Read only blank (and own written) DVDs
Hi there ^-^
I install libdvdcss2, libdvdnav4, libdvdread4 and when i insert official DVDs like Anno 1404,
try the DVD Drive to read them and then happens nothing more. (ROSA Fresh R5)
Dolphin and the Plasma Device Manager miss the DVD Entry.
Re: Read only blank (and own written) DVDs
We may guess the DVDs are not automounted. What does
say during and after the act of inserting the media? (to start from)
tail -f /var/log/messages
Here is the log, i eject and insert the disc before and while the log runs: https://paste.kde.org/pibfd6sbz
Since Dolphin and the Device Plasmaoid in Systemtray avoid to show any Entry, same as /media, how can automount be the issue ?
Note: A Tutorial told me, to install libdvdcss/read/nav and miss the fact,
that this packages are called lib64dvdcss, read and nav for x86_64,
so i previously installed the 32 Bit Versions of these Librarys.
(There is still the same issue, even with the correct Arch.)
Please: Is it really necessary, to display the 32 Bit Resources in my 64 Bit Installation and sense full, to do this default ?
Is it possible, to drop the lib32 Apps like Steam, WINE32 and Skype into a separate Repo
and disable the common 32 Bit Repos in the upcoming 64 Bit ISOs ?
Great thanks in advance
IDK really, but resulted I have the same issue on my R3 KDE.ShalokShalom писал(а):Since Dolphin and the Device Plasmaoid in Systemtray avoid to show any Entry, same as /media, how can automount be the issue ?
Jan 15 18:53:51 gnome udisksd[6029]: Mounted /dev/sr0 at /run/media/gnome/CD_ROM on behalf of uid 500
Jan 15 18:54:00 gnome dbus-daemon[3142]: dbus[3142]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Jan 15 18:54:00 gnome dbus[3142]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Jan 15 18:54:00 gnome systemd[1]: Starting Hostname Service...
Jan 15 18:54:00 gnome dbus-daemon[3142]: dbus[3142]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jan 15 18:54:00 gnome dbus[3142]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jan 15 18:54:00 gnome systemd[1]: Started Hostname Service.
Jan 15 18:54:03 gnome gnome-session[5723]: (nautilus:28067):
Jan 15 18:55:31 gnome udisksd[6029]: Cleaning up mount point /run/media/gnome/CD_ROM (device 11:0 is not mounted)
Jan 15 18:55:31 gnome udisksd[6029]: Unmounted /dev/sr0 on behalf of uid 500
Oh, ok, thanks a lot. I can life without these DVDs. :)
Does that mean, that DRM protected DVDs are broken (or libdvd_) since R3 KDE ? o.O
For all Users ? (And why do you use R3 ? :P )
well, it's my primary system for work, all set and tuned, all hardware working, no reasons to update at allShalokShalom писал(а):And why do you use R3 ?![]()
Any News ? Does it work on Open Mandriva ? Is see no Forums and/or Issue Entry there.
I'm afraid, not.ShalokShalom писал(а):Any News ?
Feel free to file a bug on http://bugs.rosalinux.ru/, though. It's a 100% bug
DVDs are automounted or not ?
