REPLACING Rocketbar
Chief
Operating system: ROSA Fresh R5
REPLACING Rocketbar
Сообщение Chief »
How do I replace ROSA FResh R5 ROCKETBAR panel with casual panel and plasma-applet-icontasks?
Re: REPLACING Rocketbar
ROSA-Add Panel?
ShalokShalom
Сообщение ShalokShalom »
Chief писал(а):How do I replace ROSA FResh R5 ROCKETBAR panel with casual panel and plasma-applet-icontasks?
You find on the right side of the Panel a Icon: Click on it and the Panel Options appear.
Click on: More Settings > Remove this Panel.
Then right click on the Desktop > Add Panel > Default Panel
Then install plasma-applet-iconstasks from the Software Manager, be aware and install the x86_64 Version. :)
I hope, this help you :)
Вернуться в «Desktop»
