ROSA Playing DVD's
dinotechrosa
Operating system: Rosa Desktop Fresh R4
ROSA Playing DVD's
Сообщение dinotechrosa »
Hello,
I'm relatively new to Linux - i've installed the ROSA Fresh R4 and I'm trying to play movie DVDs. it won't play in ROMP. The DVD title is recognized but I'm not getting any playback.
I installed the libdvdcss and libdvdread4 but there is a script that should be run after installing the library. I would like to know from the group what I need to do to get the DVD to actually play in ROMP.
I love ROSA and find it refreshing!
Dino
ShalokShalom
Operating system: ROSA
Re: ROSA Playing DVD's
Сообщение ShalokShalom »
dinotechrosa
Thanks Shalok,
I didn't read far enough on that post. Once I installed all the libraries listed the video played then stopped. Now that I see it as a bug, I'll have to use a different distro as playing DVDs is important to my client.
I'll keep an eye on that post to see if there are any changes.
Thanks again!
Dino
ShalokShalom
dinotechrosa писал(а):Thanks Shalok,
Thanks again!
Dino
It works in OpenMandriva, which is very similar to ROSA. (You use a newer Kernel, Systemd and so on in OpenMandriva)
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
