Сan log in without typing password [solved]
I am running ROSA Linux R5 when I hit the green icon on the Rosa default login screen with no password it logged me into my account. I tried it with my wife's account and it logged into her account. I then tried it on another computer in my house running ROSA R5 and yes it logged me in. I have 3 desktops and 2 laptops running ROSA R5 one desktop and one laptop still have secure login meaning you need to use a password to gain access.on one of the laptops there is three accounts two can be accessed without typing a password. On the desktop is the same two accounts can be accessed without putting in the password. I have not tried it on this computer yet as I am informing you about this this is a big security problem as anyone could log into my account. Can any one help me with this do I need to do a fresh install. Also Password-Less logins is not enabled and neither is auto-login.
- aponomarenko
Re: Сan log in without typing password
Did you set a non-empty password for the user when installing the ROSA?
Please make probes of your computers, so that we can analyse the issue: http://wiki.rosalinux.com/en/index.php/ ... ardware_DB (don't forget to type "su" command before each probe).
To re-install the system just write the ISO image by the ROSA ImageWriter program to the flash drive and boot from it. Select "Install ROSA Desktop Fresh R5". Select your language, time, etc. Select "Use existing partitions" in the partition manager and complete the installation. Do not forget to set up the user and root password at the final step.
ISO image of ROSA R5 64-bit (with updates): http://mirror.rosalab.ru/rosa/rosa2014. ... x86_64.iso
But you can just log in to your account and type this command in the terminal to change the empty password:
where USERNAME - your login name.
passwd USERNAME
hw-probe -all -upload
here is the hardware probe link Probe URL: https://linux-hardware.org/?probe=e5bfd5f892
Changing the empty password command worked. I did set passwords for both of the effected accounts. Not sure how this happened but I'm glad it's fixed.
THANKS.
THANKS.
