После обновления на R4 перестал работать gwenview
admsasha
Operating system: ROSA
Сообщение admsasha »
$ gwenview ./splash.png
Object::connect: No such signal org::freedesktop::UPower::DeviceAdded(QString)
Object::connect: No such signal org::freedesktop::UPower::DeviceRemoved(QString)
gwenview(11880)/kdeui (kdelibs): Attempt to use QAction "edit_redo" with KXMLGUIFactory!
gwenview(11880)/kdeui (kdelibs): Attempt to use QAction "edit_undo" with KXMLGUIFactory!
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.sheet.binary.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.addin.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.slideshow.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.sheet.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.presentation.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-word.template.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-excel.template.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.template.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-word.document.macroEnabled.12"
gwenview(11880) KMimeTypeRepository::parents: "/usr/share/mime/subclasses"  refers to unknown mimetype  "application/vnd.ms-powerpoint.slide.macroEnabled.12"
X Error: BadAtom (invalid Atom parameter) 5
  Major opcode: 20 (X_GetProperty)
  Resource id:  0x0
Сам gwenview открывается, в центре показывает кружок (показатель что открывает файл) и на этом висит, пока не закроешь через kill
admsasha
Re: После обновления на R4 перестал работать gwenview
Всем спасибо :)
Удалил папку /home/sasha/.kde4/share/apps/gwenview, и всё заработало.
