Mtp protocol Android 4.4 (Solved)
Juangg1977
Operating system: Rosa Desktop Fresh R4
Ubuntu 14.04
Windows 8.1
Сообщение Juangg1977 »
Hi, I'm having problems with my Android phone and Rosa Desktop R5. I can't read properly the contents of my phone neither copy files from my phone to my PC nor viceversa.
My computer has installed kio-mtp.
¿Has anyone managed to deal with this problem?
Thanks for your help.
Последний раз редактировалось Juangg1977 27 май 2015, 12:21, всего редактировалось 1 раз.
matfx
Operating system: Rosa Desktop Fresh 2012 R2
Re: Mtp protocol Android 4.4
Сообщение matfx »
There is no problem if you installed gmtp. I attached my android phone device ( running android 4.4.4) using usb cable and Rosa Desktop recognize it, i can open my phone content with dolphin.
Pentium Dual Core E5400 4GB Ram Asus R7 240 2GB DDR3 Rosa Desktop Fresh R7 64bit
Juangg1977
Ubuntu 14.04
Windows 8.1
Thank you for your help. I don't know why, but it seems that it works correctly now, I haven't installed anything, it must have been any update which solved the problem.
Anyway, thanks for your help and sorry for my delayed answer.
Re: Mtp protocol Android 4.4 (Solved)
You can also try to install android-file-transfer package. It's a standalone utility (not integrated with Dolphin) to copy files via MTP protocol.
Вернуться в «Desktop»
