How to Use Hauppauge Win Tv on Rosa R5
Majestic
Сообщение Majestic »
Hello.
I want to use my Hauppauge Win Tv on my Rosa R5 system.
Which program should I use and what should I do to make it working?
Thank you.
Think twice before giving a decide...
dareksmok
i5-4570 CPU @ 3.20GHz
NVIDIA GeForce GT 1030
8 GB RAM
Re: How to Use Hauppauge Win Tv on Rosa R5
Сообщение dareksmok »
HI
Linux TV applications
Popular applications for use with WinTV under Linux include MythTV, Kaffeine, Xine amd TV Time. Please refer to these applications for information on features supported. http://www.hauppauge.com/site/support/linux.html
Hauppauge http://linuxtv.org/wiki/index.php/Hauppauge
Xt7-player http://qt-apps.org/content/show.php?content=151684
Install Howto
1. Enable ROSA Contrib repository on Install and Remove Software"
2. Update packages list:
# urpmi.update -a
3. Install xt7-player3 rpm package:
# urpmi xt7-player3
Kaffeine https://www.kde.org/applications/multimedia/kaffeine/
Install Howto
# urpmi.update -a
3. Install kaffeine rpm package:
# urpmi kaffeine
ROSA Fresh R10 MATE - 64 bit
Majestic
Hey there...
Kaffeine is working good. But i have a little problem... Audio is going time to time... i couldnt figure out why but when i clicked the tv channel name again, it comes, it was quite good at the start but after 20 minutes, it started to mute itself more often....
And on HD channels videos are a bit slow or coming after the audio... they dont meet at the same time :S
What should i do about these?
Thank you again.
dareksmok
8 GB RAM
Install kaffeine-1.2.2 http://pkgs.org/download/kaffeine
on kaffeine-1.3.1 there is a similar problem.(And on HD channels videos are a bit slow or coming after the audio... they dont meet at the same time :S)
Вернуться в «ROSA Fresh R4-R7 (2014.1)»
