Мусор в CUPS-овских пакетах
sokoloff
Сообщение sokoloff »
Поставил себе R4 и пока настраивал принтер обратил что в логе куча сообщений вида:
[18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/ti/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/nec/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/xerox/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/lexmark/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/lexmark/readme.1st"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/tektronix/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/mitsubishi/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/panasonic/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/fujitsu/readme"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/foomatic-db-ppds/Kyocera/ReadMe.htm"!
и.т.д.
Похоже, что неправильно указали пути фалов в пакетах и в эту директорию ставится мусор.
Еще есть сообщения
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/epson/epl5800l.ppd.gz"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/epson/epl6200l.ppd.gz"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/epson/epl6100l.ppd.gz"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/epson/epl5700l.ppd.gz"!
E [18/Oct/2014:23:03:17 +0400] [cups-driverd] Bad driver information file "/usr/share/cups/model/epson/epl5900l.ppd.gz"!
Все эти файлы битые и по 33 байта.
Еще
E [18/Oct/2014:23:02:39 +0400] Unknown directive BrowseAddress on line 19 of /etc/cups/cupsd.conf.
Если посмотреть документацию CUPS 1.5, CUPS 1.6, похоже ее убрали еще в 1.6
Ну и напоследок, есть варнинг
W [18/Oct/2014:23:56:13 +0400] CreateDevice failed: org.freedesktop.DBus.Error.ServiceUnknown:The name org.freedesktop.ColorManager was not provided by any .service files
похоже что-то я не доставил.
P.S.
Похоже еще есть глюк в systemd юните. Не работают команды systemctl stop cups.service и systemctl restart cups.service, первая не прибивает cups, а вторая, соответственно не может его перезапустить, порт то уже занят. Я не разбираюсь в systemd, но похоже проблема в строке KillMode=none в /lib/systemd/system
[Unit]
Description=CUPS Printing Service
[Service]
ExecStart=/usr/sbin/cupsd -f
PrivateTmp=true
KillMode=none
[Install]
Also=cups.socket cups.path
WantedBy=printer.target
Интересно откуда она появилась и зачем?
