Ошибка Kfjongg
Ошибка Kfjongg
запускаю значек -- все нормально. Но при старте новой игры открывается браузер с этим...
<type 'exceptions.UnicodeEncodeError'>	Python 2.7.9: /usr/bin/python
Mon Mar 9 22:49:07 2015
A problem occurred in a Python script. Here is the sequence of function calls leading up to the error, in the order they occurred.
 /usr/share/apps/kajongg/mainwindow.py in playingScene(self=<mainwindow.MainWindow object>)
    257     def playingScene(self):
    258         """play a computer game: log into a server and show its tables"""
=>  259         self.scene = PlayingScene(self)
    260         HumanClient()
    261
self = <mainwindow.MainWindow object>, self.scene = <scene.PlayingScene object>, global PlayingScene = <class 'scene.PlayingScene'>
 /usr/share/apps/kajongg/scene.py in __init__(self=<scene.PlayingScene object>, parent=<mainwindow.MainWindow object>)
    291     def __init__(self, parent):
    292         super(PlayingScene, self).__init__(parent)
=>  293         self.game = None
    294         self.__startingGame = True
    295         self._clientDialog = None
self = <scene.PlayingScene object>, self.game = None, builtin None = None
 /usr/share/apps/kajongg/scene.py in game(self=<scene.PlayingScene object>, value=None)
    301         game = self._game
    302         changing = value != game
=>  303         GameScene.game.fset(self, value)
    304         if changing:
    305             self.__startingGame = False
global GameScene = <class 'scene.GameScene'>, GameScene.game = <property object>, GameScene.game.fset = <function game>, self = <scene.PlayingScene object>, value = None
    155                     self.explainView.hide()
    156                 self.mainWindow.scene = None
=>  157         self.mainWindow.updateGUI()
    158         self.mainWindow.adjustView()
    159
self = <scene.PlayingScene object>, self.mainWindow = <mainwindow.MainWindow object>, self.mainWindow.updateGUI = <bound method MainWindow.updateGUI of <mainwindow.MainWindow object>>
 /usr/share/apps/kajongg/mainwindow.py in updateGUI(self=<mainwindow.MainWindow object>)
    568         scene = self.scene
    569         if isAlive(scene):
=>  570             scene.updateSceneGUI()
    571
    572     def changeAngle(self):
scene = <scene.PlayingScene object>, scene.updateSceneGUI = <bound method PlayingScene.updateSceneGUI of <scene.PlayingScene object>>
 /usr/share/apps/kajongg/scene.py in updateSceneGUI(self=<scene.PlayingScene object>)
    426         if not game:
    427             connections = list(x.connection for x in HumanClient.humanClients if x.connection)
=>  428             title = ', '.join('{name}/{url}'.format(name=x.username, url=x.url) for x in connections)
    429             if title:
    430                 decorateWindow(mainWindow, title)
title undefined, name undefined, x undefined, url undefined, connections = [<login.Connection object>]
 /usr/share/apps/kajongg/scene.py in ((x=<login.Connection object>,))
    426         if not game:
    429             if title:
title undefined, name undefined, x = <login.Connection object>, x.username = u'\u041c\u0430\u043a\u0441\u0438\u043c', url undefined, x.url = Url(Local Game socket=/home/delta/.kajonggserver/socket8413), connections undefined
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode characters in position 0-5: ordinal not in range(128)
      args = ('ascii', u'\u041c\u0430\u043a\u0441\u0438\u043c', 0, 6, 'ordinal not in range(128)')
      encoding = 'ascii'
      end = 6
      message = ''
      object = u'\u041c\u0430\u043a\u0441\u0438\u043c'
      reason = 'ordinal not in range(128)'
      start = 0 --> -->
Mon Mar 9 22:50:46 2015
    260         HumanClient()
    261
    304         if changing:
    159
    571
    426         if not game:
    429             if title:
    426         if not game:
    429             if title:
      encoding = 'ascii'
      end = 6
      message = ''
      start = 0 --> -->
Mon Mar 9 22:50:57 2015
    260         HumanClient()
    261
    304         if changing:
    159
    571
    426         if not game:
    429             if title:
    426         if not game:
    429             if title:
      encoding = 'ascii'
      end = 6
      message = ''
      start = 0
