Проблема с запуском ABF
amag
Operating system: Linux
Сообщение amag »
Установил ABF на сервере(ROSA-Server-6.6-x86_64) по актуальной документации с помощью ansible.
В итоге на веб интерфейс зайти можно, но регистрация почему-то не работает, смотрел как на форуме, так и по документации, но ничего по этой проблеме я не нашел(может быть есть какая-то документация по настройке?).
Запускаю ABF так как написано в rosa_build.readme.
При выполнении команды:
rvm 2.1.4@rosa_build_deploy do bundle exec cap deploy:start ENV=production
выводится следующее
triggering load callbacks
* 2015-01-06 17:22:53 17:22:53 == Currently executing `deploy:start'
triggering after callbacks for `deploy:start'
* 2015-01-06 17:22:53 17:22:53 == Currently executing `puma:start'
* executing "cd /srv/rosa_build/current && bundle exec puma -q -d -e production -C ./config/puma/production.rb"
servers: ["localhost"]
[localhost] executing command
** [out :: localhost] [2190] Puma starting in cluster mode...
** [out :: localhost] [2190] * Version 2.9.1 (ruby 2.1.4-p265), codename: Team High Five
** [out :: localhost] [2190] * Min threads: 1, max threads: 3
** [out :: localhost] [2190] * Environment: production
** [out :: localhost] [2190] * Process workers: 7
** [out :: localhost] [2190] * Preloading application
*** [err :: localhost] /srv/rosa_build/releases/20150106165345/app/helpers/markdown_helper.rb:105: warning: regular expression has redundant nested repeat operator '*'
*** [err :: localhost] Both MassBuild and its :status machine have defined a different default for "status". Use only one or the other for defining defaults to avoid unexpected behaviors.
*** [err :: localhost] /srv/rosa_build/releases/20150106165345/app/models/comment.rb:8: warning: regular expression has redundant nested repeat operator '*': /(?:[a-zA-Z0-9\-_]*\/)?(?:[a-zA-Z0-9\-_]*)?#[0-9]+/
*** [err :: localhost] Both RepositoryStatus and its :status machine have defined a different default for "status". Use only one or the other for defining defaults to avoid unexpected behaviors.
** [out :: localhost] [2190] * Listening on unix:///tmp/rosa_build_unicorn.sock
** [out :: localhost] [2190] * Daemonizing...
command finished in 14828ms
* 2015-01-06 17:23:08 17:23:08 == Currently executing `resque:start'
* executing "cd /srv/rosa_build/current && COUNT=3 QUEUE=publish_observer,rpm_worker_observer,iso_worker_observer,fork_import,hook,clone_build,middle,notification INTERVAL=0.1 RAILS_ENV=production BACKGROUND=yes bundle exec rake resque:workers"
И последняя команда до конца не выполняется.
Что может быть не так настроено, или я как-то неправильно все устанавливаю и запускаю?
Re: Проблема с запуском ABF
После праздников попрошу сюда заглянуть соответствующих товарищей :)
avokhmin
Сообщение avokhmin »
еще актуально?
мы недавно на ruby-2.2.0 переключились
Вернуться в «Обсуждение сборочной среды ABF»
