Sane и сканер CANON MG2540
tolya
Operating system: linux
Сообщение tolya »
Образовалась вот такая проблема,перестал работать сканер...Подсистема SANE видит сканер,но при попытке сканирования через любой Gui всё напрочь зависает.
Искал причину в интернете,ничего не помогло.
при вводе в консоли sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
  # Also you need support for SCSI Generic (sg) in your operating system.
  # If using Linux, try "modprobe sg".
found USB scanner (vendor=0x04a9 [Canon], product=0x176d [MG2500 series]) at libusb:002:006
found USB scanner (vendor=0x12d1, product=0x1003) at libusb:003:005
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
  # You may want to run this program as root to find all devices. Once you
  # found the scanner devices, be sure to adjust access permissions as
  # necessary.
Видно что сканер обшаружен.
Добавил пользователя в группу scanner.
tolya lp wheel users vboxusers scanner sambashare
но ничего не изменилось.
далее делал по http://www.altlinux.org/%D0%9D%D0%B0%D1 ... _ALT_Linux
bash-4.3$ scanimage -L
device `v4l:/dev/video0' is a Noname 1.3M WebCam virtual device
device `pixma:04A9176D_01A7E7' is a CANON Canon PIXMA MG2500 Series multi-function peripheral
все в порядке...
а вот тестирование работы
bash-4.3$ scanimage -T
scanimage: sane_start: Invalid argument
Файл /usr/share/sane/gt68xx/A2Nfw.usb на месте...
В чем может быть причина???помогите пожалуйста....
Последний раз редактировалось tolya 08 апр 2015, 19:16, всего редактировалось 1 раз.
Re: Sane и сканер CANON MG2540
tolya писал(а):Образовалась вот такая проблема,перестал работать сканер...Подсистема SANE видит сканер,но при попытке сканирования через любой Gui всё напрочь зависает.
  # necessary.
все в порядке...
А где hw-probe -all -upload -id PC_NAME с логами после ошибки?
Последний раз редактировалось Галахов Роман 08 апр 2015, 20:15, всего редактировалось 1 раз.
tolya
Сообщение tolya »
# hw-probe -all -upload -id PC_NAME
Probe for hardware ... Ok
Reading logs ... Ok
Uploaded to DB, Thank you!
Probe URL: https://linux-hardware.org/?probe=5414b2010a
d_uragan
Сообщение d_uragan »
все в порядке...
По-моему, при таком запуске scanimage попробует использовать первое устройство в списке - в вашем случае это веб-камера. Попробуйте запустить так:
$ scanimage -T -d 'pixma:04A9176D_01A7E7'
Или вообще отключить веб-камеру и посмотреть, что получится.
tolya
Сообщение tolya »
d_uragan писал(а): По-моему, при таком запуске scanimage попробует использовать первое устройство в списке - в вашем случае это веб-камера. Попробуйте запустить так:
Похоже вы правы:
bash-4.3$ scanimage -T -d 'pixma:04A9176D_01A7E7'
scanimage: scanning image of size 638x877 pixels at 24 bits/pixel
scanimage: acquiring RGB frame, 8 bits/sample
scanimage: reading one scanline, 1914 bytes...  PASS
scanimage: reading one byte...          PASS
scanimage: stepped read, 2 bytes...     PASS
scanimage: stepped read, 4 bytes...     PASS
scanimage: stepped read, 8 bytes...     PASS
scanimage: stepped read, 16 bytes...    PASS
scanimage: stepped read, 32 bytes...    PASS
scanimage: stepped read, 64 bytes...    PASS
scanimage: stepped read, 128 bytes...   PASS
scanimage: stepped read, 256 bytes...   PASS
scanimage: stepped read, 512 bytes...   PASS
scanimage: stepped read, 1024 bytes...  PASS
scanimage: stepped read, 2048 bytes...  PASS
scanimage: stepped read, 2047 bytes...  PASS
scanimage: stepped read, 1023 bytes...  PASS
scanimage: stepped read, 511 bytes...   PASS
scanimage: stepped read, 255 bytes...   PASS
scanimage: stepped read, 127 bytes...   PASS
scanimage: stepped read, 63 bytes...    PASS
scanimage: stepped read, 31 bytes...    PASS
scanimage: stepped read, 15 bytes...    PASS
scanimage: stepped read, 7 bytes...     PASS
scanimage: stepped read, 3 bytes...     PASS
Последний раз редактировалось tolya 08 апр 2015, 19:18, всего редактировалось 1 раз.
tolya
Сообщение tolya »
Странно, Xsane и gscan2pdf так же и зависают при попытке сканирования...хотя устройство выбираю 'pixma:04A9176D_01A7E7'
Но каким-то чудесным образом стали работать Scanlite,Kooka,Простое сканирование,хотя до этого была такая же картина...
tolya писал(а):Странно, Xsane и gscan2pdf так же и зависают при попытке сканирования...хотя устройство выбираю 'pixma:04A9176D_01A7E7'
Просьба, прочитать http://forum.rosalab.ru/viewtopic.php?f=9&t=1924 http://forum.rosalab.ru/viewtopic.php?f=9&t=1759 и в соответствии с этим откорректировать свои сообщения.
tolya
Сообщение tolya »
Отредактировал...действительно так лучше...
