :0[5467]: pam_systemd(kde:session): Failed to release session: Refusing activation, D-Bus is shutting dow
апр 06 21:59:12 MyHome1 kdm[5467]: :0[5467]: pam_close_session() failed: Cannot make/remove an entry for the specified session
апр 06 21:59:13 MyHome1 systemd[1]: Failed unmounting Temporary Directory.
апр 06 21:59:13 MyHome1 kernel: watchdog watchdog0: watchdog did not stop!
-- Reboot --
апр 06 21:59:37 MyHome1 systemd[1]: Failed to start Configure CPU power related settings.
апр 06 21:59:52 MyHome1 nmbd[5555]: [2015/04/06 21:59:52.015537,  0] ../source3/nmbd/nmbd.c:949(main)
апр 06 21:59:52 MyHome1 nmbd[5555]: standard input is not a socket, assuming -D option
апр 06 21:59:52 MyHome1 nmbd[5677]: [2015/04/06 21:59:52.016629,  0] ../lib/util/become_daemon.c:136(daemon_ready)
апр 06 21:59:55 MyHome1 kdm_greet[6149]: GreeterPlugin fprintd does not exist
апр 06 22:00:03 MyHome1 systemd-logind[4457]: Failed to apply ACLs: No such file or directory
апр 06 22:00:11 MyHome1 pulseaudio[7081]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 22:00:11 MyHome1 pulseaudio[7101]: [pulseaudio] pid.c: Daemon already running.
апр 06 22:00:15 MyHome1 nmbd[5677]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
апр 06 22:00:15 MyHome1 nmbd[5677]: апр 06 22:00:15 MyHome1 nmbd[5677]: Samba name server MYHOME1 is now a local master browser for workgrou
апр 06 22:00:15 MyHome1 nmbd[5677]: апр 06 22:00:15 MyHome1 nmbd[5677]: *****
апр 06 22:05:16 MyHome1 nmbd[5677]: [2015/04/06 22:05:16.079049,  0] ../source3/nmbd/nmbd.c:57(terminate)
апр 06 22:05:16 MyHome1 nmbd[5677]: Got SIGTERM: going down...
апр 06 22:05:16 MyHome1 rpcbind[5574]: rpcbind terminating on signal. Restart with "rpcbind -w"
апр 06 22:05:16 MyHome1 kdm[6143]: :0[6143]: pam_systemd(kde:session): Failed to release session: Refusing activation, D-Bus is shutting dow
апр 06 22:05:16 MyHome1 kdm[6143]: :0[6143]: pam_close_session() failed: Cannot make/remove an entry for the specified session
апр 06 22:05:16 MyHome1 systemd[1]: Failed unmounting Temporary Directory.
апр 06 22:05:16 MyHome1 kernel: watchdog watchdog0: watchdog did not stop!
-- Reboot --
апр 06 22:05:56 MyHome1 nmbd[5580]: [2015/04/06 22:05:56.027113,  0] ../source3/nmbd/nmbd.c:949(main)
апр 06 22:05:56 MyHome1 nmbd[5580]: standard input is not a socket, assuming -D option
апр 06 22:05:56 MyHome1 nmbd[5705]: [2015/04/06 22:05:56.028114,  0] ../lib/util/become_daemon.c:136(daemon_ready)
апр 06 22:05:57 MyHome1 kdm_greet[4755]: GreeterPlugin fprintd does not exist
апр 06 22:06:00 MyHome1 systemd-logind[4492]: Failed to apply ACLs: No such file or directory
апр 06 22:06:04 MyHome1 pulseaudio[6464]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.U
апр 06 22:06:04 MyHome1 pulseaudio[6488]: [pulseaudio] pid.c: Daemon already running.
апр 06 22:06:19 MyHome1 nmbd[5705]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
апр 06 22:06:19 MyHome1 nmbd[5705]: апр 06 22:06:19 MyHome1 nmbd[5705]: Samba name server MYHOME1 is now a local master browser for workgrou
апр 06 22:06:19 MyHome1 nmbd[5705]: апр 06 22:06:19 MyHome1 nmbd[5705]: *****
апр 06 22:06:28 MyHome1 systemd-udevd[518]: timeout '/bin/sh -c '[ -f /dev/.in_sysinit ] && echo in_sysinit=1 || :''
апр 06 22:06:28 MyHome1 systemd-udevd[490]: timeout '/bin/sh -c '[ -f /dev/.in_sysinit ] && echo in_sysinit=1 || :''
апр 06 22:06:28 MyHome1 systemd-udevd[490]: timeout 'net_create_ifcfg'
апр 06 22:06:28 MyHome1 systemd-udevd[518]: timeout 'net_create_ifcfg'
апр 06 22:06:28 MyHome1 systemd-udevd[490]: timeout 'net_action'
апр 06 22:06:28 MyHome1 systemd-udevd[518]: timeout 'net_action'
апр 06 22:11:32 MyHome1 systemd-coredump[10427]: Process 10426 (monitor-get-edi) dumped core.
апр 06 22:11:32 MyHome1 systemd-coredump[10429]: Process 10428 (monitor-get-edi) dumped core.
апр 06 22:11:32 MyHome1 systemd-coredump[10431]: Process 10430 (monitor-get-edi) dumped core.
апр 07 00:23:17 MyHome1 systemd-logind[4492]: Failed to apply ACLs: No such file or directory
апр 07 00:24:02 MyHome1 systemd-logind[4492]: Failed to apply ACLs: No such file or directory
апр 07 01:06:31 MyHome1 kdm[4517]: Cannot execute 'grub-set-default': not in $PATH.
апр 07 01:06:31 MyHome1 kdm[4517]: Cannot execute 'grub': not in $PATH.
апр 07 01:06:41 MyHome1 nmbd[5705]: [2015/04/07 01:06:41.482549,  0] ../source3/nmbd/nmbd.c:57(terminate)
апр 07 01:06:41 MyHome1 nmbd[5705]: Got SIGTERM: going down...
апр 07 01:06:41 MyHome1 rpcbind[5597]: rpcbind terminating on signal. Restart with "rpcbind -w"
апр 07 01:06:41 MyHome1 systemd[1]: Failed unmounting Temporary Directory.
-- Reboot --
апр 07 12:22:31 MyHome1 systemd[1]: Failed to start Configure CPU power related settings.
апр 07 12:22:38 MyHome1 kdm_greet[5809]: GreeterPlugin fprintd does not exist
апр 07 12:22:40 MyHome1 nmbd[5827]: [2015/04/07 12:22:40.967778,  0] ../source3/nmbd/nmbd.c:949(main)
апр 07 12:22:40 MyHome1 nmbd[5827]: standard input is not a socket, assuming -D option
апр 07 12:22:40 MyHome1 nmbd[5843]: [2015/04/07 12:22:40.973126,  0] ../lib/util/become_daemon.c:136(daemon_ready)
апр 07 12:23:03 MyHome1 nmbd[5843]: STATUS=daemon 'nmbd' finished starting up and ready to serve connections*****
апр 07 12:23:03 MyHome1 nmbd[5843]: апр 07 12:23:03 MyHome1 nmbd[5843]: Samba name server MYHOME1 is now a local master browser for workgrou
апр 07 12:23:03 MyHome1 nmbd[5843]: апр 07 12:23:03 MyHome1 nmbd[5843]: *****
апр 07 12:28:26 MyHome1 systemd-logind[4531]: Failed to apply ACLs: No such file or directory
апр 07 12:28:31 MyHome1 pulseaudio[21899]: [pulseaudio] bluez4-util.c: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.
апр 07 12:28:31 MyHome1 pulseaudio[21940]: [pulseaudio] pid.c: Daemon already running.
апр 07 12:39:29 MyHome1 systemd-coredump[698]: Coredump too large, ignoring
апр 07 12:39:29 MyHome1 systemd-coredump[698]: Process 24579 (firefox) dumped core.
lines 149-177/177 (END)
Можно посмотреть тут: https://linux-hardware.org/?probe=f1d8759c0f (Кроме сегодняшнего дня).
KDM что-то Граба найти не может.
monitor-get-edi что-то дампится...
Хотя всё работает.
